[mapguide-users] FDO Gdal raster problem
Jsm enriquev at consortech.com
Sat Mar 28 02:22:35 EDT 2009
I used the hostname to connect, because Jmeter is running on my machine (windows xp) and the web extensions and server are on another machine (windows 2003).
I just patched the tcpip.sys limit (or "feature") and Jmeter still stops after a while, I know it has nothing to do with mapguide because I tryed it on a normal web site and it did the same thing...
Anyways I found this in jmeter.log:
2009/03/28 02:17:22 INFO  - jmeter.threads.JMeterThread: Thread Groupe de thread 1-5 is done
2009/03/28 02:17:22 INFO  - jmeter.engine.StandardJMeterEngine: Ending thread Groupe de thread 1-5
2009/03/28 02:17:23 ERROR - jmeter.threads.JMeterThread: Test failed! java.lang.OutOfMemoryError: Java heap space
I'll see if I find anything about that, for now I hope those numbers say something, if I am able to bypass this I'll run Jmeter non-stop for a day or 2 and send the results.
On Sat, Mar 28, 2009 at 4:42 PM, Jsm <enriquev at consortech.com> wrote:
> Well in the jmx file it is set to continue on error, but when you mean profile are we talking about the same thing ? (jmx file)
yep thats what i meant
> On another note I saw this in my event viewer (jmeter on winxp, server is on another machine win2k3):
> TCP/IP Has Reached the Security Limit Imposed on the Number of Concurrent TCP Connect Attempts
> So it's probably my WinXP that is messing with me, I'll try and patch my system and post Jmeter results again.
out of interested where you using localhost or your hostname
hehe, don't you just love MS :)
mapguide runs soo lot better on linux, it's just a pig to build...
z
> you don't have stop on error set in your jmeter profile?
> On Sat, Mar 28, 2009 at 4:07 PM, Jsm <enriquev at consortech.com> wrote:
>> Yes
>> There's an xls file with the stats, before and after. And also the jmx file I used, I don't know how to use Jmeter much doh, I don't understand why at somepoint it stops even when I choose loop forever, but I know it's not mapguide, as I can still access it.
>> summary-old-raster.xls
>> Summary+Report.jmx
>> View this message in context: http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548100.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> View this message in context: http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548158.html
Zac Spitzer -
+61 405 847 168
View this message in context: http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548231.html
