[mapguide-users] FDO Gdal raster problem
Zac Spitzer
zac.spitzer at gmail.com
Sat Mar 28 02:38:45 EDT 2009
i know that one!
change these lines in bin\jmeter.bat
set HEAP=-Xms256m -Xmx512m
set NEW=-XX:NewSize=128m -XX:MaxNewSize=512m
set PERM=-XX:PermSize=128m -XX:MaxPermSize=128m
z
On Sat, Mar 28, 2009 at 5:22 PM, Jsm <enriquev at consortech.com> wrote:
> I used the hostname to connect, because Jmeter is running on my machine (windows xp) and the web extensions and server are on another machine (windows 2003).
> I just patched the tcpip.sys limit (or "feature") and Jmeter still stops after a while, I know it has nothing to do with mapguide because I tryed it on a normal web site and it did the same thing...
> Anyways I found this in jmeter.log:
> 2009/03/28 02:17:22 INFO - jmeter.threads.JMeterThread: Thread Groupe de thread 1-5 is done
> 2009/03/28 02:17:22 INFO - jmeter.engine.StandardJMeterEngine: Ending thread Groupe de thread 1-5
> 2009/03/28 02:17:23 ERROR - jmeter.threads.JMeterThread: Test failed! java.lang.OutOfMemoryError: Java heap space
> I'll see if I find anything about that, for now I hope those numbers say something, if I am able to bypass this I'll run Jmeter non-stop for a day or 2 and send the results.
> On Sat, Mar 28, 2009 at 4:42 PM, Jsm <enriquev at consortech.com> wrote:
>> Well in the jmx file it is set to continue on error, but when you mean profile are we talking about the same thing ? (jmx file)
> yep thats what i meant
>> On another note I saw this in my event viewer (jmeter on winxp, server is on another machine win2k3):
>> TCP/IP Has Reached the Security Limit Imposed on the Number of Concurrent TCP Connect Attempts
>> So it's probably my WinXP that is messing with me, I'll try and patch my system and post Jmeter results again.
> out of interested where you using localhost or your hostname
> hehe, don't you just love MS :)
> mapguide runs soo lot better on linux, it's just a pig to build...
> z
>> you don't have stop on error set in your jmeter profile?
>> On Sat, Mar 28, 2009 at 4:07 PM, Jsm <enriquev at consortech.com> wrote:
>>> Yes
>>> There's an xls file with the stats, before and after. And also the jmx file I used, I don't know how to use Jmeter much doh, I don't understand why at somepoint it stops even when I choose loop forever, but I know it's not mapguide, as I can still access it.
>>> summary-old-raster.xls
>>> Summary+Report.jmx
>>> View this message in context: http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548100.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> View this message in context: http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548158.html
> Zac Spitzer -
> +61 405 847 168
> View this message in context: http://n2.nabble.com/FDO-Gdal-raster-problem-tp2538452p2548231.html
Zac Spitzer -
+61 405 847 168
