[mapguide-users] MapGuide Markup app and MgDeleteFeatures
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sun Mar 29 09:05:35 EDT 2009
The "UpdateFeatures" call does not throw an exception:
http://trac.osgeo.org/mapguide/ticket/649
You have to parse the results to see what went wrong.
Regards, Kenneth Skovhede, GEOGRAF A/S
Warren Medernach skrev:
> Thanks Andy,
> That's actually how I had it coded originally. I then saw a sample
> from AU I believe, that separated out the MgDeleteFeatures call, so I
> was trying that... Still no go, but now I see that it is happening
> intermittently on the original app as well?
> I have some digging to do.
> Warren M
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andy
> Morsell
> *Sent:* Friday, March 27, 2009 11:46 AM
> *To:* 'MapGuide Users Mail List'
> *Subject:* RE: [mapguide-users] MapGuide Markup app and MgDeleteFeatures
> Try this:
> MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
> commands.Add(new MgDeleteFeatures("Markup", "ID = " + ID));
> featureService.UpdateFeatures(featureSourceId, commands, false);
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Warren
> Medernach
> *Sent:* Friday, March 27, 2009 9:30 AM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] MapGuide Markup app and MgDeleteFeatures
> Hello all,
> I am trying to port some of the GT Markup app to code-behind aspx
> classes. When I do this, the Delete Markup Feature functionality is
> not functioning from code behind?
> The only changes I made to the code that was working in the original
> markup app are:
> I'm calling a function to retrieve the markup name (GetFullMarkupName)
> and I'm passing in the ID I'm trying to delete.
> MgFeatureService featureService =
> (MgFeatureService)app_Markup.site.CreateService(MgServiceType.FeatureService);
> MgResourceIdentifier featureSourceId = new
> MgResourceIdentifier(app_Markup.GetFullMarkupName());
> MgDeleteFeatures deleteFeat = new MgDeleteFeatures("Markup", "ID=" + ID);
> commands.Add(deleteFeat);
> Through debugging I have verified that the featureSourceId is pointing
> to the correct FeatureSource, the ID is getting passed through and the
> DeleteFeatures statement is correct, but when it calls UpdateFeatures,
> it spins away for a while, and eventually ends without deleting the
> feature, and doesn't throw an error? Would there be anything in the
> logs I could look for?
> Fyi, when I run the original markup app side-by-side, the features are
> deleted with no problems.
> Thanks for any suggestions.
> Warren M
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090329/34acc7f6/attachment.html
