[mapguide-users] MapGuide Markup app and MgDeleteFeatures
Warren Medernach
wmedernach at rand.com
Mon Mar 30 10:26:00 EDT 2009
Thanks for the info Kenneth!
Warren
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Sunday, March 29, 2009 7:06 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide Markup app and MgDeleteFeatures
The "UpdateFeatures" call does not throw an exception:
http://trac.osgeo.org/mapguide/ticket/649
You have to parse the results to see what went wrong.
Regards, Kenneth Skovhede, GEOGRAF A/S
Warren Medernach skrev:
Thanks Andy,
That's actually how I had it coded originally. I then saw a sample from
AU I believe, that separated out the MgDeleteFeatures call, so I was
trying that... Still no go, but now I see that it is happening
intermittently on the original app as well?
I have some digging to do.
Warren M
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Friday, March 27, 2009 11:46 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MapGuide Markup app and MgDeleteFeatures
Try this:
MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
commands.Add(new MgDeleteFeatures("Markup", "ID = " + ID));
featureService.UpdateFeatures(featureSourceId, commands, false);
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren
Medernach
Sent: Friday, March 27, 2009 9:30 AM
Subject: [mapguide-users] MapGuide Markup app and MgDeleteFeatures
Hello all,
I am trying to port some of the GT Markup app to code-behind aspx
classes. When I do this, the Delete Markup Feature functionality is not
functioning from code behind?
The only changes I made to the code that was working in the original
markup app are:
I'm calling a function to retrieve the markup name (GetFullMarkupName)
and I'm passing in the ID I'm trying to delete.
MgFeatureService featureService =
(MgFeatureService)app_Markup.site.CreateService(MgServiceType.FeatureSer
vice);
MgResourceIdentifier featureSourceId = new
MgResourceIdentifier(app_Markup.GetFullMarkupName());
MgDeleteFeatures deleteFeat = new MgDeleteFeatures("Markup", "ID=" +
ID);
commands.Add(deleteFeat);
Through debugging I have verified that the featureSourceId is pointing
to the correct FeatureSource, the ID is getting passed through and the
DeleteFeatures statement is correct, but when it calls UpdateFeatures,
it spins away for a while, and eventually ends without deleting the
feature, and doesn't throw an error? Would there be anything in the
logs I could look for?
Fyi, when I run the original markup app side-by-side, the features are
deleted with no problems.
Thanks for any suggestions.
Warren M
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090330/c3d1efe2/attachment.html
