[mapguide-users] Using the MapAgent directly to create map images.
Jackie Ng
jumpinjackie at gmail.com
Mon Mar 30 10:03:22 EDT 2009
I believe GETMAPIMAGE incorporates all the visible layers on the map, whereas GETDYNAMICOVERLAYIMAGE only considers the non-tiled visible layers.
- Jackie
Hi folks,
Can someone out there please tell me when using the MapAgent directly (as I am developing my own viewer) when should I use GETMAPIMAGE and GETDYNAMICMAPOVERLAYIMAGE? Is there a conceptual difference here? And if so, please explain what that difference is? I notice that the Ajax Viewer seems to consistently use the GETDYNAMICMAPOVERLAYIMAGE method? Yet I am having issues with it.
Any help would be appreciated.
Thanks,
Travis
View this message in context: http://n2.nabble.com/Using-the-MapAgent-directly-to-create-map-images.-tp2557232p2557355.html
