[mapguide-users] pleease help
saloua wakrim wakrimsaloua.wakrim at gmail.com
Sun May 3 13:20:17 EDT 2009
@ Page Language="C#" AutoEventWireup="true" CodeFile="essai.aspx.cs"
Inherits
="essai" %>
@ Import Namespace="System" %>
@ Import Namespace="System.IO" %>
@ Import Namespace="System.Collections.Specialized" %>
@ Import Namespace="OSGeo.MapGuide" %>
@ Import Namespace="System.Text" %>
@ Import Namespace="System.Globalization" %>
@ Import Namespace="OSGeo.MapGuide.Schema.LayerDefinition"%>;
<!-- #Include File="C:\Program
Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\mapviewernet\common.aspx-->
DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
html xmlns="http://www.w3.org/1999/xhtml" >
head id="Head1" runat="server">
<title>selection</title>
head>
body>
br />
String x0 = "100";
String y0 = "100";
String x1 = "109";
String y1 = "109";
String sessionid1;
MgSiteConnection siteConnection;
MgResourceService resourceSrvc;
String myLayerName = "linetest";
String mapname = "Sheboygan";
MgMap map;
MgFeatureService featureSrvc;
String configPath = "C:\\Program
Files\\Autodesk\\MapGuideEnterprise2008\\WebServerExtensions\\www\\webconfig.ini";
MapGuideApi.MgInitializeWebTier(configPath);
MgSite site1 = new MgSite();
MgUserInformation userInfo = new MgUserInformation("Administrator", "admin");
siteConnection =
new MgSiteConnection();
siteConnection.Open(userInfo);
site1 = siteConnection.GetSite();
sessionid1 = site1.CreateSession();
userInfo.SetMgSessionId(sessionid1);
resourceSrvc = (
MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService)
as MgResourceService;
featureSrvc = siteConnection.CreateService(
MgServiceType.FeatureService) as MgFeatureService;
MgResourceIdentifier resourceID = new MgResourceIdentifier(
"Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
map =
new MgMap(siteConnection);
map.Create(resourceSrvc, resourceID, mapname);
//MgResourceIdentifier mapStateId = new MgResourceIdentifier("Session:" +
sessionid1 + "//" + mapname + "." + MgResourceType.Map);
map.Save();
map.Open(resourceSrvc, mapname);
Response.Charset =
"utf-8";
//String x0 = "100";
//String y0 = "100";
//String x1 = "109";
//String y1 = "109";
String layerDef = "Library://Samples/Sheboygan/Layers/" + myLayerName +
".LayerDefinition";
MgResourceIdentifier layerDefId = new MgResourceIdentifier(layerDef);
String dataSource = "Library://Samples/Sheboygan/Data/" + myLayerName +
".FeatureSource";
MgResourceIdentifier dataSourceId = new MgResourceIdentifier(dataSource);
if (DoesLayerExist(myLayerName, map) == false)
//create Feature Source
MgClassDefinition myClassDef = new MgClassDefinition();
myClassDef.SetName(
"linetest");
//myClassDef.SetDescription(myLayerName + " Feature Source");
myClassDef.SetDefaultGeometryPropertyName(
"SHPGEOM");
//Set KEY Property
MgDataPropertyDefinition prop = new MgDataPropertyDefinition("KEY");
prop.SetDataType(
MgPropertyType.Int32);
prop.SetAutoGeneration(
true);
prop.SetReadOnly(
true);
prop.SetNullable(
false);
myClassDef.GetProperties().Add(prop);
myClassDef.GetIdentityProperties().Add(prop);
//Set ID Property
prop =
new MgDataPropertyDefinition("ID");
prop.SetDataType(
//Set geometry property
MgGeometricPropertyDefinition geomProp = new MgGeometricPropertyDefinition(
"SHPGEOM");
geomProp.SetGeometryTypes(
MgFeatureGeometricType.Curve);
geomProp.SetHasElevation(
false);
geomProp.SetHasMeasure(
false);
geomProp.SetSpatialContextAssociation(
"LL84");
myClassDef.GetProperties().Add(geomProp);
"SHPGEOM");
//Create the schema
MgFeatureSchema schema = new MgFeatureSchema();
schema.SetName(
"SHP_Shema");
schema.GetClasses().Add(myClassDef);
MgCreateSdfParams sdfParams = new MgCreateSdfParams("MGA-56 (GDA94 /MGA zone
56)", map.GetMapSRS(), schema);
featureSrvc.CreateFeatureSource(dataSourceId, sdfParams);
//create layer
//String layerDef = "Session:" + sessionid1 + "//" + myLayerName
+".LayerDefinition";
//layerDef = "Session:" + sessionid1 + "//" + myLayerName +
".LayerDefinition";
MgByteReader layerDefContent = BuildLayerDefinitionContent(dataSource,
"SHP_Shema:linetest", "", "5", "F000F");
resourceSrvc.SetResource(layerDefId, layerDefContent,
null);
MgLayer myLayer = new MgLayer(layerDefId, resourceSrvc);
myLayer.SetName(myLayerName);
myLayer.SetLegendLabel(
"legend" + myLayerName);
myLayer.SetDisplayInLegend(
true);
myLayer.SetSelectable(
true);
map.GetLayers().Insert(0, myLayer);
//map.GetLayers().Add(myLayer);
myLayer.ForceRefresh();
map.Save(resourceSrvc);
// Save the map back to the session repository
/*String sessionIdName = "Session:" + sessionid1 + "//" + mapname + ".Map";
MgResourceIdentifier sessionResourceID = new
MgResourceIdentifier(sessionIdName);
sessionResourceID.Validate();
map.Save(resourceSrvc, sessionResourceID);
//Response.Write(map.GetLayers().GetItem("layertest").GetName());
//Response.Write(map.GetLayers().GetItem("Redline2").GetLayerDefinition().ToString());
//myLayer.SetVisible(true);
MgInsertFeatures insertFeatures = new MgInsertFeatures(myLayerName,
makeLine("1", x0, y0, x1, y1));
MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
commands.Add(insertFeatures);
int commandIndex = commands.IndexOf(insertFeatures);
MgPropertyCollection insertResults;
insertResults = featureSrvc.UpdateFeatures(dataSourceId, commands,
false);
div id="viewer">
<iframe id="carte" width="800" height="300" frameborder="0" scrolling="no"
src="http://localhost/mapguide2008/mapviewerajax/?SESSION=<%=sessionid1 %>
&WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout"
name="fenetre"></iframe>
</div>
<br />
<div>
input type="button" value="zoom" name="zoom" onclick="zoom()"/>
div>
br />
div>
input type="button" value="rafraichir" name="calque" onclick="testcalque();"/>
div>
body>
script type="text/javascript">
var str2;
var str;
 function zoom()
carte.GetMapFrame().ZoomToView(-87.7116768,43.7766789973,5000,
true);
function testcalque()
//carte.GetMapFrame().GetLayers(true,true);
//carte.GetScriptFrame().location.href = "essai.aspx";
frames[
'fenetre'].location.reload();
carte.GetMapFrame().Refresh();
//carte.ExecuteMapAction(20);
//carte.GetMapFrame().ExecuteMapAction(1);
//carte.GetTaskFrame().location.href = "essai.aspx"
//carte.GetMapFrame().ExecuteMapAction(20);
script>
script runat=server>
MgPropertyCollection makeLine(String Name, String x0, String y0, String x1,
String y1)
MgPropertyCollection PropertyCollection = new MgPropertyCollection();
MgInt32Property nameProperty = new MgInt32Property("ID", 1);
PropertyCollection.Add(nameProperty);
MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
MgGeometry geometry = wktReaderWriter.Read("LINESTRING XY (" + x0 + " "+ y0
+ "," + x1 + " " + y1 + ")") as MgLineString;
 MgByteReader geometryByteReader = agfReaderWriter.Write(geometry);
MgGeometryProperty geometryProperty = new
MgGeometryProperty("SHPGEOM",geometryByteReader);
PropertyCollection.Add(geometryProperty);
return PropertyCollection;
Boolean
DoesLayerExist(String LayerName, MgMap Map)
MgLayerCollection layers = Map.GetLayers();
return (layers.Contains(LayerName));
String LoadTemplate2(String filePath)
StreamReader sr = File.OpenText(filePath);
String template = sr.ReadToEnd();
return template;
MgByteReader
BuildLayerDefinitionContent(String ResourceId, String FeatureName,
StringToolTip,
String Thickness, String LineColor)
String layerTempl = LoadTemplate2("C:\\Program
Files\\Autodesk\\MapGuideEnterprise2008\\WebServerExtensions\\www\\viewerfiles\\linelayerdef.templ");
String[] vals = {
ResourceId,
FeatureName,
"SHPGEOM",
ToolTip,
Thickness,
LineColor
layerTempl = Substitute(layerTempl, vals);
byte[] bytes = Encoding.UTF8.GetBytes(layerTempl);
MgByteSource src = new MgByteSource(bytes, bytes.Length);
return src.GetReader();
void add_layer_group(MgLayer layer, String layergroupname, MgMap map)
MgLayerGroupCollection group = map.GetLayerGroups();
MgLayerGroup grouplayer = group.GetItem(layergroupname);
layer.SetGroup(grouplayer);
map.Save();
script>
html>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090503/259e59b9/attachment.html
