[mapguide-users] can anyone solved this buffer problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 6 05:38:27 EDT 2009
I don't have code to send, I just gave you a general approach.
If you manage to produce the code based on the general idea,
it would be nice if you share it here:
http://trac.osgeo.org/mapguide/wiki/CodeSamples
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi Kenneth,
> Thanks for ur help.
> if u dont mind can u plz send me the code for retrieving features with in
> the buffer area....................
> Thanks in advance...
> Regards,
> Padmini.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> My method would be to retrieve the WKT of the buffer object,
>> then iterate all the layers, and for each layer execute a query with the
>> filter set to:
>> "<geometry column name> INTERSECTS GEOMFROMTEXT('...wkt...')"
>> You should then get all objects that are within the buffer zone.
>>> Hi,
>>> Thanks for ur reply
>>> 1)can u plz tell me how to retrieve features with in the buffer
>>> area(actually im a little bit confused)
>>> Regards,
>>> Padmini.
>>>> It looks correct, it seems to follow the edges as expected.
>>>> When creating the buffer, a simple method is to take each line, and
>>>> buffer it,
>>>> so it gets rounded corners.
>>>> Then alle the resulting buffer items are combined into a single object
>>>> that is the buffer.
>>>> If I look at your image, that seems to happen correctly.
>>>> The long side at the bottom right seems to be reflected in the buffer
>>>> edge.
>>>> If you would like it to be a perfect circle, you should only buffer a
>>>> point,
>>>> not a polygon.
>>>>> Hi Kenneth,
>>>>> i have created a buffer with 0.2 miles but i think the buffer is not
>>>>> creating accurately
>>>>> http://n2.nabble.com/file/n2745746/buffer.jpeg
>>>>> 1) can u provide any solution?????????????
>>>>> 2)And can u plz tell me the code for retrieving parcel_id with in the
>>>>> buffer
>>>>> area(im a little bit confused)
>>>>> plzzzzzzzz
>>>>> Regards,
>>>>> Padmini.
>>>>>> It looks correct to me. Try using a smaller buffer to better determine
>>>>>> accuracy.
>>>>>> For the second question, you have already asked that in another
>>>>>> thread.
>>>>>> The AJAX viewer shows selection data, so try looking at the
>>>>>> selection.aspx files,
>>>>>> and see how it works.
>>>>>>> Hi Kenneth,
>>>>>>> Thanku very much for ur help.............
>>>>>>> i did the coordinate system override as per ur instructions.
>>>>>>> It works fine
>>>>>>> but i felt that the buffer feature is not coming accurately??
>>>>>>> what was the problem????????????????????????????
>>>>>>> i mean by observing closely its not an accurate circle(buffer
>>>>>>> layer).
>>>>>>> http://n2.nabble.com/file/n2683455/pic.jpeg
>>>>>>> 2)secondly i want to retrieve the parcel_ids that are included or
>>>>>>> intersected in the buffer layer.How is it possible ? can u send me
>>>>>>> the
>>>>>>> sample code?????????
>>>>>>> Thanks in advance.
>>>>>>> Regards,
>>>>>>> Padmini.
>>>>>>>> Thats because the Sheboygan data uses a true georeferenced
>>>>>>>> coordinate
>>>>>>>> system,
>>>>>>>> and your data is using a non-georeferenced system, like XY-M.
>>>>>>>> Arbitrary should be understood as "non-georeferenced".
>>>>>>>> If your data is not in the same projection as the map, you cannot
>>>>>>>> use
>>>>>>>> the buffer feature.
>>>>>>>> This then returns to my initial statement: "Coordinate System
>>>>>>>> Override",
>>>>>>>> which can
>>>>>>>> set the data coordinate system to match the maps.
>>>>>>>> Can you please report what happened with with the suggestions I
>>>>>>>> made,
>>>>>>>> regarding the coordinate system overrides?
>>>>>>>>> Hi,
>>>>>>>>> In my data
>>>>>>>>> bool arbitraryMapSrs = (srsMap.GetType() ==
>>>>>>>>> MgCoordinateSystemType.Arbitrary);
>>>>>>>>> arbitraryMapSrs comes as true but in sheboygan data it comes as
>>>>>>>>> false
>>>>>>>>> if (arbitraryMapSrs)
>>>>>>>>> mapSrsUnits = srsMap.GetUnits();
>>>>>>>>> In mydata mapSrsUnits comes as "meter" but in sheboygan data it
>>>>>>>>> comes
>>>>>>>>> as
>>>>>>>>> null
>>>>>>>>> so that
>>>>>>>>> if ((arbitraryDsSrs != arbitraryMapSrs) || (arbitraryDsSrs &&
>>>>>>>>> (dsSrsUnits
>>>>>>>>> != mapSrsUnits)))
>>>>>>>>> excludedLayers++;
>>>>>>>>> continue;
>>>>>>>>> In my data excludedLayers comes as 1 and where as in sheboyan data
>>>>>>>>> this
>>>>>>>>> condition fails....................
>>>>>>>>> Can u plz provide me the solution?????????????
>>>>>>>>> Regards,
>>>>>>>>> Padmini.
>>>>>>>>>> Why do you mention packages?
>>>>>>>>>> excludedLayers is incremented because the data coordinate system
>>>>>>>>>> is
>>>>>>>>>> not
>>>>>>>>>> the same as the map coodinate system.
>>>>>>>>>> Please comment on what happend when you attempted my previous
>>>>>>>>>> suggestions.
>>>>>>>>>>> Hi Kenneth,
>>>>>>>>>>> Thanks for ur suggestions.
>>>>>>>>>>> I have created a package using OGR provider but in the buffering
>>>>>>>>>>> i
>>>>>>>>>>> found
>>>>>>>>>>> some problem that
>>>>>>>>>>> // exclude layer if:
>>>>>>>>>>> // the map is non-arbitrary and the layer is
>>>>>>>>>>> arbitrary
>>>>>>>>>>> or
>>>>>>>>>>> vice-versa
>>>>>>>>>>> // or
>>>>>>>>>>> // layer and map are both arbitrary but have
>>>>>>>>>>> different
>>>>>>>>>>> units
>>>>>>>>>>> (arbitraryDsSrs
>>>>>>>>>>> (dsSrsUnits != mapSrsUnits)))
>>>>>>>>>>> excludedLayers++;
>>>>>>>>>>> continue;
>>>>>>>>>>> it gives difference to my data and sheboygan sample data
>>>>>>>>>>> so that in my code excludedLayers is incremented to 1 so i didnt
>>>>>>>>>>> get
>>>>>>>>>>> the
>>>>>>>>>>> buffer features
>>>>>>>>>>> can u plz tell me the solution?????????????????
>>>>>>>>>>> Regards,
>>>>>>>>>>> Padmini.
>>>>>>>>>>>> I'm not sure that provider is case insensitive.
>>>>>>>>>>>> Try adding the file again, but with the name "PROPERTIES.shp".
>>>>>>>>>>>> Also, try creating a folder, and place the files in the folder.
>>>>>>>>>>>> Then try to use the "External files" and point to the folder.
>>>>>>>>>>>> Also try pointing directly to the file.
>>>>>>>>>>>> When the "Test connection" is successfull, try clicking the
>>>>>>>>>>>> rightmost button in the "coordinate system override" field, and
>>>>>>>>>>>> it will show you what the provider returns as the coordinate
>>>>>>>>>>>> system.
>>>>>>>>>>>> Alternatively, try using the OGR provider instead of the SHP
>>>>>>>>>>>> provider.
>>>>>>>>>>>>> Hi Keneneth,
>>>>>>>>>>>>> First of all thanks for ur patience
>>>>>>>>>>>>> i have uploaded all the files but i didnt get the coordinate
>>>>>>>>>>>>> system
>>>>>>>>>>>>> http://n2.nabble.com/file/n2676400/file.jpeg
>>>>>>>>>>>>> again i did anything wrong??????????
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>> IIRC Shape files consist of more than just the SHP file.
>>>>>>>>>>>>>> You must upload all the "Properties.*" files to the
>>>>>>>>>>>>>> datasource,
>>>>>>>>>>>>>> even if the upload file dialog is misleading (you must select
>>>>>>>>>>>>>> "All
>>>>>>>>>>>>>> files" to see them).
>>>>>>>>>>>>>> A ticket for this problem is here.
>>>>>>>>>>>>>> http://trac.osgeo.org/mapguide/ticket/783
>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>> but i did it as per ur instruction but it didn't come
>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2676097/over.jpeg
>>>>>>>>>>>>>>> my code as same as previous
>>>>>>>>>>>>>>> MgResourceIdentifier featSourceId = new
>>>>>>>>>>>>>>> MgResourceIdentifier(selLayer.GetFeatureSourceId());
>>>>>>>>>>>>>>> MgSpatialContextReader ctxs =
>>>>>>>>>>>>>>> featureSrvc.GetSpatialContexts(featSourceId, false);
>>>>>>>>>>>>>>> String srsDefDs = "";
>>>>>>>>>>>>>>> if (ctxs != null && ctxs.ReadNext())
>>>>>>>>>>>>>>> srsDefDs = ctxs.GetCoordinateSystemWkt();
>>>>>>>>>>>>>>> in srsDefDs i got null
>>>>>>>>>>>>>>> does i did any thing wrong
>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>> Yes, your FeatureSource reports an empty coordinate system,
>>>>>>>>>>>>>>>> so
>>>>>>>>>>>>>>>> you
>>>>>>>>>>>>>>>> have
>>>>>>>>>>>>>>>> to specify it manually.
>>>>>>>>>>>>>>>> There is a short explanation on how to use overrides here:
>>>>>>>>>>>>>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#OverridingCoordinateSystems
>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>> thanks but is it necessary overriding a coordinate
>>>>>>>>>>>>>>>>> system????????
>>>>>>>>>>>>>>>>> How it willbe done???????
>>>>>>>>>>>>>>>>> can u provide me some guidance???????
>>>>>>>>>>>>>>>>> i have seen ur link but no data available in that for
>>>>>>>>>>>>>>>>> overrides
>>>>>>>>>>>>>>>>> coordinate
>>>>>>>>>>>>>>>>> system
>>>>>>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
>>>>>>>>>>>>>>>>> can u plz tell me????????????
>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>>>> No, I meant "Coordinate System Override", which is located
>>>>>>>>>>>>>>>>>> on
>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>> FeatureSource editor at the bottom.
>>>>>>>>>>>>>>>>>> See screenshots here:
>>>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>>>> Thanks for ur reply
>>>>>>>>>>>>>>>>>>> u man to say in mapdefinition(in maestro)????????????????
>>>>>>>>>>>>>>>>>>> iam using maestro and i have selected the coordinate
>>>>>>>>>>>>>>>>>>> system
>>>>>>>>>>>>>>>>>>> as
>>>>>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2675676/coor.jpeg
>>>>>>>>>>>>>>>>>>> does i did any thing wrong???????????????
>>>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>>>>>> Have you tried to add a coordinate system override,
>>>>>>>>>>>>>>>>>>>> using Maestro or Studio?
>>>>>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS
>>>>>>>>>>>>>>>>>>>>> 5.1)
>>>>>>>>>>>>>>>>>>>>> i want to make a buffer to my data
>>>>>>>>>>>>>>>>>>>>> the buffer function works fine for this sheboygan data
>>>>>>>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>>>>>>>> for
>>>>>>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>>>>>>> data
>>>>>>>>>>>>>>>>>>>>> i have debugged the application and i got the error at
>>>>>>>>>>>>>>>>>>>>> In Sheboygan data
>>>>>>>>>>>>>>>>>>>>> srsDefDs comes as GEOGCS["WGS84 Lat/Long's, Degrees,
>>>>>>>>>>>>>>>>>>>>> -180
>>>>>>>>>>>>>>>>>>>>> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
>>>>>>>>>>>>>>>>>>>>> but for my data
>>>>>>>>>>>>>>>>>>>>> srsDefDs comes as null
>>>>>>>>>>>>>>>>>>>>> Actually my data is in coordinate system
>>>>>>>>>>>>>>>>>>>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>>>>>>>>>>>>>>>>>>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
>>>>>>>>>>>>>>>>>>>>> can u plz tell me the solution????????????????????????
>>>>>>>>>>>>>>>>>>>>> plzzz
>>>>>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>>>>>> Padmini.
>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090506/1241f725/attachment.html
