[mapguide-users] select the location on map
Chris Claydon chris.claydon at autodesk.com
Mon May 4 10:37:39 EDT 2009
It looks like this field <input type="hidden"name="SESSION" value="javascript:Getsession()"/ >
is using the string "javascript:Getsession()" rather than actually calling the method and setting the value to the id that is returned.
If you remove the quotes, what happens then?
Chris.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of susan Daniel
Sent: Sunday, May 03, 2009 10:09 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] select the location on map
hi....
      Still the same error ....
Invalid argument(s): [1] = "javascript:Getsession()" The session ID is invalid because the session separator character was not found.Invalid argument(s): [1] = "javascript:Getsession()" The session ID is invalid because the session separator character was not found. Exception occurred in method MgUserInformation.SetMgSessionId at line 183 in file d:\buildforgeprojects\mapguide_open_source
my code in window.php:
<body>
<script language="javascript"type="javasript/text">
function Getsession()
 document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
function Getmapname()
 document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;
</script>
<form action="selectlocation.php" method="get">
Enter PanId <input type="text" name="PanId"/><br><br>
<input type="hidden"name="MAPNAME" value="javascript:Getmapname()"/  >
<input type="submit" value="Submit" />
</form>
<br><br>
Tf anyone having any idea plsss help.....I tried a lot
thanks&regards
susan
On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov <s.dalakov at mapware.net<mailto:s.dalakov at mapware.net>> wrote:
You could use something like this (executed when window.php is loaded)
Stefan
susan Daniel wrote:
hi..all
      Then what i have to do?Any solution to pass these sessionId and mapname ????
regards
susan
On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov <s.dalakov at mapware.net<mailto:s.dalakov at mapware.net> <mailto:s.dalakov at mapware.net<mailto:s.dalakov at mapware.net>>> wrote:
   These javascript.functions never get executed. I checked now, I
   added some "alert"s  and they didn't show.
   susan Daniel wrote:
   HI..
           I removed that brace but still the error is there
   regards
   susan
   On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
   <jumpinjackie at gmail.com<mailto:jumpinjackie at gmail.com> <mailto:jumpinjackie at gmail.com<mailto:jumpinjackie at gmail.com>>> wrote:
       I see an extra brace (the very first one) in the javascript
       block that could
       be messing everything up.
       - Jackie
       SusanDaniel wrote:
       > hi all
       >         In order to display a form in the task pane i've
       the following
       > code
       > in "....../mapviewerphp/window.php"
       > <body>
       > <script language="javascript">
       > function getsession()
       > sessionId=parent.parent.mapframe.GetSessionId();
       > function getmapname()
       > mapname=parent.parent.mapframe.GetMapName();
       > </script>
       value="javascript:getsession()"/ >
       value="javascript:getmapname()"/  >
       > </form>
       > *and in the selectlocation .php i am having
       >  </head>
       >   <?php $ID= $_GET['PanId'];
       >     ?>.<br />
       >   <body class="AppFrame" onLoad="OnPageLoad()">
       >     <h1 class="AppHeading">Select features</h1>
       >     <?php
       >     include '../common/common.php';
       >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
       $_GET;
       >     $sessionId = $args['SESSION'];
       >     $mapName = $args['MAPNAME'];
       >     try
       >       // Initialize the Web Extensions and connect to the
       Server using
       >       // the Web Extensions session identifier stored in
       PHP session
       > state.
       >       MgInitializeWebTier ($webconfigFilePath);
       >       $userInfo = new MgUserInformation($sessionId);
       >       $siteConnection = new MgSiteConnection();
       >       $siteConnection->Open($userInfo);
       >       $map = new MgMap($siteConnection);
       >       $map->Open($mapName);
       >       // Get the geometry for the boundaries of District 1
       >       $districtQuery = new MgFeatureQueryOptions();
       >       $districtQuery->SetFilter("pan_id==$ID");
       >       $layer = $map->GetLayers()->GetItem('Panchayat');
       >       $featureReader = $layer->SelectFeatures($districtQuery);
       >       $featureReader->ReadNext();
       >       $districtGeometryData = $featureReader->
       >       GetGeometry('Data');
       >       // Convert the AGF binary data to MgGeometry.
       >       $agfReaderWriter = new MgAgfReaderWriter();
       >       $districtGeometry =
       $agfReaderWriter->Read($districtGeometryData);
       >       // Create a filter to select the desired features.
       Combine
       >       // a basic filter and a spatial filter.
       >       $queryOptions = new MgFeatureQueryOptions();
       >       $queryOptions->SetSpatialFilter('SHPGEOM',
       $districtGeometry,
       > MgFeatureSpatialOperations::Inside);
       >       // Get the features from the feature source,
       >       // turn it into a selection, then save the selection
       as XML.
       >       $layer = $map->GetLayers()->GetItem(0);
       >       $featureReader = $layer->SelectFeatures($queryOptions);
       >       $selection = new MgSelection($map);
       >       $selection->AddFeatures($layer, $featureReader, 0);
       >       $selectionXml = $selection->ToXml();
       >     catch (MgException $e)
       >       echo $e->GetMessage();
       >       echo $e->GetDetails();
       >   </body>
       >     function OnPageLoad()
       >       selectionXml = '<?php echo $selectionXml; ?>';
       >       parent.parent.SetSelectionXML(selectionXml);
       >   </script>
       > </body>
       > </html>
       > *This code..But when i enter the panId in the form this
       error is occuring
       >   Invalid argument(s): [1] = "javascript:getsession()" The
       session ID is
       found.Invalid
       > argument(s): [1] = "javascript:getsession()" The session ID
       is invalid
       Exception occurred
       > in
       d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
       > Any mistake in my coding?????
       > Help me plss
       > regards
       > susan
       > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
       > <dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com>
       <mailto:dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com>>>wrote:
       >>  Did you check out the samples in the downloads area of Osgeo?
       >> http://mapguide.osgeo.org/download/releases/2.0.x-samples
       >> Dave
       >> *From:* mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>
       <mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>> [mailto:
       <mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>>] *On Behalf
       Of *Ivan Milicevic
       >> *Sent:* Wednesday, April 22, 2009 1:52 AM
       >> *To:* MapGuide Users Mail List
       >> *Subject:* RE: [mapguide-users] select the location on map
       >> You can get it from some of them. Please, read descritption.
       Of *susan Daniel
       >> *Sent:* Wednesday, April 22, 2009 9:46 AM
       >> *Subject:* Re: [mapguide-users] select the location on map
       >> Thank u....
       >>                Can i get the source code of any of these
       sample
       >> applications? If so from where?
       >> regards
       >> susan
       >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
       >> Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>
       <mailto:Ivan.Milicevic at supranet.hr<mailto:Ivan.Milicevic at supranet.hr>>> wrote:
       >> http://mapguide.osgeo.org/livegallery.html
       Of *susan Daniel
       >> *Sent:* Wednesday, April 22, 2009 8:06 AM
       >> hi deve
       >>            I couldn't find that sample application.Any link?
       >> regards
       >> susan
       >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
       <dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com> <mailto:dave.wilson at autodesk.com<mailto:dave.wilson at autodesk.com>>>
       >> wrote:
       >> The sample application that does the Find Address does a
       selection on the
       >> map when you click on one of the search results. I thought
       this was
       >> discussed in the Sample Application.
       >> Dave
       Of *susan Daniel
       >> *Sent:* Monday, April 20, 2009 12:18 AM
       >> hi alll...........
       >>                   I read the dev guide but didn't get any
       idea regarding
       >> this.Hav anyone tried this before pls give me any hint how
       to start this
       >> thanks &regards
       >> susan
       >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
       >> wrote:
       >> Have you read through the developer's guide? It has sample
       code for
       >> selection and explains many concepts. It sounds like you
       need to make
       >> either
       >> an invoke script or invoke url call from a command in your
       Basic or
       >> Flexible
       >> Web Layout. You don't actually have to replace the
       gettingstarted.php. In
       >> the invoke script or invoke url command allows you to
       specify the target
       >> frame for the output of the script.
       >> Regards,
       >> Dave
       Of *susan Daniel
       >> *Sent:* Friday, April 17, 2009 3:57 AM
       >> yeah...i know that..
       >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
       >> Did you know how to create file that display's database
       table? If you
       >> don't
       >> know that you must find help somewhere else because I'm
       not a PHP guy.
       Of *susan Daniel
       >> *Sent:* Friday, April 17, 2009 11:42 AM
       >> Hi..
       >>     No i dont have the file that displays database
       table...Actually iam
       >> doing this prjct in php.but i know javascript'
       >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
       >> Ok, so you have file that display's data from your
       database table? Or you
       >> don't have it at all? How familiar are you with javascript?
       Of *susan Daniel
       >> *Sent:* Friday, April 17, 2009 11:13 AM
       >> hi...
       >>    My problem is that..
       >>    I have a database table..Having colums  place ,id etc .If i
       >> selected(clicking) a data in the table the corresponding
       place(polygon)
       >> should be displayed(selected) on the map...My map is a
       polygon map .each
       >> polygon having unique id.and the same id is present in the
       db table
       >> also....Now u got it?any idea please help...
       >> regards
       >> susan
       >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
       >> I'm not sure that I understand your problem. With this
       code you can
       >> select
       >> any feature on map. Can you send a little bit more
       information? I'm clues
       >> over there.
       Of *susan Daniel
       >> *Sent:* Friday, April 17, 2009 10:47 AM
       >> thank you  ivan...
       >>                        on which file i have to write this
       coding???  any
       >> idea??
       >> regards
       >> susan
       >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
       >> OBJEKTI is layer name and other thing is path to the
       feature source.
       >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
       >> You can copy/paste feature source from mapguide maestro in
       layer
       >> definition
       >> window.
       Of *susan Daniel
       >> *Sent:* Friday, April 17, 2009 9:45 AM
       >> thank you Ivan
       >> but  i 'd like to know on which file i want to write this
       coding??
       >> In ur coding OBJEKT1  is layer name right?then what is this
       >> "Library://PROJEKTI/" + TIMgisUser +
       "/PODACI/OBJEKTI.FeatureSource");
       >> thanks and regards
       >> susan
       >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
       >> Hello Susan,
       >> Here is C# code for selection, it's pretty same as PHP.
       >> MgSiteConnection siteConnection = null;
       >>     InitializeWebTier();
       >>     MgUserInformation userInfo = new
       MgUserInformation(mgSessionId);
       >>     siteConnection.Open(userInfo);
       >>     MgResourceService resourceService =
       siteConnection.CreateService(
       >> MgServiceType.ResourceService) as MgResourceService;
       >>     MgFeatureService featureService =
       >> MgServiceType.FeatureService) as MgFeatureService;
       >>     MgMap map = new MgMap();
       >>     map.Open(resourceService, "1"); //opening map with
       name "1"
       >>     MgFeatureQueryOptions queryOptionsObjekti = new
       >>     MgAgfReaderWriter geometryReaderWriter = new
       >>     MgSelection selection = new MgSelection(map);
       >>     //Defining layer and feature source
       >>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
       >>     MgResourceIdentifier featureResIdObjekti = new
       MgResourceIdentifier(
       >>     //Creating feature filter, this is very important step!
       >>     string filter = "ID=" + idO;
       >>     queryOptionsObjekti.SetFilter(filter);
       >>     MgFeatureReader featureReaderObjekti =
       featureService.SelectFeatures(
       >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
       >>     selection.AddFeatures(layerObjekti,
       featureReaderObjekti, 1);
       >>     selection.Save(resourceService, "1");
       >>     StringReader stream = new StringReader(selection.ToXml());
       >>     string selectionXml = selection.ToXml();
       >>     featureReaderObjekti.Close();
       >>     map.Save();
       >>     //Here, you call javascript function and pass the
       selection var
       >>     Response.Write("<script>select('" + selectionXml +
       "');</script>");
       >> //This is javascript function that set's the selection
       from code and do
       >> the
       >> refresh.
       >> function select(xml)
       >> parent.mapFrame.SetSelectionXML(xml);
       >> parent.mapFrame.ExecuteMapAction(10);
       Of *susan Daniel
       >> *Sent:* Friday, April 17, 2009 9:11 AM
       >> *To:* mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
       <mailto:mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>>
       >> *Subject:* [mapguide-users] select the location on map
       >> hi all
       >>         My plat form is mapguide maestro&php.I connect it
       with mysql.Now
       >> i
       >> want to select the corresponding polygon on the map while
       clicking on the
       >> data in database.In order to display the database table in
       the taskpane,i
       >> removed the contents of the file "/mapviewerphp/getting
       started .php" and
       >> wrote my codings.then how to select the polygon?.Any one know
       >> this????Anyone
       >> having coding to do this???
       >> please help me
       >> thanks&regards
       >>  susan
       >> mapguide-users mailing list
       >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
       >> thanks&regards
       >>  susan
       >> thanks&regards
       >>  susan
       >> thanks&regards
       >>  susan
       >> thanks&regards
       >>  susan
       >> thanks&regards
       >>  susan
       >> thanks&regards
       >>  susan
       >> thanks&regards
       >>  susan
       >> thanks&regards
       >>  susan
       > thanks&regards
       >  susan
       View this message in context:
       http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
   --    thanks&regards
    susan
   _______________________________________________ mapguide-users
   mailing list mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
   mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org> <mailto:mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>>
thanks&regards
 susan
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090504/dfef17ea/attachment.html
