[mapguide-users] select the location on map
susan Daniel daniel.susan6 at gmail.com
Tue May 5 00:39:40 EDT 2009
hi chris
         I removed that quotes .but the same error occurred..Anyone know any
other method to pass this SessionId &mapname???
help me plsssss
regards
susan
On Mon, May 4, 2009 at 8:07 PM, Chris Claydon <chris.claydon at autodesk.com>wrote:
>  It looks like this field *<input type="hidden"name="SESSION"
> value="javascript:Getsession()"/ >
> *is using the string “javascript:Getsession()” rather than actually
> calling the method and setting the value to the id that is returned.
> If you remove the quotes, what happens then?
> Chris.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *susan Daniel
> *Sent:* Sunday, May 03, 2009 10:09 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] select the location on map
> hi....
>       *Still the same error ....*
> Invalid argument(s): [1] = "javascript:Getsession()" The session ID is
> invalid because the session separator character was not found.Invalid
> argument(s): [1] = "javascript:Getsession()" The session ID is invalid
> because the session separator character was not found. Exception occurred in
> method MgUserInformation.SetMgSessionId at line 183 in file
> d:\buildforgeprojects\mapguide_open_source
> *my code in window.php:
> <body>
> <script language="javascript"type="javasript/text">
> function Getsession()
>  document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
> function Getmapname()
>  document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;
> </script>
> <form action="selectlocation.php" method="get">
> Enter PanId <input type="text" name="PanId"/><br><br>
> <input type="hidden"name="SESSION" value="javascript:Getsession()"/ >
> <input type="hidden"name="MAPNAME" value="javascript:Getmapname()"/  >
> <input type="submit" value="Submit" />
> </form>
> <br><br>
> Tf anyone having any idea plsss help.....I tried a lot
> thanks&regards
> susan
>  On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov <s.dalakov at mapware.net>
> wrote:
> You could use something like this (executed when window.php is loaded)
> Stefan
> susan Daniel wrote:
> hi..all
>       Then what i have to do?Any solution to pass these sessionId and
> mapname ????
> regards
> susan
> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov <s.dalakov at mapware.net<mailto:
> s.dalakov at mapware.net>> wrote:
>    These javascript.functions never get executed. I checked now, I
>    added some "alert"s  and they didn't show.
>    susan Daniel wrote:
>     HI..
>            I removed that brace but still the error is there
>    regards
>    susan
>    On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
>    <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>> wrote:
>        I see an extra brace (the very first one) in the javascript
>        block that could
>        be messing everything up.
>        - Jackie
>        SusanDaniel wrote:
>        > hi all
>        >         In order to display a form in the task pane i've
>        the following
>        > code
>        > in "....../mapviewerphp/window.php"
>        > <body>
>        > <script language="javascript">
>        > function getsession()
>        > sessionId=parent.parent.mapframe.GetSessionId();
>        > function getmapname()
>        > mapname=parent.parent.mapframe.GetMapName();
>        > </script>
>        value="javascript:getsession()"/ >
>        value="javascript:getmapname()"/  >
>        > </form>
>        > *and in the selectlocation .php i am having
>        >  </head>
>        >   <?php $ID= $_GET['PanId'];
>        >     ?>.<br />
>        >   <body class="AppFrame" onLoad="OnPageLoad()">
>        >     <h1 class="AppHeading">Select features</h1>
>        >     <?php
>        >     include '../common/common.php';
>        >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
>        $_GET;
>        >     $sessionId = $args['SESSION'];
>        >     $mapName = $args['MAPNAME'];
>        >     try
>        >       // Initialize the Web Extensions and connect to the
>        Server using
>        >       // the Web Extensions session identifier stored in
>        PHP session
>        > state.
>        >       MgInitializeWebTier ($webconfigFilePath);
>        >       $userInfo = new MgUserInformation($sessionId);
>        >       $siteConnection = new MgSiteConnection();
>        >       $siteConnection->Open($userInfo);
>        >       $map = new MgMap($siteConnection);
>        >       $map->Open($mapName);
>        >       // Get the geometry for the boundaries of District 1
>        >       $districtQuery = new MgFeatureQueryOptions();
>        >       $districtQuery->SetFilter("pan_id==$ID");
>        >       $layer = $map->GetLayers()->GetItem('Panchayat');
>        >       $featureReader = $layer->SelectFeatures($districtQuery);
>        >       $featureReader->ReadNext();
>        >       $districtGeometryData = $featureReader->
>        >       GetGeometry('Data');
>        >       // Convert the AGF binary data to MgGeometry.
>        >       $agfReaderWriter = new MgAgfReaderWriter();
>        >       $districtGeometry =
>        $agfReaderWriter->Read($districtGeometryData);
>        >       // Create a filter to select the desired features.
>        Combine
>        >       // a basic filter and a spatial filter.
>        >       $queryOptions = new MgFeatureQueryOptions();
>        >       $queryOptions->SetSpatialFilter('SHPGEOM',
>        $districtGeometry,
>        > MgFeatureSpatialOperations::Inside);
>        >       // Get the features from the feature source,
>        >       // turn it into a selection, then save the selection
>        as XML.
>        >       $layer = $map->GetLayers()->GetItem(0);
>        >       $featureReader = $layer->SelectFeatures($queryOptions);
>        >       $selection = new MgSelection($map);
>        >       $selection->AddFeatures($layer, $featureReader, 0);
>        >       $selectionXml = $selection->ToXml();
>        >     catch (MgException $e)
>        >       echo $e->GetMessage();
>        >       echo $e->GetDetails();
>        >   </body>
>        >     function OnPageLoad()
>        >       selectionXml = '<?php echo $selectionXml; ?>';
>        >       parent.parent.SetSelectionXML(selectionXml);
>        >   </script>
>        > </body>
>        > </html>
>        > *This code..But when i enter the panId in the form this
>        error is occuring
>        >   Invalid argument(s): [1] = "javascript:getsession()" The
>        session ID is
>        found.Invalid
>        > argument(s): [1] = "javascript:getsession()" The session ID
>        is invalid
>        Exception occurred
>        > in
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
>        > Any mistake in my coding?????
>        > Help me plss
>        > regards
>        > susan
>        > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
>        > <dave.wilson at autodesk.com
>        <mailto:dave.wilson at autodesk.com>>wrote:
>        >>  Did you check out the samples in the downloads area of Osgeo?
>        >> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>        >> Dave
>        <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:
>        <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf
>        Of *Ivan Milicevic
>        >> *Sent:* Wednesday, April 22, 2009 1:52 AM
>        >> *Subject:* RE: [mapguide-users] select the location on map
>        >> You can get it from some of them. Please, read descritption.
>        Of *susan Daniel
>        >> *Sent:* Wednesday, April 22, 2009 9:46 AM
>        >> Thank u....
>        >>                Can i get the source code of any of these
>        sample
>        >> applications? If so from where?
>        >> regards
>        >> susan
>        >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
>        >> Ivan.Milicevic at supranet.hr
>        <mailto:Ivan.Milicevic at supranet.hr>> wrote:
>        >> http://mapguide.osgeo.org/livegallery.html
>        Of *susan Daniel
>        >> *Sent:* Wednesday, April 22, 2009 8:06 AM
>        >> hi deve
>        >>            I couldn't find that sample application.Any link?
>        >> regards
>        >> susan
>        >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
>        <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com>>
>        >> wrote:
>        >> The sample application that does the Find Address does a
>        selection on the
>        >> map when you click on one of the search results. I thought
>        this was
>        >> discussed in the Sample Application.
>        >> Dave
>        Of *susan Daniel
>        >> *Sent:* Monday, April 20, 2009 12:18 AM
>        >> hi alll...........
>        >>                   I read the dev guide but didn't get any
>        idea regarding
>        >> this.Hav anyone tried this before pls give me any hint how
>        to start this
>        >> thanks &regards
>        >> susan
>        >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>        >> wrote:
>        >> Have you read through the developer’s guide? It has sample
>        code for
>        >> selection and explains many concepts. It sounds like you
>        need to make
>        >> either
>        >> an invoke script or invoke url call from a command in your
>        Basic or
>        >> Flexible
>        >> Web Layout. You don’t actually have to replace the
>        gettingstarted.php. In
>        >> the invoke script or invoke url command allows you to
>        specify the target
>        >> frame for the output of the script.
>        >> Regards,
>        >> Dave
>        Of *susan Daniel
>        >> *Sent:* Friday, April 17, 2009 3:57 AM
>        >> yeah...i know that..
>        >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
>        >> Did you know how to create file that display's database
>        table? If you
>        >> don't
>        >> know that you must find help somewhere else because I'm
>        not a PHP guy.
>        Of *susan Daniel
>        >> *Sent:* Friday, April 17, 2009 11:42 AM
>        >> Hi..
>        >>     No i dont have the file that displays database
>        table...Actually iam
>        >> doing this prjct in php.but i know javascript'
>        >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
>        >> Ok, so you have file that display's data from your
>        database table? Or you
>        >> don't have it at all? How familiar are you with javascript?
>        Of *susan Daniel
>        >> *Sent:* Friday, April 17, 2009 11:13 AM
>        >> hi...
>        >>    My problem is that..
>        >>    I have a database table..Having colums  place ,id etc .If i
>        >> selected(clicking) a data in the table the corresponding
>        place(polygon)
>        >> should be displayed(selected) on the map...My map is a
>        polygon map .each
>        >> polygon having unique id.and the same id is present in the
>        db table
>        >> also....Now u got it?any idea please help...
>        >> regards
>        >> susan
>        >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
>        >> I'm not sure that I understand your problem. With this
>        code you can
>        >> select
>        >> any feature on map. Can you send a little bit more
>        information? I'm clues
>        >> over there.
>        Of *susan Daniel
>        >> *Sent:* Friday, April 17, 2009 10:47 AM
>        >> thank you  ivan...
>        >>                        on which file i have to write this
>        coding???  any
>        >> idea??
>        >> regards
>        >> susan
>        >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
>        >> OBJEKTI is layer name and other thing is path to the
>        feature source.
>        >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>        >> You can copy/paste feature source from mapguide maestro in
>        layer
>        >> definition
>        >> window.
>        Of *susan Daniel
>        >> *Sent:* Friday, April 17, 2009 9:45 AM
>        >> thank you Ivan
>        >> but  i 'd like to know on which file i want to write this
>        coding??
>        >> In ur coding OBJEKT1  is layer name right?then what is this
>        >> "Library://PROJEKTI/" + TIMgisUser +
>        "/PODACI/OBJEKTI.FeatureSource");
>        >> thanks and regards
>        >> susan
>        >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
>        >> Hello Susan,
>        >> Here is C# code for selection, it's pretty same as PHP.
>        >> MgSiteConnection siteConnection = null;
>        >>     InitializeWebTier();
>        >>     MgUserInformation userInfo = new
>        MgUserInformation(mgSessionId);
>        >>     siteConnection.Open(userInfo);
>        >>     MgResourceService resourceService =
>        siteConnection.CreateService(
>        >> MgServiceType.ResourceService) as MgResourceService;
>        >>     MgFeatureService featureService =
>        >> MgServiceType.FeatureService) as MgFeatureService;
>        >>     MgMap map = new MgMap();
>        >>     map.Open(resourceService, "1"); //opening map with
>        name „1“
>        >>     MgFeatureQueryOptions queryOptionsObjekti = new
>        >>     MgAgfReaderWriter geometryReaderWriter = new
>        >>     MgSelection selection = new MgSelection(map);
>        >>     //Defining layer and feature source
>        >>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>        >>     MgResourceIdentifier featureResIdObjekti = new
>        MgResourceIdentifier(
>        >>     //Creating feature filter, this is very important step!
>        >>     string filter = "ID=" + idO;
>        >>     queryOptionsObjekti.SetFilter(filter);
>        >>     MgFeatureReader featureReaderObjekti =
>        featureService.SelectFeatures(
>        >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>        >>     selection.AddFeatures(layerObjekti,
>        featureReaderObjekti, 1);
>        >>     selection.Save(resourceService, "1");
>        >>     StringReader stream = new StringReader(selection.ToXml());
>        >>     string selectionXml = selection.ToXml();
>        >>     featureReaderObjekti.Close();
>        >>     map.Save();
>        >>     //Here, you call javascript function and pass the
>        selection var
>        >>     Response.Write("<script>select('" + selectionXml +
>        "');</script>");
>        >> //This is javascript function that set's the selection
>        from code and do
>        >> the
>        >> refresh.
>        >> function select(xml)
>        >> parent.mapFrame.SetSelectionXML(xml);
>        >> parent.mapFrame.ExecuteMapAction(10);
>        Of *susan Daniel
>        >> *Sent:* Friday, April 17, 2009 9:11 AM
>        >> *To:* mapguide-users at lists.osgeo.org
>        <mailto:mapguide-users at lists.osgeo.org>
>        >> *Subject:* [mapguide-users] select the location on map
>        >> hi all
>        >>         My plat form is mapguide maestro&php.I connect it
>        with mysql.Now
>        >> i
>        >> want to select the corresponding polygon on the map while
>        clicking on the
>        >> data in database.In order to display the database table in
>        the taskpane,i
>        >> removed the contents of the file "/mapviewerphp/getting
>        started .php" and
>        >> wrote my codings.then how to select the polygon?.Any one know
>        >> this????Anyone
>        >> having coding to do this???
>        >> please help me
>        >> thanks&regards
>        >>  susan
>        >> _______________________________________________
>        >> mapguide-users mailing list
>        >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>        >> thanks&regards
>        >>  susan
>        >> thanks&regards
>        >>  susan
>        >> thanks&regards
>        >>  susan
>        >> thanks&regards
>        >>  susan
>        >> thanks&regards
>        >>  susan
>        >> thanks&regards
>        >>  susan
>        >> thanks&regards
>        >>  susan
>        >> thanks&regards
>        >>  susan
>        > thanks&regards
>        >  susan
>        View this message in context:
> http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
>        Sent from the MapGuide Users mailing list archive at Nabble.com.
>    --    thanks&regards
>     susan
>    _______________________________________________ mapguide-users
>    mailing list mapguide-users at lists.osgeo.org
>    mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> thanks&regards
>  susan
> thanks&regards
>  susan
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090505/c24604a9/attachment.html
