[mapguide-users] select the location on map
Zac Spitzer zac.spitzer at gmail.com
Tue May 5 00:44:06 EDT 2009
quicky n dirty but it should work
<input type="hidden" name="SESSION" id="mg_session" value=""/ >
<script>
	document.getElementById('mg_session').value=Getsession();
</script>
On Tue, May 5, 2009 at 2:39 PM, susan Daniel <daniel.susan6 at gmail.com> wrote:
> hi chris
>          I removed that quotes .but the same error occurred..Anyone know any
> other method to pass this SessionId &mapname???
> help me plsssss
> regards
> susan
> On Mon, May 4, 2009 at 8:07 PM, Chris Claydon <chris.claydon at autodesk.com>
> wrote:
>> It looks like this field <input type="hidden"name="SESSION"
>> value="javascript:Getsession()"/ >
>> is using the string “javascript:Getsession()” rather than actually calling
>> the method and setting the value to the id that is returned.
>> If you remove the quotes, what happens then?
>> Chris.
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of susan Daniel
>> Sent: Sunday, May 03, 2009 10:09 PM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] select the location on map
>> hi....
>>       Still the same error ....
>> Invalid argument(s): [1] = "javascript:Getsession()" The session ID is
>> invalid because the session separator character was not found.Invalid
>> argument(s): [1] = "javascript:Getsession()" The session ID is invalid
>> because the session separator character was not found. Exception occurred in
>> method MgUserInformation.SetMgSessionId at line 183 in file
>> d:\buildforgeprojects\mapguide_open_source
>> my code in window.php:
>> <body>
>> <script language="javascript"type="javasript/text">
>> function Getsession()
>>  document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
>> function Getmapname()
>>  document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;
>> </script>
>> <form action="selectlocation.php" method="get">
>> Enter PanId <input type="text" name="PanId"/><br><br>
>> <input type="hidden"name="SESSION" value="javascript:Getsession()"/ >
>> <input type="hidden"name="MAPNAME" value="javascript:Getmapname()"/  >
>> <input type="submit" value="Submit" />
>> </form>
>> <br><br>
>> Tf anyone having any idea plsss help.....I tried a lot
>> thanks&regards
>> susan
>> On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov <s.dalakov at mapware.net>
>> wrote:
>> You could use something like this (executed when window.php is loaded)
>> Stefan
>> susan Daniel wrote:
>> hi..all
>>       Then what i have to do?Any solution to pass these sessionId and
>> mapname ????
>> regards
>> susan
>> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov <s.dalakov at mapware.net
>> <mailto:s.dalakov at mapware.net>> wrote:
>>    These javascript.functions never get executed. I checked now, I
>>    added some "alert"s  and they didn't show.
>>    susan Daniel wrote:
>>    HI..
>>            I removed that brace but still the error is there
>>    regards
>>    susan
>>    On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
>>    <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>> wrote:
>>        I see an extra brace (the very first one) in the javascript
>>        block that could
>>        be messing everything up.
>>        - Jackie
>>        SusanDaniel wrote:
>>        > hi all
>>        >         In order to display a form in the task pane i've
>>        the following
>>        > code
>>        > in "....../mapviewerphp/window.php"
>>        > <body>
>>        > <script language="javascript">
>>        > function getsession()
>>        > sessionId=parent.parent.mapframe.GetSessionId();
>>        > function getmapname()
>>        > mapname=parent.parent.mapframe.GetMapName();
>>        > </script>
>>        > <form action="selectlocation.php" method="get">
>>        > Enter PanId <input type="text" name="PanId"/><br><br>
>>        > <input type="hidden"name="SESSION"
>>        value="javascript:getsession()"/ >
>>        > <input type="hidden"name="MAPNAME"
>>        value="javascript:getmapname()"/  >
>>        > <input type="submit" value="Submit" />
>>        > </form>
>>        > *and in the selectlocation .php i am having
>>        >  </head>
>>        >   <?php $ID= $_GET['PanId'];
>>        >     ?>.<br />
>>        >   <body class="AppFrame" onLoad="OnPageLoad()">
>>        >     <h1 class="AppHeading">Select features</h1>
>>        >     <?php
>>        >     include '../common/common.php';
>>        >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
>>        $_GET;
>>        >     $sessionId = $args['SESSION'];
>>        >     $mapName = $args['MAPNAME'];
>>        >     try
>>        >       // Initialize the Web Extensions and connect to the
>>        Server using
>>        >       // the Web Extensions session identifier stored in
>>        PHP session
>>        > state.
>>        >       MgInitializeWebTier ($webconfigFilePath);
>>        >       $userInfo = new MgUserInformation($sessionId);
>>        >       $siteConnection = new MgSiteConnection();
>>        >       $siteConnection->Open($userInfo);
>>        >       $map = new MgMap($siteConnection);
>>        >       $map->Open($mapName);
>>        >       // Get the geometry for the boundaries of District 1
>>        >       $districtQuery = new MgFeatureQueryOptions();
>>        >       $districtQuery->SetFilter("pan_id==$ID");
>>        >       $layer = $map->GetLayers()->GetItem('Panchayat');
>>        >       $featureReader = $layer->SelectFeatures($districtQuery);
>>        >       $featureReader->ReadNext();
>>        >       $districtGeometryData = $featureReader->
>>        >       GetGeometry('Data');
>>        >       // Convert the AGF binary data to MgGeometry.
>>        >       $agfReaderWriter = new MgAgfReaderWriter();
>>        >       $districtGeometry =
>>        $agfReaderWriter->Read($districtGeometryData);
>>        >       // Create a filter to select the desired features.
>>        Combine
>>        >       // a basic filter and a spatial filter.
>>        >       $queryOptions = new MgFeatureQueryOptions();
>>        >       $queryOptions->SetSpatialFilter('SHPGEOM',
>>        $districtGeometry,
>>        > MgFeatureSpatialOperations::Inside);
>>        >       // Get the features from the feature source,
>>        >       // turn it into a selection, then save the selection
>>        as XML.
>>        >       $layer = $map->GetLayers()->GetItem(0);
>>        >       $featureReader = $layer->SelectFeatures($queryOptions);
>>        >       $selection = new MgSelection($map);
>>        >       $selection->AddFeatures($layer, $featureReader, 0);
>>        >       $selectionXml = $selection->ToXml();
>>        >     catch (MgException $e)
>>        >       echo $e->GetMessage();
>>        >       echo $e->GetDetails();
>>        >   </body>
>>        >     function OnPageLoad()
>>        >       selectionXml = '<?php echo $selectionXml; ?>';
>>        >       parent.parent.SetSelectionXML(selectionXml);
>>        >   </script>
>>        > </body>
>>        > </html>
>>        > *This code..But when i enter the panId in the form this
>>        error is occuring
>>        >   Invalid argument(s): [1] = "javascript:getsession()" The
>>        session ID is
>>        > invalid because the session separator character was not
>>        found.Invalid
>>        > argument(s): [1] = "javascript:getsession()" The session ID
>>        is invalid
>>        > because the session separator character was not found.
>>        Exception occurred
>>        > in
>>        > method MgUserInformation.SetMgSessionId at line 183 in file
>>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
>>        > Any mistake in my coding?????
>>        > Help me plss
>>        > regards
>>        > susan
>>        > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
>>        > <dave.wilson at autodesk.com
>>        <mailto:dave.wilson at autodesk.com>>wrote:
>>        >>  Did you check out the samples in the downloads area of Osgeo?
>>        >> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>>        >> Dave
>>        >> *From:* mapguide-users-bounces at lists.osgeo.org
>>        <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:
>>        >> mapguide-users-bounces at lists.osgeo.org
>>        <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf
>>        Of *Ivan Milicevic
>>        >> *Sent:* Wednesday, April 22, 2009 1:52 AM
>>        >> *To:* MapGuide Users Mail List
>>        >> *Subject:* RE: [mapguide-users] select the location on map
>>        >> You can get it from some of them. Please, read descritption.
>>        Of *susan Daniel
>>        >> *Sent:* Wednesday, April 22, 2009 9:46 AM
>>        >> *Subject:* Re: [mapguide-users] select the location on map
>>        >> Thank u....
>>        >>                Can i get the source code of any of these
>>        sample
>>        >> applications? If so from where?
>>        >> regards
>>        >> susan
>>        >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
>>        >> Ivan.Milicevic at supranet.hr
>>        <mailto:Ivan.Milicevic at supranet.hr>> wrote:
>>        >> http://mapguide.osgeo.org/livegallery.html
>>        Of *susan Daniel
>>        >> *Sent:* Wednesday, April 22, 2009 8:06 AM
>>        >> hi deve
>>        >>            I couldn't find that sample application.Any link?
>>        >> regards
>>        >> susan
>>        >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
>>        <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com>>
>>        >> wrote:
>>        >> The sample application that does the Find Address does a
>>        selection on the
>>        >> map when you click on one of the search results. I thought
>>        this was
>>        >> discussed in the Sample Application.
>>        >> Dave
>>        Of *susan Daniel
>>        >> *Sent:* Monday, April 20, 2009 12:18 AM
>>        >> hi alll...........
>>        >>                   I read the dev guide but didn't get any
>>        idea regarding
>>        >> this.Hav anyone tried this before pls give me any hint how
>>        to start this
>>        >> thanks &regards
>>        >> susan
>>        >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>>        >> wrote:
>>        >> Have you read through the developer’s guide? It has sample
>>        code for
>>        >> selection and explains many concepts. It sounds like you
>>        need to make
>>        >> either
>>        >> an invoke script or invoke url call from a command in your
>>        Basic or
>>        >> Flexible
>>        >> Web Layout. You don’t actually have to replace the
>>        gettingstarted.php. In
>>        >> the invoke script or invoke url command allows you to
>>        specify the target
>>        >> frame for the output of the script.
>>        >> Regards,
>>        >> Dave
>>        Of *susan Daniel
>>        >> *Sent:* Friday, April 17, 2009 3:57 AM
>>        >> yeah...i know that..
>>        >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
>>        >> Did you know how to create file that display's database
>>        table? If you
>>        >> don't
>>        >> know that you must find help somewhere else because I'm
>>        not a PHP guy.
>>        Of *susan Daniel
>>        >> *Sent:* Friday, April 17, 2009 11:42 AM
>>        >> Hi..
>>        >>     No i dont have the file that displays database
>>        table...Actually iam
>>        >> doing this prjct in php.but i know javascript'
>>        >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
>>        >> Ok, so you have file that display's data from your
>>        database table? Or you
>>        >> don't have it at all? How familiar are you with javascript?
>>        Of *susan Daniel
>>        >> *Sent:* Friday, April 17, 2009 11:13 AM
>>        >> hi...
>>        >>    My problem is that..
>>        >>    I have a database table..Having colums  place ,id etc .If i
>>        >> selected(clicking) a data in the table the corresponding
>>        place(polygon)
>>        >> should be displayed(selected) on the map...My map is a
>>        polygon map .each
>>        >> polygon having unique id.and the same id is present in the
>>        db table
>>        >> also....Now u got it?any idea please help...
>>        >> regards
>>        >> susan
>>        >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
>>        >> I'm not sure that I understand your problem. With this
>>        code you can
>>        >> select
>>        >> any feature on map. Can you send a little bit more
>>        information? I'm clues
>>        >> over there.
>>        Of *susan Daniel
>>        >> *Sent:* Friday, April 17, 2009 10:47 AM
>>        >> thank you  ivan...
>>        >>                        on which file i have to write this
>>        coding???  any
>>        >> idea??
>>        >> regards
>>        >> susan
>>        >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
>>        >> OBJEKTI is layer name and other thing is path to the
>>        feature source.
>>        >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>>        >> You can copy/paste feature source from mapguide maestro in
>>        layer
>>        >> definition
>>        >> window.
>>        Of *susan Daniel
>>        >> *Sent:* Friday, April 17, 2009 9:45 AM
>>        >> thank you Ivan
>>        >> but  i 'd like to know on which file i want to write this
>>        coding??
>>        >> In ur coding OBJEKT1  is layer name right?then what is this
>>        >> "Library://PROJEKTI/" + TIMgisUser +
>>        "/PODACI/OBJEKTI.FeatureSource");
>>        >> thanks and regards
>>        >> susan
>>        >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
>>        >> Hello Susan,
>>        >> Here is C# code for selection, it's pretty same as PHP.
>>        >> MgSiteConnection siteConnection = null;
>>        >>     InitializeWebTier();
>>        >>     MgUserInformation userInfo = new
>>        MgUserInformation(mgSessionId);
>>        >>     siteConnection = new MgSiteConnection();
>>        >>     siteConnection.Open(userInfo);
>>        >>     MgResourceService resourceService =
>>        siteConnection.CreateService(
>>        >> MgServiceType.ResourceService) as MgResourceService;
>>        >>     MgFeatureService featureService =
>>        >> MgServiceType.FeatureService) as MgFeatureService;
>>        >>     MgMap map = new MgMap();
>>        >>     map.Open(resourceService, "1"); //opening map with
>>        name „1“
>>        >>     MgFeatureQueryOptions queryOptionsObjekti = new
>>        >>     MgAgfReaderWriter geometryReaderWriter = new
>>        >>     MgSelection selection = new MgSelection(map);
>>        >>     //Defining layer and feature source
>>        >>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>>        >>     MgResourceIdentifier featureResIdObjekti = new
>>        MgResourceIdentifier(
>>        >>     //Creating feature filter, this is very important step!
>>        >>     string filter = "ID=" + idO;
>>        >>     queryOptionsObjekti.SetFilter(filter);
>>        >>     MgFeatureReader featureReaderObjekti =
>>        featureService.SelectFeatures(
>>        >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>>        >>     selection.AddFeatures(layerObjekti,
>>        featureReaderObjekti, 1);
>>        >>     selection.Save(resourceService, "1");
>>        >>     StringReader stream = new StringReader(selection.ToXml());
>>        >>     string selectionXml = selection.ToXml();
>>        >>     featureReaderObjekti.Close();
>>        >>     map.Save();
>>        >>     //Here, you call javascript function and pass the
>>        selection var
>>        >>     Response.Write("<script>select('" + selectionXml +
>>        "');</script>");
>>        >> //This is javascript function that set's the selection
>>        from code and do
>>        >> the
>>        >> refresh.
>>        >> function select(xml)
>>        >> parent.mapFrame.SetSelectionXML(xml);
>>        >> parent.mapFrame.ExecuteMapAction(10);
>>        Of *susan Daniel
>>        >> *Sent:* Friday, April 17, 2009 9:11 AM
>>        >> *To:* mapguide-users at lists.osgeo.org
>>        <mailto:mapguide-users at lists.osgeo.org>
>>        >> *Subject:* [mapguide-users] select the location on map
>>        >> hi all
>>        >>         My plat form is mapguide maestro&php.I connect it
>>        with mysql.Now
>>        >> i
>>        >> want to select the corresponding polygon on the map while
>>        clicking on the
>>        >> data in database.In order to display the database table in
>>        the taskpane,i
>>        >> removed the contents of the file "/mapviewerphp/getting
>>        started .php" and
>>        >> wrote my codings.then how to select the polygon?.Any one know
>>        >> this????Anyone
>>        >> having coding to do this???
>>        >> please help me
>>        >> thanks&regards
>>        >>  susan
>>        >> _______________________________________________
>>        >> mapguide-users mailing list
>>        >> mapguide-users at lists.osgeo.org
>>        >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>        >> thanks&regards
>>        >>  susan
>>        >> thanks&regards
>>        >>  susan
>>        >> thanks&regards
>>        >>  susan
>>        >> thanks&regards
>>        >>  susan
>>        >> thanks&regards
>>        >>  susan
>>        >> thanks&regards
>>        >>  susan
>>        >> thanks&regards
>>        >>  susan
>>        >> thanks&regards
>>        >>  susan
>>        > thanks&regards
>>        >  susan
>>        View this message in context:
>>  http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
>>        Sent from the MapGuide Users mailing list archive at Nabble.com.
>>    --    thanks&regards
>>     susan
>>    _______________________________________________ mapguide-users
>>    mailing list mapguide-users at lists.osgeo.org
>>    mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>> thanks&regards
>>  susan
>> thanks&regards
>>  susan
> thanks&regards
>  susan
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
