[mapguide-users] select the location on map
susan Daniel
daniel.susan6 at gmail.com
Tue May 5 01:02:57 EDT 2009
hi zac...
It is also not working......
This is the code
*<body> *
*<script>
document.getElementById('mg_session').value=Getsession();
</script>
*<form action="selectlocation.php" method="get">
Enter PanId <input type="text" name="PanId"/><br><br>
<input type="hidden" name="SESSION" id="mg_session" value=""/ >
<input type="submit" value="Submit" />
</form>
and in selectlocation.php i'm having this code:
<?php $ID= $_GET['PanId'];
?><br />
<body class="AppFrame" onLoad="OnPageLoad()">
<h1 class="AppHeading">Select features</h1>
<?php
include '../common/common.php';
$args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST: $_GET;
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
try
// Initialize the Web Extensions and connect to the Server using
// the Web Extensions session identifier stored in PHP session state.
MgInitializeWebTier ($webconfigFilePath);
$userInfo = new MgUserInformation($sessionId );
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$map = new MgMap($siteConnection);
$map->Open( $mapName );
// Get the geometry for the boundaries of District 1
$districtQuery = new MgFeatureQueryOptions();
$districtQuery->SetFilter("pan_id==$ID");
$layer = $map->GetLayers()->GetItem('Panchayat');
$featureReader = $layer->SelectFeatures($districtQuery);
$featureReader->ReadNext();
$districtGeometryData = $featureReader->
GetGeometry('Data');
// Convert the AGF binary data to MgGeometry.
$agfReaderWriter = new MgAgfReaderWriter();
$districtGeometry = $agfReaderWriter->Read($districtGeometryData);
// Create a filter to select the desired features. Combine
// a basic filter and a spatial filter.
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetSpatialFilter('panchayat', $districtGeometry,
MgFeatureSpatialOperations::Inside);
// Get the features from the feature source,
// turn it into a selection, then save the selection as XML.
$layer = $map->GetLayers()->GetItem(0);
$featureReader = $layer->SelectFeatures($queryOptions);
$selection = new MgSelection($map);
$selection->AddFeatures($layer, $featureReader, 0);
$selectionXml = $selection->ToXml();
catch (MgException $e)
echo $e->GetMessage();
echo $e->GetDetails();
</body>
<script language="javascript">
function OnPageLoad()
selectionXml = '<?php echo $selectionXml; ?>';
parent.parent.SetSelectionXML(selectionXml);
</script>
</body>
</html>
Can u find any error in this?????
regards
susan
On Tue, May 5, 2009 at 10:14 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> quicky n dirty but it should work
> <script>
> </script>
> On Tue, May 5, 2009 at 2:39 PM, susan Daniel <daniel.susan6 at gmail.com>
> wrote:
> > hi chris
> > I removed that quotes .but the same error occurred..Anyone know
> any
> > other method to pass this SessionId &mapname???
> > help me plsssss
> > regards
> > susan
> > On Mon, May 4, 2009 at 8:07 PM, Chris Claydon <
> chris.claydon at autodesk.com>
> > wrote:
> >> It looks like this field <input type="hidden"name="SESSION"
> >> value="javascript:Getsession()"/ >
> >> is using the string “javascript:Getsession()” rather than actually
> calling
> >> the method and setting the value to the id that is returned.
> >> If you remove the quotes, what happens then?
> >> Chris.
> >> From: mapguide-users-bounces at lists.osgeo.org
> >> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of susan
> Daniel
> >> Sent: Sunday, May 03, 2009 10:09 PM
> >> To: MapGuide Users Mail List
> >> Subject: Re: [mapguide-users] select the location on map
> >> hi....
> >> Still the same error ....
> >> Invalid argument(s): [1] = "javascript:Getsession()" The session ID is
> >> invalid because the session separator character was not found.Invalid
> >> argument(s): [1] = "javascript:Getsession()" The session ID is invalid
> >> because the session separator character was not found. Exception
> occurred in
> >> method MgUserInformation.SetMgSessionId at line 183 in file
> >> d:\buildforgeprojects\mapguide_open_source
> >> my code in window.php:
> >> <body>
> >> <script language="javascript"type="javasript/text">
> >> function Getsession()
> >> document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
> >> function Getmapname()
> >> document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;
> >> </script>
> >> <input type="hidden"name="SESSION" value="javascript:Getsession()"/ >
> >> <input type="hidden"name="MAPNAME" value="javascript:Getmapname()"/ >
> >> </form>
> >> <br><br>
> >> Tf anyone having any idea plsss help.....I tried a lot
> >> thanks®ards
> >> susan
> >> On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov <s.dalakov at mapware.net>
> >> wrote:
> >> You could use something like this (executed when window.php is loaded)
> >> Stefan
> >> susan Daniel wrote:
> >> hi..all
> >> Then what i have to do?Any solution to pass these sessionId and
> >> mapname ????
> >> regards
> >> susan
> >> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov <s.dalakov at mapware.net
> >> <mailto:s.dalakov at mapware.net>> wrote:
> >> These javascript.functions never get executed. I checked now, I
> >> added some "alert"s and they didn't show.
> >> susan Daniel wrote:
> >> HI..
> >> I removed that brace but still the error is there
> >> regards
> >> susan
> >> On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
> >> <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>> wrote:
> >> I see an extra brace (the very first one) in the javascript
> >> block that could
> >> be messing everything up.
> >> - Jackie
> >> SusanDaniel wrote:
> >> > hi all
> >> > In order to display a form in the task pane i've
> >> the following
> >> > code
> >> > in "....../mapviewerphp/window.php"
> >> > <body>
> >> > function getsession()
> >> > sessionId=parent.parent.mapframe.GetSessionId();
> >> > function getmapname()
> >> > mapname=parent.parent.mapframe.GetMapName();
> >> > </script>
> >> value="javascript:getsession()"/ >
> >> value="javascript:getmapname()"/ >
> >> > </form>
> >> > *and in the selectlocation .php i am having
> >> > </head>
> >> > ?>.<br />
> >> > <?php
> >> $_GET;
> >> > try
> >> Server using
> >> PHP session
> >> > state.
> >> > $userInfo = new MgUserInformation($sessionId);
> >> > $map->Open($mapName);
> >> > $districtGeometry =
> >> Combine
> >> > $queryOptions->SetSpatialFilter('SHPGEOM',
> >> $districtGeometry,
> >> as XML.
> >> > </body>
> >> > </script>
> >> > </body>
> >> > </html>
> >> > *This code..But when i enter the panId in the form this
> >> error is occuring
> >> > Invalid argument(s): [1] = "javascript:getsession()" The
> >> session ID is
> >> found.Invalid
> >> > argument(s): [1] = "javascript:getsession()" The session ID
> >> is invalid
> >> Exception occurred
> >> > in
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
> >> > Any mistake in my coding?????
> >> > Help me plss
> >> > regards
> >> > susan
> >> > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
> >> > <dave.wilson at autodesk.com
> >> <mailto:dave.wilson at autodesk.com>>wrote:
> >> >> Did you check out the samples in the downloads area of Osgeo?
> >> >> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> >> >> Dave
> >> >> *From:* mapguide-users-bounces at lists.osgeo.org
> >> <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:
> >> <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf
> >> Of *Ivan Milicevic
> >> >> *Sent:* Wednesday, April 22, 2009 1:52 AM
> >> >> *To:* MapGuide Users Mail List
> >> >> *Subject:* RE: [mapguide-users] select the location on map
> >> >> You can get it from some of them. Please, read descritption.
> >> Of *susan Daniel
> >> >> *Sent:* Wednesday, April 22, 2009 9:46 AM
> >> >> *Subject:* Re: [mapguide-users] select the location on map
> >> >> Thank u....
> >> >> Can i get the source code of any of these
> >> sample
> >> >> applications? If so from where?
> >> >> regards
> >> >> susan
> >> >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
> >> >> Ivan.Milicevic at supranet.hr
> >> <mailto:Ivan.Milicevic at supranet.hr>> wrote:
> >> >> http://mapguide.osgeo.org/livegallery.html
> >> Of *susan Daniel
> >> >> *Sent:* Wednesday, April 22, 2009 8:06 AM
> >> >> hi deve
> >> >> I couldn't find that sample application.Any link?
> >> >> regards
> >> >> susan
> >> >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
> >> <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com>>
> >> >> wrote:
> >> >> The sample application that does the Find Address does a
> >> selection on the
> >> >> map when you click on one of the search results. I thought
> >> this was
> >> >> discussed in the Sample Application.
> >> >> Dave
> >> Of *susan Daniel
> >> >> *Sent:* Monday, April 20, 2009 12:18 AM
> >> >> hi alll...........
> >> >> I read the dev guide but didn't get any
> >> idea regarding
> >> >> this.Hav anyone tried this before pls give me any hint how
> >> to start this
> >> >> thanks ®ards
> >> >> susan
> >> >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
> >> >> wrote:
> >> >> Have you read through the developer’s guide? It has sample
> >> code for
> >> >> selection and explains many concepts. It sounds like you
> >> need to make
> >> >> either
> >> >> an invoke script or invoke url call from a command in your
> >> Basic or
> >> >> Flexible
> >> >> Web Layout. You don’t actually have to replace the
> >> gettingstarted.php. In
> >> >> the invoke script or invoke url command allows you to
> >> specify the target
> >> >> frame for the output of the script.
> >> >> Regards,
> >> >> Dave
> >> Of *susan Daniel
> >> >> *Sent:* Friday, April 17, 2009 3:57 AM
> >> >> yeah...i know that..
> >> >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
> >> >> Did you know how to create file that display's database
> >> table? If you
> >> >> don't
> >> >> know that you must find help somewhere else because I'm
> >> not a PHP guy.
> >> Of *susan Daniel
> >> >> *Sent:* Friday, April 17, 2009 11:42 AM
> >> >> Hi..
> >> >> No i dont have the file that displays database
> >> table...Actually iam
> >> >> doing this prjct in php.but i know javascript'
> >> >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
> >> >> Ok, so you have file that display's data from your
> >> database table? Or you
> >> >> don't have it at all? How familiar are you with javascript?
> >> Of *susan Daniel
> >> >> *Sent:* Friday, April 17, 2009 11:13 AM
> >> >> hi...
> >> >> My problem is that..
> >> >> I have a database table..Having colums place ,id etc .If i
> >> >> selected(clicking) a data in the table the corresponding
> >> place(polygon)
> >> >> should be displayed(selected) on the map...My map is a
> >> polygon map .each
> >> >> polygon having unique id.and the same id is present in the
> >> db table
> >> >> also....Now u got it?any idea please help...
> >> >> regards
> >> >> susan
> >> >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
> >> >> I'm not sure that I understand your problem. With this
> >> code you can
> >> >> select
> >> >> any feature on map. Can you send a little bit more
> >> information? I'm clues
> >> >> over there.
> >> Of *susan Daniel
> >> >> *Sent:* Friday, April 17, 2009 10:47 AM
> >> >> thank you ivan...
> >> >> on which file i have to write this
> >> coding??? any
> >> >> idea??
> >> >> regards
> >> >> susan
> >> >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
> >> >> OBJEKTI is layer name and other thing is path to the
> >> feature source.
> >> >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
> >> >> You can copy/paste feature source from mapguide maestro in
> >> layer
> >> >> definition
> >> >> window.
> >> Of *susan Daniel
> >> >> *Sent:* Friday, April 17, 2009 9:45 AM
> >> >> thank you Ivan
> >> >> but i 'd like to know on which file i want to write this
> >> coding??
> >> >> In ur coding OBJEKT1 is layer name right?then what is this
> >> >> "Library://PROJEKTI/" + TIMgisUser +
> >> "/PODACI/OBJEKTI.FeatureSource");
> >> >> thanks and regards
> >> >> susan
> >> >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
> >> >> Hello Susan,
> >> >> Here is C# code for selection, it's pretty same as PHP.
> >> >> MgSiteConnection siteConnection = null;
> >> >> InitializeWebTier();
> >> >> MgUserInformation userInfo = new
> >> MgUserInformation(mgSessionId);
> >> >> siteConnection.Open(userInfo);
> >> >> MgResourceService resourceService =
> >> siteConnection.CreateService(
> >> >> MgServiceType.ResourceService) as MgResourceService;
> >> >> MgFeatureService featureService =
> >> >> MgServiceType.FeatureService) as MgFeatureService;
> >> >> MgMap map = new MgMap();
> >> >> map.Open(resourceService, "1"); //opening map with
> >> name „1“
> >> >> MgFeatureQueryOptions queryOptionsObjekti = new
> >> >> MgAgfReaderWriter geometryReaderWriter = new
> >> >> MgSelection selection = new MgSelection(map);
> >> >> //Defining layer and feature source
> >> >> MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
> >> >> MgResourceIdentifier featureResIdObjekti = new
> >> MgResourceIdentifier(
> >> >> //Creating feature filter, this is very important step!
> >> >> string filter = "ID=" + idO;
> >> >> queryOptionsObjekti.SetFilter(filter);
> >> >> MgFeatureReader featureReaderObjekti =
> >> featureService.SelectFeatures(
> >> >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
> >> >> selection.AddFeatures(layerObjekti,
> >> featureReaderObjekti, 1);
> >> >> selection.Save(resourceService, "1");
> >> >> StringReader stream = new StringReader(selection.ToXml());
> >> >> string selectionXml = selection.ToXml();
> >> >> featureReaderObjekti.Close();
> >> >> map.Save();
> >> >> //Here, you call javascript function and pass the
> >> selection var
> >> >> Response.Write("<script>select('" + selectionXml +
> >> "');</script>");
> >> >> //This is javascript function that set's the selection
> >> from code and do
> >> >> the
> >> >> refresh.
> >> >> function select(xml)
> >> >> parent.mapFrame.SetSelectionXML(xml);
> >> >> parent.mapFrame.ExecuteMapAction(10);
> >> Of *susan Daniel
> >> >> *Sent:* Friday, April 17, 2009 9:11 AM
> >> >> *To:* mapguide-users at lists.osgeo.org
> >> <mailto:mapguide-users at lists.osgeo.org>
> >> >> *Subject:* [mapguide-users] select the location on map
> >> >> hi all
> >> >> My plat form is mapguide maestro&php.I connect it
> >> with mysql.Now
> >> >> i
> >> >> want to select the corresponding polygon on the map while
> >> clicking on the
> >> >> data in database.In order to display the database table in
> >> the taskpane,i
> >> >> removed the contents of the file "/mapviewerphp/getting
> >> started .php" and
> >> >> wrote my codings.then how to select the polygon?.Any one know
> >> >> this????Anyone
> >> >> having coding to do this???
> >> >> please help me
> >> >> thanks®ards
> >> >> susan
> >> >> _______________________________________________
> >> >> mapguide-users mailing list
> >> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> >> thanks®ards
> >> >> susan
> >> >> thanks®ards
> >> >> susan
> >> >> thanks®ards
> >> >> susan
> >> >> thanks®ards
> >> >> susan
> >> >> thanks®ards
> >> >> susan
> >> >> thanks®ards
> >> >> susan
> >> >> thanks®ards
> >> >> susan
> >> >> thanks®ards
> >> >> susan
> >> > thanks®ards
> >> > susan
> >> View this message in context:
> >> http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> -- thanks®ards
> >> susan
> >> _______________________________________________ mapguide-users
> >> mailing list mapguide-users at lists.osgeo.org
> >> mapguide-users at lists.osgeo.org <mailto:
> >> thanks®ards
> >> susan
> >> thanks®ards
> >> susan
> > thanks®ards
> > susan
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
thanks®ards
susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090505/a011e2d2/attachment.html
