[mapguide-users] select the location on map
Zac Spitzer zac.spitzer at gmail.com
Tue May 5 01:40:25 EDT 2009
that looks right
try using fiddler to monitor track what is being passed back up to the server
r u using firefox with firebug?
you could also add an
alert(Getsession());
to make sure the session id is being returned
On Tue, May 5, 2009 at 3:35 PM, susan Daniel <daniel.susan6 at gmail.com> wrote:
> hi......
>              Did u mean like this
> <form action="selectlocation.php" method="GET">
> Enter PanId <input type="text" name="PanId"/><br><br>
> <input type="hidden" name="SESSION" id="mg_session" value=""/ >
> <script language="javascript">
>        document.getElementById('mg_session').value=Getsession();
> </script>
> <input type="submit" value="Submit" />
> </form>
> but still the error is occuring...
> the error is like this
> Invalid argument(s): [1] = "" The session ID is invalid because the session
> separator character was not found.Invalid argument(s): [1] = "" The session
> ID is invalid because the session separator character was not found.
> Exception occurred in method MgUserInformation.SetMgSessionId at line 183 in
> file d:\buildforgeprojects\mapguide_open_source
> Do u know what is this session separator character????
> thanks&regards
> susan
> On Tue, May 5, 2009 at 10:44 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> you changed the order!
>> what you have done is try to reference the hidden form field before it
>> exists
>> z
>> On Tue, May 5, 2009 at 3:02 PM, susan Daniel <daniel.susan6 at gmail.com>
>> wrote:
>> > hi zac...
>> >         It is also not working......
>> > This is the code
>> > <body>
>> > <script>
>> > </script>
>> > <form action="selectlocation.php" method="get">
>> > </form>
>> > and in selectlocation.php i'm having this code:
>> > <?php $ID= $_GET['PanId'];
>> >    ?><br />
>> >   <body class="AppFrame" onLoad="OnPageLoad()">
>> >     <h1 class="AppHeading">Select features</h1>
>> >     <?php
>> >     include '../common/common.php';
>> >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST: $_GET;
>> >     $sessionId = $args['SESSION'];
>> >     $mapName = $args['MAPNAME'];
>> >     try
>> >       // Initialize the Web Extensions and connect to the Server using
>> >       // the Web Extensions session identifier stored in PHP session
>> > state.
>> >       MgInitializeWebTier ($webconfigFilePath);
>> >       $userInfo = new MgUserInformation($sessionId  );
>> >       $siteConnection = new MgSiteConnection();
>> >       $siteConnection->Open($userInfo);
>> >       $map = new MgMap($siteConnection);
>> >       $map->Open( $mapName  );
>> >       // Get the geometry for the boundaries of District 1
>> >       $districtQuery = new MgFeatureQueryOptions();
>> >       $districtQuery->SetFilter("pan_id==$ID");
>> >       $layer = $map->GetLayers()->GetItem('Panchayat');
>> >       $featureReader = $layer->SelectFeatures($districtQuery);
>> >       $featureReader->ReadNext();
>> >       $districtGeometryData = $featureReader->
>> >       GetGeometry('Data');
>> >       // Convert the AGF binary data to MgGeometry.
>> >       $agfReaderWriter = new MgAgfReaderWriter();
>> >       $districtGeometry = $agfReaderWriter->Read($districtGeometryData);
>> >       // Create a filter to select the desired features. Combine
>> >       // a basic filter and a spatial filter.
>> >       $queryOptions = new MgFeatureQueryOptions();
>> >       $queryOptions->SetSpatialFilter('panchayat', $districtGeometry,
>> > MgFeatureSpatialOperations::Inside);
>> >       // Get the features from the feature source,
>> >       // turn it into a selection, then save the selection as XML.
>> >       $layer = $map->GetLayers()->GetItem(0);
>> >       $featureReader = $layer->SelectFeatures($queryOptions);
>> >       $selection = new MgSelection($map);
>> >       $selection->AddFeatures($layer, $featureReader, 0);
>> >       $selectionXml = $selection->ToXml();
>> >     catch (MgException $e)
>> >       echo $e->GetMessage();
>> >       echo $e->GetDetails();
>> >   </body>
>> >     function OnPageLoad()
>> >       selectionXml = '<?php echo $selectionXml; ?>';
>> >       parent.parent.SetSelectionXML(selectionXml);
>> >   </script>
>> > </body>
>> > </html>
>> > Can u find any error in this?????
>> > regards
>> > susan
>> > On Tue, May 5, 2009 at 10:14 AM, Zac Spitzer <zac.spitzer at gmail.com>
>> > wrote:
>> >> quicky n dirty but it should work
>> >> <script>
>> >> </script>
>> >> On Tue, May 5, 2009 at 2:39 PM, susan Daniel <daniel.susan6 at gmail.com>
>> >> wrote:
>> >> > hi chris
>> >> >          I removed that quotes .but the same error occurred..Anyone
>> >> > know
>> >> > any
>> >> > other method to pass this SessionId &mapname???
>> >> > help me plsssss
>> >> > regards
>> >> > susan
>> >> > On Mon, May 4, 2009 at 8:07 PM, Chris Claydon
>> >> > <chris.claydon at autodesk.com>
>> >> > wrote:
>> >> >> It looks like this field <input type="hidden"name="SESSION"
>> >> >> value="javascript:Getsession()"/ >
>> >> >> is using the string “javascript:Getsession()” rather than actually
>> >> >> calling
>> >> >> the method and setting the value to the id that is returned.
>> >> >> If you remove the quotes, what happens then?
>> >> >> Chris.
>> >> >> From: mapguide-users-bounces at lists.osgeo.org
>> >> >> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of susan
>> >> >> Daniel
>> >> >> Sent: Sunday, May 03, 2009 10:09 PM
>> >> >> To: MapGuide Users Mail List
>> >> >> Subject: Re: [mapguide-users] select the location on map
>> >> >> hi....
>> >> >>       Still the same error ....
>> >> >> Invalid argument(s): [1] = "javascript:Getsession()" The session ID
>> >> >> is
>> >> >> found.Invalid
>> >> >> argument(s): [1] = "javascript:Getsession()" The session ID is
>> >> >> invalid
>> >> >> because the session separator character was not found. Exception
>> >> >> occurred in
>> >> >> method MgUserInformation.SetMgSessionId at line 183 in file
>> >> >> my code in window.php:
>> >> >> <body>
>> >> >> <script language="javascript"type="javasript/text">
>> >> >> function Getsession()
>> >> >>  document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
>> >> >> function Getmapname()
>> >> >>  document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;
>> >> >> </script>
>> >> >> <input type="hidden"name="SESSION" value="javascript:Getsession()"/
>> >> >> <input type="hidden"name="MAPNAME" value="javascript:Getmapname()"/
>> >> >> </form>
>> >> >> <br><br>
>> >> >> Tf anyone having any idea plsss help.....I tried a lot
>> >> >> thanks&regards
>> >> >> susan
>> >> >> On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov
>> >> >> <s.dalakov at mapware.net>
>> >> >> wrote:
>> >> >> You could use something like this (executed when window.php is
>> >> >> loaded)
>> >> >> Stefan
>> >> >> susan Daniel wrote:
>> >> >> hi..all
>> >> >>       Then what i have to do?Any solution to pass these sessionId
>> >> >> and
>> >> >> mapname ????
>> >> >> regards
>> >> >> susan
>> >> >> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov
>> >> >> <mailto:s.dalakov at mapware.net>> wrote:
>> >> >>    These javascript.functions never get executed. I checked now, I
>> >> >>    added some "alert"s  and they didn't show.
>> >> >>    susan Daniel wrote:
>> >> >>    HI..
>> >> >>            I removed that brace but still the error is there
>> >> >>    regards
>> >> >>    susan
>> >> >>    On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
>> >> >>    <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>> wrote:
>> >> >>        I see an extra brace (the very first one) in the javascript
>> >> >>        block that could
>> >> >>        be messing everything up.
>> >> >>        - Jackie
>> >> >>        SusanDaniel wrote:
>> >> >>        > hi all
>> >> >>        >         In order to display a form in the task pane i've
>> >> >>        the following
>> >> >>        > code
>> >> >>        > in "....../mapviewerphp/window.php"
>> >> >>        > <body>
>> >> >>        > <script language="javascript">
>> >> >>        > function getsession()
>> >> >>        > sessionId=parent.parent.mapframe.GetSessionId();
>> >> >>        > function getmapname()
>> >> >>        > mapname=parent.parent.mapframe.GetMapName();
>> >> >>        > </script>
>> >> >>        > <form action="selectlocation.php" method="get">
>> >> >>        > Enter PanId <input type="text" name="PanId"/><br><br>
>> >> >>        > <input type="hidden"name="SESSION"
>> >> >>        value="javascript:getsession()"/ >
>> >> >>        > <input type="hidden"name="MAPNAME"
>> >> >>        value="javascript:getmapname()"/  >
>> >> >>        > <input type="submit" value="Submit" />
>> >> >>        > </form>
>> >> >>        > *and in the selectlocation .php i am having
>> >> >>        >  </head>
>> >> >>        >   <?php $ID= $_GET['PanId'];
>> >> >>        >     ?>.<br />
>> >> >>        >   <body class="AppFrame" onLoad="OnPageLoad()">
>> >> >>        >     <h1 class="AppHeading">Select features</h1>
>> >> >>        >     <?php
>> >> >>        >     include '../common/common.php';
>> >> >>        >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
>> >> >>        $_GET;
>> >> >>        >     $sessionId = $args['SESSION'];
>> >> >>        >     $mapName = $args['MAPNAME'];
>> >> >>        >     try
>> >> >>        >       // Initialize the Web Extensions and connect to the
>> >> >>        Server using
>> >> >>        >       // the Web Extensions session identifier stored in
>> >> >>        PHP session
>> >> >>        > state.
>> >> >>        >       MgInitializeWebTier ($webconfigFilePath);
>> >> >>        >       $userInfo = new MgUserInformation($sessionId);
>> >> >>        >       $siteConnection = new MgSiteConnection();
>> >> >>        >       $siteConnection->Open($userInfo);
>> >> >>        >       $map = new MgMap($siteConnection);
>> >> >>        >       $map->Open($mapName);
>> >> >>        >       // Get the geometry for the boundaries of District 1
>> >> >>        >       $districtQuery = new MgFeatureQueryOptions();
>> >> >>        >       $districtQuery->SetFilter("pan_id==$ID");
>> >> >>        >       $layer = $map->GetLayers()->GetItem('Panchayat');
>> >> >>        >       $featureReader =
>> >> >>        >       $featureReader->ReadNext();
>> >> >>        >       $districtGeometryData = $featureReader->
>> >> >>        >       GetGeometry('Data');
>> >> >>        >       // Convert the AGF binary data to MgGeometry.
>> >> >>        >       $agfReaderWriter = new MgAgfReaderWriter();
>> >> >>        >       $districtGeometry =
>> >> >>        >       // Create a filter to select the desired features.
>> >> >>        Combine
>> >> >>        >       // a basic filter and a spatial filter.
>> >> >>        >       $queryOptions = new MgFeatureQueryOptions();
>> >> >>        >       $queryOptions->SetSpatialFilter('SHPGEOM',
>> >> >>        $districtGeometry,
>> >> >>        > MgFeatureSpatialOperations::Inside);
>> >> >>        >       // Get the features from the feature source,
>> >> >>        >       // turn it into a selection, then save the selection
>> >> >>        as XML.
>> >> >>        >       $layer = $map->GetLayers()->GetItem(0);
>> >> >>        >       $featureReader =
>> >> >>        >       $selection = new MgSelection($map);
>> >> >>        >       $selection->AddFeatures($layer, $featureReader, 0);
>> >> >>        >       $selectionXml = $selection->ToXml();
>> >> >>        >     catch (MgException $e)
>> >> >>        >       echo $e->GetMessage();
>> >> >>        >       echo $e->GetDetails();
>> >> >>        >   </body>
>> >> >>        >     function OnPageLoad()
>> >> >>        >       selectionXml = '<?php echo $selectionXml; ?>';
>> >> >>        >       parent.parent.SetSelectionXML(selectionXml);
>> >> >>        >   </script>
>> >> >>        > </body>
>> >> >>        > </html>
>> >> >>        > *This code..But when i enter the panId in the form this
>> >> >>        error is occuring
>> >> >>        >   Invalid argument(s): [1] = "javascript:getsession()" The
>> >> >>        session ID is
>> >> >>        > invalid because the session separator character was not
>> >> >>        found.Invalid
>> >> >>        > argument(s): [1] = "javascript:getsession()" The session ID
>> >> >>        is invalid
>> >> >>        > because the session separator character was not found.
>> >> >>        Exception occurred
>> >> >>        > in
>> >> >>        > method MgUserInformation.SetMgSessionId at line 183 in file
>> >> >>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
>> >> >>        > Any mistake in my coding?????
>> >> >>        > Help me plss
>> >> >>        > regards
>> >> >>        > susan
>> >> >>        > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
>> >> >>        > <dave.wilson at autodesk.com
>> >> >>        <mailto:dave.wilson at autodesk.com>>wrote:
>> >> >>        >>  Did you check out the samples in the downloads area of
>> >> >> Osgeo?
>> >> >>        >> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>> >> >>        >> Dave
>> >> >>        >> *From:* mapguide-users-bounces at lists.osgeo.org
>> >> >>        <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:
>> >> >>        >> mapguide-users-bounces at lists.osgeo.org
>> >> >>        <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf
>> >> >>        Of *Ivan Milicevic
>> >> >>        >> *Sent:* Wednesday, April 22, 2009 1:52 AM
>> >> >>        >> *To:* MapGuide Users Mail List
>> >> >>        >> *Subject:* RE: [mapguide-users] select the location on map
>> >> >>        >> You can get it from some of them. Please, read
>> >> >> descritption.
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Wednesday, April 22, 2009 9:46 AM
>> >> >>        >> *Subject:* Re: [mapguide-users] select the location on map
>> >> >>        >> Thank u....
>> >> >>        >>                Can i get the source code of any of these
>> >> >>        sample
>> >> >>        >> applications? If so from where?
>> >> >>        >> regards
>> >> >>        >> susan
>> >> >>        >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
>> >> >>        >> Ivan.Milicevic at supranet.hr
>> >> >>        <mailto:Ivan.Milicevic at supranet.hr>> wrote:
>> >> >>        >> http://mapguide.osgeo.org/livegallery.html
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Wednesday, April 22, 2009 8:06 AM
>> >> >>        >> hi deve
>> >> >>        >>            I couldn't find that sample application.Any
>> >> >> link?
>> >> >>        >> regards
>> >> >>        >> susan
>> >> >>        >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
>> >> >>        <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com>>
>> >> >>        >> wrote:
>> >> >>        >> The sample application that does the Find Address does a
>> >> >>        selection on the
>> >> >>        >> map when you click on one of the search results. I thought
>> >> >>        this was
>> >> >>        >> discussed in the Sample Application.
>> >> >>        >> Dave
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Monday, April 20, 2009 12:18 AM
>> >> >>        >> hi alll...........
>> >> >>        >>                   I read the dev guide but didn't get any
>> >> >>        idea regarding
>> >> >>        >> this.Hav anyone tried this before pls give me any hint how
>> >> >>        to start this
>> >> >>        >> thanks &regards
>> >> >>        >> susan
>> >> >>        >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>> >> >>        >> wrote:
>> >> >>        >> Have you read through the developer’s guide? It has sample
>> >> >>        code for
>> >> >>        >> selection and explains many concepts. It sounds like you
>> >> >>        need to make
>> >> >>        >> either
>> >> >>        >> an invoke script or invoke url call from a command in your
>> >> >>        Basic or
>> >> >>        >> Flexible
>> >> >>        >> Web Layout. You don’t actually have to replace the
>> >> >>        gettingstarted.php. In
>> >> >>        >> the invoke script or invoke url command allows you to
>> >> >>        specify the target
>> >> >>        >> frame for the output of the script.
>> >> >>        >> Regards,
>> >> >>        >> Dave
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Friday, April 17, 2009 3:57 AM
>> >> >>        >> yeah...i know that..
>> >> >>        >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
>> >> >>        >> Did you know how to create file that display's database
>> >> >>        table? If you
>> >> >>        >> don't
>> >> >>        >> know that you must find help somewhere else because I'm
>> >> >>        not a PHP guy.
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Friday, April 17, 2009 11:42 AM
>> >> >>        >> Hi..
>> >> >>        >>     No i dont have the file that displays database
>> >> >>        table...Actually iam
>> >> >>        >> doing this prjct in php.but i know javascript'
>> >> >>        >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
>> >> >>        >> Ok, so you have file that display's data from your
>> >> >>        database table? Or you
>> >> >>        >> don't have it at all? How familiar are you with
>> >> >> javascript?
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Friday, April 17, 2009 11:13 AM
>> >> >>        >> hi...
>> >> >>        >>    My problem is that..
>> >> >>        >>    I have a database table..Having colums  place ,id etc
>> >> >> .If
>> >> >> i
>> >> >>        >> selected(clicking) a data in the table the corresponding
>> >> >>        place(polygon)
>> >> >>        >> should be displayed(selected) on the map...My map is a
>> >> >>        polygon map .each
>> >> >>        >> polygon having unique id.and the same id is present in the
>> >> >>        db table
>> >> >>        >> also....Now u got it?any idea please help...
>> >> >>        >> regards
>> >> >>        >> susan
>> >> >>        >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
>> >> >>        >> I'm not sure that I understand your problem. With this
>> >> >>        code you can
>> >> >>        >> select
>> >> >>        >> any feature on map. Can you send a little bit more
>> >> >>        information? I'm clues
>> >> >>        >> over there.
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Friday, April 17, 2009 10:47 AM
>> >> >>        >> thank you  ivan...
>> >> >>        >>                        on which file i have to write this
>> >> >>        coding???  any
>> >> >>        >> idea??
>> >> >>        >> regards
>> >> >>        >> susan
>> >> >>        >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
>> >> >>        >> OBJEKTI is layer name and other thing is path to the
>> >> >>        feature source.
>> >> >>        >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>> >> >>        >> You can copy/paste feature source from mapguide maestro in
>> >> >>        layer
>> >> >>        >> definition
>> >> >>        >> window.
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Friday, April 17, 2009 9:45 AM
>> >> >>        >> thank you Ivan
>> >> >>        >> but  i 'd like to know on which file i want to write this
>> >> >>        coding??
>> >> >>        >> In ur coding OBJEKT1  is layer name right?then what is
>> >> >> this
>> >> >>        >> "Library://PROJEKTI/" + TIMgisUser +
>> >> >>        "/PODACI/OBJEKTI.FeatureSource");
>> >> >>        >> thanks and regards
>> >> >>        >> susan
>> >> >>        >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
>> >> >>        >> Hello Susan,
>> >> >>        >> Here is C# code for selection, it's pretty same as PHP.
>> >> >>        >> MgSiteConnection siteConnection = null;
>> >> >>        >>     InitializeWebTier();
>> >> >>        >>     MgUserInformation userInfo = new
>> >> >>        MgUserInformation(mgSessionId);
>> >> >>        >>     siteConnection = new MgSiteConnection();
>> >> >>        >>     siteConnection.Open(userInfo);
>> >> >>        >>     MgResourceService resourceService =
>> >> >>        siteConnection.CreateService(
>> >> >>        >> MgServiceType.ResourceService) as MgResourceService;
>> >> >>        >>     MgFeatureService featureService =
>> >> >>        >> MgServiceType.FeatureService) as MgFeatureService;
>> >> >>        >>     MgMap map = new MgMap();
>> >> >>        >>     map.Open(resourceService, "1"); //opening map with
>> >> >>        name „1“
>> >> >>        >>     MgFeatureQueryOptions queryOptionsObjekti = new
>> >> >>        >>     MgAgfReaderWriter geometryReaderWriter = new
>> >> >>        >>     MgSelection selection = new MgSelection(map);
>> >> >>        >>     //Defining layer and feature source
>> >> >>        >>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>> >> >>        >>     MgResourceIdentifier featureResIdObjekti = new
>> >> >>        MgResourceIdentifier(
>> >> >>        >>     //Creating feature filter, this is very important
>> >> >> step!
>> >> >>        >>     string filter = "ID=" + idO;
>> >> >>        >>     queryOptionsObjekti.SetFilter(filter);
>> >> >>        >>     MgFeatureReader featureReaderObjekti =
>> >> >>        featureService.SelectFeatures(
>> >> >>        >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>> >> >>        >>     selection.AddFeatures(layerObjekti,
>> >> >>        featureReaderObjekti, 1);
>> >> >>        >>     selection.Save(resourceService, "1");
>> >> >>        >>     StringReader stream = new
>> >> >> StringReader(selection.ToXml());
>> >> >>        >>     string selectionXml = selection.ToXml();
>> >> >>        >>     featureReaderObjekti.Close();
>> >> >>        >>     map.Save();
>> >> >>        >>     //Here, you call javascript function and pass the
>> >> >>        selection var
>> >> >>        >>     Response.Write("<script>select('" + selectionXml +
>> >> >>        "');</script>");
>> >> >>        >> //This is javascript function that set's the selection
>> >> >>        from code and do
>> >> >>        >> the
>> >> >>        >> refresh.
>> >> >>        >> function select(xml)
>> >> >>        >> parent.mapFrame.SetSelectionXML(xml);
>> >> >>        >> parent.mapFrame.ExecuteMapAction(10);
>> >> >>        Of *susan Daniel
>> >> >>        >> *Sent:* Friday, April 17, 2009 9:11 AM
>> >> >>        >> *To:* mapguide-users at lists.osgeo.org
>> >> >>        <mailto:mapguide-users at lists.osgeo.org>
>> >> >>        >> *Subject:* [mapguide-users] select the location on map
>> >> >>        >> hi all
>> >> >>        >>         My plat form is mapguide maestro&php.I connect it
>> >> >>        with mysql.Now
>> >> >>        >> i
>> >> >>        >> want to select the corresponding polygon on the map while
>> >> >>        clicking on the
>> >> >>        >> data in database.In order to display the database table in
>> >> >>        the taskpane,i
>> >> >>        >> removed the contents of the file "/mapviewerphp/getting
>> >> >>        started .php" and
>> >> >>        >> wrote my codings.then how to select the polygon?.Any one
>> >> >> know
>> >> >>        >> this????Anyone
>> >> >>        >> having coding to do this???
>> >> >>        >> please help me
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> _______________________________________________
>> >> >>        >> mapguide-users mailing list
>> >> >>        >> mapguide-users at lists.osgeo.org
>> >> >>        >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        >> thanks&regards
>> >> >>        >>  susan
>> >> >>        > thanks&regards
>> >> >>        >  susan
>> >> >>        View this message in context:
>> >> >>  http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
>> >> >>        Sent from the MapGuide Users mailing list archive at
>> >> >> Nabble.com.
>> >> >>    --    thanks&regards
>> >> >>     susan
>> >> >>    _______________________________________________ mapguide-users
>> >> >>    mailing list mapguide-users at lists.osgeo.org
>> >> >> thanks&regards
>> >> >>  susan
>> >> >> thanks&regards
>> >> >>  susan
>> >> > thanks&regards
>> >> >  susan
>> >> Zac Spitzer -
>> >> http://zacster.blogspot.com
>> >> +61 405 847 168
>> > thanks&regards
>> >  susan
>> Zac Spitzer -
>> +61 405 847 168
> thanks&regards
>  susan
Zac Spitzer -
+61 405 847 168
