[mapguide-users] select the location on map
susan Daniel daniel.susan6 at gmail.com
Tue May 5 02:48:31 EDT 2009
hi all..
              can i give this sessionId and mapname directly in
selectlocation.php page.If so how???
thanka&regards
susan
On Tue, May 5, 2009 at 11:10 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> that looks right
> try using fiddler to monitor track what is being passed back up to the
> server
> r u using firefox with firebug?
> you could also add an
> alert(Getsession());
> to make sure the session id is being returned
> On Tue, May 5, 2009 at 3:35 PM, susan Daniel <daniel.susan6 at gmail.com>
> wrote:
> > hi......
> >              Did u mean like this
> > <form action="selectlocation.php" method="GET">
> > Enter PanId <input type="text" name="PanId"/><br><br>
> > <input type="hidden" name="SESSION" id="mg_session" value=""/ >
> > <script language="javascript">
> >        document.getElementById('mg_session').value=Getsession();
> > </script>
> > <input type="submit" value="Submit" />
> > </form>
> > but still the error is occuring...
> > the error is like this
> > Invalid argument(s): [1] = "" The session ID is invalid because the
> session
> > separator character was not found.Invalid argument(s): [1] = "" The
> session
> > ID is invalid because the session separator character was not found.
> > Exception occurred in method MgUserInformation.SetMgSessionId at line 183
> in
> > file d:\buildforgeprojects\mapguide_open_source
> > Do u know what is this session separator character????
> > thanks&regards
> > susan
> > On Tue, May 5, 2009 at 10:44 AM, Zac Spitzer <zac.spitzer at gmail.com>
> wrote:
> >> you changed the order!
> >> what you have done is try to reference the hidden form field before it
> >> exists
> >> z
> >> On Tue, May 5, 2009 at 3:02 PM, susan Daniel <daniel.susan6 at gmail.com>
> >> wrote:
> >> > hi zac...
> >> >         It is also not working......
> >> > This is the code
> >> > <body>
> >> > <script>
> >> > </script>
> >> > <form action="selectlocation.php" method="get">
> >> > </form>
> >> > and in selectlocation.php i'm having this code:
> >> > <?php $ID= $_GET['PanId'];
> >> >    ?><br />
> >> >   <body class="AppFrame" onLoad="OnPageLoad()">
> >> >     <h1 class="AppHeading">Select features</h1>
> >> >     <?php
> >> >     include '../common/common.php';
> >> >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST: $_GET;
> >> >     $sessionId = $args['SESSION'];
> >> >     $mapName = $args['MAPNAME'];
> >> >     try
> >> >       // Initialize the Web Extensions and connect to the Server using
> >> >       // the Web Extensions session identifier stored in PHP session
> >> > state.
> >> >       MgInitializeWebTier ($webconfigFilePath);
> >> >       $userInfo = new MgUserInformation($sessionId  );
> >> >       $siteConnection = new MgSiteConnection();
> >> >       $siteConnection->Open($userInfo);
> >> >       $map = new MgMap($siteConnection);
> >> >       $map->Open( $mapName  );
> >> >       // Get the geometry for the boundaries of District 1
> >> >       $districtQuery = new MgFeatureQueryOptions();
> >> >       $districtQuery->SetFilter("pan_id==$ID");
> >> >       $layer = $map->GetLayers()->GetItem('Panchayat');
> >> >       $featureReader = $layer->SelectFeatures($districtQuery);
> >> >       $featureReader->ReadNext();
> >> >       $districtGeometryData = $featureReader->
> >> >       GetGeometry('Data');
> >> >       // Convert the AGF binary data to MgGeometry.
> >> >       $agfReaderWriter = new MgAgfReaderWriter();
> >> >       $districtGeometry =
> $agfReaderWriter->Read($districtGeometryData);
> >> >       // Create a filter to select the desired features. Combine
> >> >       // a basic filter and a spatial filter.
> >> >       $queryOptions = new MgFeatureQueryOptions();
> >> >       $queryOptions->SetSpatialFilter('panchayat', $districtGeometry,
> >> > MgFeatureSpatialOperations::Inside);
> >> >       // Get the features from the feature source,
> >> >       // turn it into a selection, then save the selection as XML.
> >> >       $layer = $map->GetLayers()->GetItem(0);
> >> >       $featureReader = $layer->SelectFeatures($queryOptions);
> >> >       $selection = new MgSelection($map);
> >> >       $selection->AddFeatures($layer, $featureReader, 0);
> >> >       $selectionXml = $selection->ToXml();
> >> >     catch (MgException $e)
> >> >       echo $e->GetMessage();
> >> >       echo $e->GetDetails();
> >> >   </body>
> >> >     function OnPageLoad()
> >> >       selectionXml = '<?php echo $selectionXml; ?>';
> >> >       parent.parent.SetSelectionXML(selectionXml);
> >> >   </script>
> >> > </body>
> >> > </html>
> >> > Can u find any error in this?????
> >> > regards
> >> > susan
> >> > On Tue, May 5, 2009 at 10:14 AM, Zac Spitzer <zac.spitzer at gmail.com>
> >> > wrote:
> >> >> quicky n dirty but it should work
> >> >> <script>
> >> >> </script>
> >> >> On Tue, May 5, 2009 at 2:39 PM, susan Daniel <
> >> >> wrote:
> >> >> > hi chris
> >> >> >          I removed that quotes .but the same error occurred..Anyone
> >> >> > know
> >> >> > any
> >> >> > other method to pass this SessionId &mapname???
> >> >> > help me plsssss
> >> >> > regards
> >> >> > susan
> >> >> > On Mon, May 4, 2009 at 8:07 PM, Chris Claydon
> >> >> > <chris.claydon at autodesk.com>
> >> >> > wrote:
> >> >> >> It looks like this field <input type="hidden"name="SESSION"
> >> >> >> value="javascript:Getsession()"/ >
> >> >> >> is using the string “javascript:Getsession()” rather than actually
> >> >> >> calling
> >> >> >> the method and setting the value to the id that is returned.
> >> >> >> If you remove the quotes, what happens then?
> >> >> >> Chris.
> >> >> >> From: mapguide-users-bounces at lists.osgeo.org
> >> >> >> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
> susan
> >> >> >> Daniel
> >> >> >> Sent: Sunday, May 03, 2009 10:09 PM
> >> >> >> To: MapGuide Users Mail List
> >> >> >> Subject: Re: [mapguide-users] select the location on map
> >> >> >> hi....
> >> >> >>       Still the same error ....
> >> >> >> Invalid argument(s): [1] = "javascript:Getsession()" The session
> ID
> >> >> >> is
> >> >> >> found.Invalid
> >> >> >> argument(s): [1] = "javascript:Getsession()" The session ID is
> >> >> >> invalid
> >> >> >> because the session separator character was not found. Exception
> >> >> >> occurred in
> >> >> >> method MgUserInformation.SetMgSessionId at line 183 in file
> >> >> >> my code in window.php:
> >> >> >> <body>
> >> >> >> <script language="javascript"type="javasript/text">
> >> >> >> function Getsession()
>  document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
> >> >> >> function Getmapname()
> >> >> >>  document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName()
> >> >> >> </script>
> >> >> >> <input type="hidden"name="MAPNAME"
> value="javascript:Getmapname()"/
> >> >> >> </form>
> >> >> >> <br><br>
> >> >> >> Tf anyone having any idea plsss help.....I tried a lot
> >> >> >> thanks&regards
> >> >> >> susan
> >> >> >> On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov
> >> >> >> <s.dalakov at mapware.net>
> >> >> >> wrote:
> >> >> >> You could use something like this (executed when window.php is
> >> >> >> loaded)
> >> >> >> Stefan
> >> >> >> susan Daniel wrote:
> >> >> >> hi..all
> >> >> >>       Then what i have to do?Any solution to pass these sessionId
> >> >> >> and
> >> >> >> mapname ????
> >> >> >> regards
> >> >> >> susan
> >> >> >> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov
> >> >> >> <mailto:s.dalakov at mapware.net>> wrote:
> >> >> >>    These javascript.functions never get executed. I checked now, I
> >> >> >>    added some "alert"s  and they didn't show.
> >> >> >>    susan Daniel wrote:
> >> >> >>    HI..
> >> >> >>            I removed that brace but still the error is there
> >> >> >>    regards
> >> >> >>    susan
> >> >> >>    On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
> >> >> >>    <jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>>
> wrote:
> >> >> >>        I see an extra brace (the very first one) in the javascript
> >> >> >>        block that could
> >> >> >>        be messing everything up.
> >> >> >>        - Jackie
> >> >> >>        SusanDaniel wrote:
> >> >> >>        > hi all
> >> >> >>        >         In order to display a form in the task pane i've
> >> >> >>        the following
> >> >> >>        > code
> >> >> >>        > in "....../mapviewerphp/window.php"
> >> >> >>        > <body>
> >> >> >>        > function getsession()
> >> >> >>        > sessionId=parent.parent.mapframe.GetSessionId();
> >> >> >>        > function getmapname()
> >> >> >>        > mapname=parent.parent.mapframe.GetMapName();
> >> >> >>        > </script>
> >> >> >>        value="javascript:getsession()"/ >
> >> >> >>        value="javascript:getmapname()"/  >
> >> >> >>        > </form>
> >> >> >>        > *and in the selectlocation .php i am having
> >> >> >>        >  </head>
> >> >> >>        >     ?>.<br />
> >> >> >>        >     <?php
> $_POST:
> >> >> >>        $_GET;
> >> >> >>        >     try
> >> >> >>        Server using
> >> >> >>        PHP session
> >> >> >>        > state.
> >> >> >>        >       $userInfo = new MgUserInformation($sessionId);
> >> >> >>        >       $map->Open($mapName);
> 1
> >> >> >>        >       $featureReader =
> >> >> >>        >       $districtGeometry =
> >> >> >>        Combine
> >> >> >>        >       $queryOptions->SetSpatialFilter('SHPGEOM',
> >> >> >>        $districtGeometry,
> selection
> >> >> >>        as XML.
> >> >> >>        >       $featureReader =
> >> >> >>        >   </body>
> >> >> >>        >   </script>
> >> >> >>        > </body>
> >> >> >>        > </html>
> >> >> >>        > *This code..But when i enter the panId in the form this
> >> >> >>        error is occuring
> >> >> >>        >   Invalid argument(s): [1] = "javascript:getsession()"
> The
> >> >> >>        session ID is
> >> >> >>        found.Invalid
> >> >> >>        > argument(s): [1] = "javascript:getsession()" The session
> ID
> >> >> >>        is invalid
> >> >> >>        Exception occurred
> >> >> >>        > in
> file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
> >> >> >>        > Any mistake in my coding?????
> >> >> >>        > Help me plss
> >> >> >>        > regards
> >> >> >>        > susan
> >> >> >>        > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
> >> >> >>        > <dave.wilson at autodesk.com
> >> >> >>        <mailto:dave.wilson at autodesk.com>>wrote:
> >> >> >>        >>  Did you check out the samples in the downloads area of
> >> >> >> Osgeo?
> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> >> >> >>        >> Dave
> >> >> >>        >> *From:* mapguide-users-bounces at lists.osgeo.org
> >> >> >>        <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:
> >> >> >>        <mailto:mapguide-users-bounces at lists.osgeo.org>] *On
> Behalf
> >> >> >>        Of *Ivan Milicevic
> >> >> >>        >> *Sent:* Wednesday, April 22, 2009 1:52 AM
> >> >> >>        >> *To:* MapGuide Users Mail List
> >> >> >>        >> *Subject:* RE: [mapguide-users] select the location on
> map
> >> >> >>        >> You can get it from some of them. Please, read
> >> >> >> descritption.
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Wednesday, April 22, 2009 9:46 AM
> >> >> >>        >> *Subject:* Re: [mapguide-users] select the location on
> map
> >> >> >>        >> Thank u....
> >> >> >>        >>                Can i get the source code of any of these
> >> >> >>        sample
> >> >> >>        >> applications? If so from where?
> >> >> >>        >> regards
> >> >> >>        >> susan
> >> >> >>        >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
> >> >> >>        >> Ivan.Milicevic at supranet.hr
> >> >> >>        <mailto:Ivan.Milicevic at supranet.hr>> wrote:
> >> >> >>        >> http://mapguide.osgeo.org/livegallery.html
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Wednesday, April 22, 2009 8:06 AM
> map
> >> >> >>        >> hi deve
> >> >> >>        >>            I couldn't find that sample application.Any
> >> >> >> link?
> >> >> >>        >> regards
> >> >> >>        >> susan
> >> >> >>        >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
> >> >> >>        <dave.wilson at autodesk.com <mailto:dave.wilson at autodesk.com
> >> >> >>        >> wrote:
> >> >> >>        >> The sample application that does the Find Address does a
> >> >> >>        selection on the
> >> >> >>        >> map when you click on one of the search results. I
> thought
> >> >> >>        this was
> >> >> >>        >> discussed in the Sample Application.
> >> >> >>        >> Dave
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Monday, April 20, 2009 12:18 AM
> map
> >> >> >>        >> hi alll...........
> >> >> >>        >>                   I read the dev guide but didn't get
> any
> >> >> >>        idea regarding
> >> >> >>        >> this.Hav anyone tried this before pls give me any hint
> how
> >> >> >>        to start this
> >> >> >>        >> thanks &regards
> >> >> >>        >> susan
> >> >> >>        >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
> >> >> >>        >> wrote:
> >> >> >>        >> Have you read through the developer’s guide? It has
> sample
> >> >> >>        code for
> >> >> >>        >> selection and explains many concepts. It sounds like you
> >> >> >>        need to make
> >> >> >>        >> either
> >> >> >>        >> an invoke script or invoke url call from a command in
> your
> >> >> >>        Basic or
> >> >> >>        >> Flexible
> >> >> >>        >> Web Layout. You don’t actually have to replace the
> >> >> >>        gettingstarted.php. In
> >> >> >>        >> the invoke script or invoke url command allows you to
> >> >> >>        specify the target
> >> >> >>        >> frame for the output of the script.
> >> >> >>        >> Regards,
> >> >> >>        >> Dave
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Friday, April 17, 2009 3:57 AM
> map
> >> >> >>        >> yeah...i know that..
> >> >> >>        >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
> >> >> >>        >> Did you know how to create file that display's database
> >> >> >>        table? If you
> >> >> >>        >> don't
> >> >> >>        >> know that you must find help somewhere else because I'm
> >> >> >>        not a PHP guy.
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Friday, April 17, 2009 11:42 AM
> map
> >> >> >>        >> Hi..
> >> >> >>        >>     No i dont have the file that displays database
> >> >> >>        table...Actually iam
> >> >> >>        >> doing this prjct in php.but i know javascript'
> >> >> >>        >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
> >> >> >>        >> Ok, so you have file that display's data from your
> >> >> >>        database table? Or you
> >> >> >>        >> don't have it at all? How familiar are you with
> >> >> >> javascript?
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Friday, April 17, 2009 11:13 AM
> map
> >> >> >>        >> hi...
> >> >> >>        >>    My problem is that..
> >> >> >>        >>    I have a database table..Having colums  place ,id etc
> >> >> >> .If
> >> >> >> i
> >> >> >>        >> selected(clicking) a data in the table the corresponding
> >> >> >>        place(polygon)
> >> >> >>        >> should be displayed(selected) on the map...My map is a
> >> >> >>        polygon map .each
> >> >> >>        >> polygon having unique id.and the same id is present in
> the
> >> >> >>        db table
> >> >> >>        >> also....Now u got it?any idea please help...
> >> >> >>        >> regards
> >> >> >>        >> susan
> >> >> >>        >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
> >> >> >>        >> I'm not sure that I understand your problem. With this
> >> >> >>        code you can
> >> >> >>        >> select
> >> >> >>        >> any feature on map. Can you send a little bit more
> >> >> >>        information? I'm clues
> >> >> >>        >> over there.
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Friday, April 17, 2009 10:47 AM
> map
> >> >> >>        >> thank you  ivan...
> >> >> >>        >>                        on which file i have to write
> this
> >> >> >>        coding???  any
> >> >> >>        >> idea??
> >> >> >>        >> regards
> >> >> >>        >> susan
> >> >> >>        >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
> >> >> >>        >> OBJEKTI is layer name and other thing is path to the
> >> >> >>        feature source.
> >> >> >>        >> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
> >> >> >>        >> You can copy/paste feature source from mapguide maestro
> in
> >> >> >>        layer
> >> >> >>        >> definition
> >> >> >>        >> window.
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Friday, April 17, 2009 9:45 AM
> map
> >> >> >>        >> thank you Ivan
> >> >> >>        >> but  i 'd like to know on which file i want to write
> this
> >> >> >>        coding??
> >> >> >>        >> In ur coding OBJEKT1  is layer name right?then what is
> >> >> >> this
> >> >> >>        >> "Library://PROJEKTI/" + TIMgisUser +
> >> >> >>        "/PODACI/OBJEKTI.FeatureSource");
> >> >> >>        >> thanks and regards
> >> >> >>        >> susan
> >> >> >>        >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
> >> >> >>        >> Hello Susan,
> >> >> >>        >> Here is C# code for selection, it's pretty same as PHP.
> >> >> >>        >> MgSiteConnection siteConnection = null;
> >> >> >>        >>     InitializeWebTier();
> >> >> >>        >>     MgUserInformation userInfo = new
> >> >> >>        MgUserInformation(mgSessionId);
> >> >> >>        >>     siteConnection.Open(userInfo);
> >> >> >>        >>     MgResourceService resourceService =
> >> >> >>        siteConnection.CreateService(
> >> >> >>        >> MgServiceType.ResourceService) as MgResourceService;
> >> >> >>        >>     MgFeatureService featureService =
> >> >> >>        >> MgServiceType.FeatureService) as MgFeatureService;
> >> >> >>        >>     MgMap map = new MgMap();
> >> >> >>        >>     map.Open(resourceService, "1"); //opening map with
> >> >> >>        name „1“
> >> >> >>        >>     MgFeatureQueryOptions queryOptionsObjekti = new
> >> >> >>        >>     MgAgfReaderWriter geometryReaderWriter = new
> >> >> >>        >>     MgSelection selection = new MgSelection(map);
> >> >> >>        >>     //Defining layer and feature source
> >> >> >>        >>     MgLayer layerObjekti = GetLayerByName(map,
> "OBJEKTI");
> >> >> >>        >>     MgResourceIdentifier featureResIdObjekti = new
> >> >> >>        MgResourceIdentifier(
> >> >> >>        >>     //Creating feature filter, this is very important
> >> >> >> step!
> >> >> >>        >>     string filter = "ID=" + idO;
> >> >> >>        >>     queryOptionsObjekti.SetFilter(filter);
> >> >> >>        >>     MgFeatureReader featureReaderObjekti =
> >> >> >>        featureService.SelectFeatures(
> >> >> >>        >> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
> >> >> >>        >>     selection.AddFeatures(layerObjekti,
> >> >> >>        featureReaderObjekti, 1);
> >> >> >>        >>     selection.Save(resourceService, "1");
> >> >> >>        >>     StringReader stream = new
> >> >> >> StringReader(selection.ToXml());
> >> >> >>        >>     string selectionXml = selection.ToXml();
> >> >> >>        >>     featureReaderObjekti.Close();
> >> >> >>        >>     map.Save();
> >> >> >>        >>     //Here, you call javascript function and pass the
> >> >> >>        selection var
> >> >> >>        >>     Response.Write("<script>select('" + selectionXml +
> >> >> >>        "');</script>");
> >> >> >>        >> //This is javascript function that set's the selection
> >> >> >>        from code and do
> >> >> >>        >> the
> >> >> >>        >> refresh.
> >> >> >>        >> function select(xml)
> >> >> >>        >> parent.mapFrame.SetSelectionXML(xml);
> >> >> >>        >> parent.mapFrame.ExecuteMapAction(10);
> Behalf
> >> >> >>        Of *susan Daniel
> >> >> >>        >> *Sent:* Friday, April 17, 2009 9:11 AM
> >> >> >>        >> *To:* mapguide-users at lists.osgeo.org
> >> >> >>        <mailto:mapguide-users at lists.osgeo.org>
> >> >> >>        >> *Subject:* [mapguide-users] select the location on map
> >> >> >>        >> hi all
> >> >> >>        >>         My plat form is mapguide maestro&php.I connect
> it
> >> >> >>        with mysql.Now
> >> >> >>        >> i
> >> >> >>        >> want to select the corresponding polygon on the map
> while
> >> >> >>        clicking on the
> >> >> >>        >> data in database.In order to display the database table
> in
> >> >> >>        the taskpane,i
> >> >> >>        >> removed the contents of the file "/mapviewerphp/getting
> >> >> >>        started .php" and
> >> >> >>        >> wrote my codings.then how to select the polygon?.Any one
> >> >> >> know
> >> >> >>        >> this????Anyone
> >> >> >>        >> having coding to do this???
> >> >> >>        >> please help me
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> _______________________________________________
> >> >> >>        >> mapguide-users mailing list
> >> >> >>        >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        >> thanks&regards
> >> >> >>        >>  susan
> >> >> >>        > thanks&regards
> >> >> >>        >  susan
> >> >> >>        View this message in context:
> http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
> >> >> >>        Sent from the MapGuide Users mailing list archive at
> >> >> >> Nabble.com.
> >> >> >>    --    thanks&regards
> >> >> >>     susan
> >> >> >>    _______________________________________________ mapguide-users
> >> >> >>    mailing list mapguide-users at lists.osgeo.org
> >> >> >> thanks&regards
> >> >> >>  susan
> >> >> >> thanks&regards
> >> >> >>  susan
> >> >> > thanks&regards
> >> >> >  susan
> >> >> Zac Spitzer -
> >> >> http://zacster.blogspot.com
> >> >> +61 405 847 168
> >> > thanks&regards
> >> >  susan
> >> Zac Spitzer -
> >> +61 405 847 168
> > thanks&regards
> >  susan
> Zac Spitzer -
> +61 405 847 168
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090505/58105c33/attachment.html
