[mapguide-users] select the location on map
Stefan Dalakov
s.dalakov at mapware.net
Tue May 5 06:24:38 EDT 2009
Hi Susan,
this one for sure works :
<head>
<script language="javascript">
function MyOnLoad ()
document.myform.SESSION.value=parent.parent.mapFrame.GetSessionId();;
document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;;
</script>
</head>
<body onLoad="MyOnLoad()">
<form name="myform" action="selectlocation.php" method="get">
Enter PanId <input type="text" name="PanId"/><br><br>
<input type="hidden" name="SESSION" value=""/>
<input type="hidden" name="MAPNAME" value=""/>
<input type="submit" value="Submit" />
</form>
<br><br>
</body>
If it doesn't work just check references to mapFrame -
parent.parent.mapFrame or parent.mapFrame - depends from where you are
calling it.
Setselection.php needs to get these values from the calling routine from
client side - there is no way for setselection to guess the session id
of the caller
Stefan Dalakov
susan Daniel wrote:
> hi all..
> can i give this sessionId and mapname directly in
> selectlocation.php page.If so how???
> thanka®ards
> susan
> On Tue, May 5, 2009 at 11:10 AM, Zac Spitzer <zac.spitzer at gmail.com
> <mailto:zac.spitzer at gmail.com>> wrote:
> that looks right
> try using fiddler to monitor track what is being passed back up to
> the server
> r u using firefox with firebug?
> you could also add an
> alert(Getsession());
> to make sure the session id is being returned
> On Tue, May 5, 2009 at 3:35 PM, susan Daniel
> <daniel.susan6 at gmail.com <mailto:daniel.susan6 at gmail.com>> wrote:
> > hi......
> > Did u mean like this
> > <form action="selectlocation.php" method="GET">
> > <input type="hidden" name="SESSION" id="mg_session" value=""/ >
> > document.getElementById('mg_session').value=Getsession();
> > </script>
> > </form>
> > but still the error is occuring...
> > the error is like this
> > Invalid argument(s): [1] = "" The session ID is invalid because
> the session
> > separator character was not found.Invalid argument(s): [1] = ""
> The session
> > ID is invalid because the session separator character was not found.
> > Exception occurred in method MgUserInformation.SetMgSessionId at
> line 183 in
> > file d:\buildforgeprojects\mapguide_open_source
> > Do u know what is this session separator character????
> > thanks®ards
> > susan
> > On Tue, May 5, 2009 at 10:44 AM, Zac Spitzer
> <zac.spitzer at gmail.com <mailto:zac.spitzer at gmail.com>> wrote:
> >> you changed the order!
> >> what you have done is try to reference the hidden form field
> before it
> >> exists
> >> z
> >> On Tue, May 5, 2009 at 3:02 PM, susan Daniel
> >> wrote:
> >> > hi zac...
> >> > It is also not working......
> >> > This is the code
> >> > <body>
> >> > <script>
> >> > </script>
> >> > <form action="selectlocation.php" method="get">
> >> > </form>
> >> > and in selectlocation.php i'm having this code:
> >> > <?php $ID= $_GET['PanId'];
> >> > ?><br />
> >> > <body class="AppFrame" onLoad="OnPageLoad()">
> >> > <h1 class="AppHeading">Select features</h1>
> >> > <?php
> >> > include '../common/common.php';
> >> > $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
> $_GET;
> >> > $sessionId = $args['SESSION'];
> >> > $mapName = $args['MAPNAME'];
> >> > try
> >> > // Initialize the Web Extensions and connect to the
> Server using
> >> > // the Web Extensions session identifier stored in PHP
> session
> >> > state.
> >> > MgInitializeWebTier ($webconfigFilePath);
> >> > $userInfo = new MgUserInformation($sessionId );
> >> > $siteConnection = new MgSiteConnection();
> >> > $siteConnection->Open($userInfo);
> >> > $map = new MgMap($siteConnection);
> >> > $map->Open( $mapName );
> >> > // Get the geometry for the boundaries of District 1
> >> > $districtQuery = new MgFeatureQueryOptions();
> >> > $districtQuery->SetFilter("pan_id==$ID");
> >> > $layer = $map->GetLayers()->GetItem('Panchayat');
> >> > $featureReader = $layer->SelectFeatures($districtQuery);
> >> > $featureReader->ReadNext();
> >> > $districtGeometryData = $featureReader->
> >> > GetGeometry('Data');
> >> > // Convert the AGF binary data to MgGeometry.
> >> > $agfReaderWriter = new MgAgfReaderWriter();
> >> > $districtGeometry =
> $agfReaderWriter->Read($districtGeometryData);
> >> > // Create a filter to select the desired features. Combine
> >> > // a basic filter and a spatial filter.
> >> > $queryOptions = new MgFeatureQueryOptions();
> >> > $queryOptions->SetSpatialFilter('panchayat',
> $districtGeometry,
> >> > MgFeatureSpatialOperations::Inside);
> >> > // Get the features from the feature source,
> >> > // turn it into a selection, then save the selection as
> XML.
> >> > $layer = $map->GetLayers()->GetItem(0);
> >> > $featureReader = $layer->SelectFeatures($queryOptions);
> >> > $selection = new MgSelection($map);
> >> > $selection->AddFeatures($layer, $featureReader, 0);
> >> > $selectionXml = $selection->ToXml();
> >> > catch (MgException $e)
> >> > echo $e->GetMessage();
> >> > echo $e->GetDetails();
> >> > </body>
> >> > function OnPageLoad()
> >> > selectionXml = '<?php echo $selectionXml; ?>';
> >> > parent.parent.SetSelectionXML(selectionXml);
> >> > </script>
> >> > </body>
> >> > </html>
> >> > Can u find any error in this?????
> >> > regards
> >> > susan
> >> > On Tue, May 5, 2009 at 10:14 AM, Zac Spitzer
> >> > wrote:
> >> >> quicky n dirty but it should work
> >> >> <script>
> >> >> </script>
> >> >> On Tue, May 5, 2009 at 2:39 PM, susan Daniel
> >> >> wrote:
> >> >> > hi chris
> >> >> > I removed that quotes .but the same error
> occurred..Anyone
> >> >> > know
> >> >> > any
> >> >> > other method to pass this SessionId &mapname???
> >> >> > help me plsssss
> >> >> > regards
> >> >> > susan
> >> >> > On Mon, May 4, 2009 at 8:07 PM, Chris Claydon
> >> >> > <chris.claydon at autodesk.com
> <mailto:chris.claydon at autodesk.com>>
> >> >> > wrote:
> >> >> >> It looks like this field <input type="hidden"name="SESSION"
> >> >> >> value="javascript:Getsession()"/ >
> >> >> >> is using the string “javascript:Getsession()” rather than
> actually
> >> >> >> calling
> >> >> >> the method and setting the value to the id that is returned.
> >> >> >> If you remove the quotes, what happens then?
> >> >> >> Chris.
> >> >> >> From: mapguide-users-bounces at lists.osgeo.org
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> >> >> >> [mailto:mapguide-users-bounces at lists.osgeo.org
> <mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of susan
> >> >> >> Daniel
> >> >> >> Sent: Sunday, May 03, 2009 10:09 PM
> >> >> >> To: MapGuide Users Mail List
> >> >> >> Subject: Re: [mapguide-users] select the location on map
> >> >> >> hi....
> >> >> >> Still the same error ....
> >> >> >> Invalid argument(s): [1] = "javascript:Getsession()" The
> session ID
> >> >> >> is
> >> >> >> found.Invalid
> >> >> >> argument(s): [1] = "javascript:Getsession()" The session
> ID is
> >> >> >> invalid
> Exception
> >> >> >> occurred in
> >> >> >> method MgUserInformation.SetMgSessionId at line 183 in file
> >> >> >> my code in window.php:
> >> >> >> <body>
> >> >> >> <script language="javascript"type="javasript/text">
> >> >> >> function Getsession()
> document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
> >> >> >> function Getmapname()
> >> >> >> </script>
> >> >> >> <input type="hidden"name="MAPNAME"
> value="javascript:Getmapname()"/
> >> >> >> </form>
> >> >> >> <br><br>
> >> >> >> Tf anyone having any idea plsss help.....I tried a lot
> >> >> >> thanks®ards
> >> >> >> susan
> >> >> >> On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov
> >> >> >> <s.dalakov at mapware.net <mailto:s.dalakov at mapware.net>>
> >> >> >> wrote:
> >> >> >> You could use something like this (executed when
> window.php is
> >> >> >> loaded)
> >> >> >> Stefan
> >> >> >> susan Daniel wrote:
> >> >> >> hi..all
> >> >> >> Then what i have to do?Any solution to pass these
> sessionId
> >> >> >> and
> >> >> >> mapname ????
> >> >> >> regards
> >> >> >> susan
> >> >> >> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov
> <mailto:s.dalakov at mapware.net>>> wrote:
> >> >> >> These javascript.functions never get executed. I
> checked now, I
> >> >> >> added some "alert"s and they didn't show.
> >> >> >> susan Daniel wrote:
> >> >> >> HI..
> >> >> >> I removed that brace but still the error is there
> >> >> >> regards
> >> >> >> susan
> >> >> >> On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
> >> >> >> <jumpinjackie at gmail.com
> <mailto:jumpinjackie at gmail.com> <mailto:jumpinjackie at gmail.com
> <mailto:jumpinjackie at gmail.com>>> wrote:
> >> >> >> I see an extra brace (the very first one) in the
> javascript
> >> >> >> block that could
> >> >> >> be messing everything up.
> >> >> >> - Jackie
> >> >> >> SusanDaniel wrote:
> >> >> >> > hi all
> >> >> >> > In order to display a form in the task
> pane i've
> >> >> >> the following
> >> >> >> > code
> >> >> >> > in "....../mapviewerphp/window.php"
> >> >> >> > <body>
> >> >> >> > function getsession()
> >> >> >> > sessionId=parent.parent.mapframe.GetSessionId();
> >> >> >> > function getmapname()
> >> >> >> > mapname=parent.parent.mapframe.GetMapName();
> >> >> >> > </script>
> >> >> >> value="javascript:getsession()"/ >
> >> >> >> value="javascript:getmapname()"/ >
> >> >> >> > </form>
> >> >> >> > *and in the selectlocation .php i am having
> >> >> >> > </head>
> >> >> >> > ?>.<br />
> >> >> >> > <?php
> "POST")? $_POST:
> >> >> >> $_GET;
> >> >> >> > try
> connect to the
> >> >> >> Server using
> stored in
> >> >> >> PHP session
> >> >> >> > state.
> >> >> >> > $userInfo = new MgUserInformation($sessionId);
> >> >> >> > $map->Open($mapName);
> District 1
> >> >> >> > $layer =
> >> >> >> > $featureReader =
> >> >> >> > $districtGeometry =
> features.
> >> >> >> Combine
> >> >> >> > $queryOptions->SetSpatialFilter('SHPGEOM',
> >> >> >> $districtGeometry,
> selection
> >> >> >> as XML.
> >> >> >> > $featureReader =
> $featureReader, 0);
> >> >> >> > </body>
> >> >> >> > </script>
> >> >> >> > </body>
> >> >> >> > </html>
> >> >> >> > *This code..But when i enter the panId in the
> form this
> >> >> >> error is occuring
> "javascript:getsession()" The
> >> >> >> session ID is
> was not
> >> >> >> found.Invalid
> >> >> >> > argument(s): [1] = "javascript:getsession()" The
> session ID
> >> >> >> is invalid
> found.
> >> >> >> Exception occurred
> >> >> >> > in
> 183 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
> >> >> >> > Any mistake in my coding?????
> >> >> >> > Help me plss
> >> >> >> > regards
> >> >> >> > susan
> >> >> >> > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
> >> >> >> > <dave.wilson at autodesk.com
> <mailto:dave.wilson at autodesk.com>
> <mailto:dave.wilson at autodesk.com>>>wrote:
> >> >> >> >> Did you check out the samples in the downloads
> area of
> >> >> >> Osgeo?
> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> >> >> >> >> Dave
> >> >> >> >> *From:* mapguide-users-bounces at lists.osgeo.org
> <mailto:mapguide-users-bounces at lists.osgeo.org>> [mailto:
> <mailto:mapguide-users-bounces at lists.osgeo.org>>] *On Behalf
> >> >> >> Of *Ivan Milicevic
> >> >> >> >> *Sent:* Wednesday, April 22, 2009 1:52 AM
> >> >> >> >> *To:* MapGuide Users Mail List
> >> >> >> >> *Subject:* RE: [mapguide-users] select the
> location on map
> >> >> >> >> You can get it from some of them. Please, read
> >> >> >> descritption.
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Wednesday, April 22, 2009 9:46 AM
> >> >> >> >> *Subject:* Re: [mapguide-users] select the
> location on map
> >> >> >> >> Thank u....
> >> >> >> >> Can i get the source code of any
> of these
> >> >> >> sample
> >> >> >> >> applications? If so from where?
> >> >> >> >> regards
> >> >> >> >> susan
> >> >> >> >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
> >> >> >> >> Ivan.Milicevic at supranet.hr
> <mailto:Ivan.Milicevic at supranet.hr>
> <mailto:Ivan.Milicevic at supranet.hr>>> wrote:
> >> >> >> >> http://mapguide.osgeo.org/livegallery.html
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Wednesday, April 22, 2009 8:06 AM
> location on map
> >> >> >> >> hi deve
> >> >> >> >> I couldn't find that sample
> application.Any
> >> >> >> link?
> >> >> >> >> regards
> >> >> >> >> susan
> >> >> >> >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
> <mailto:dave.wilson at autodesk.com> <mailto:dave.wilson at autodesk.com
> >> >> >> >> wrote:
> >> >> >> >> The sample application that does the Find
> Address does a
> >> >> >> selection on the
> >> >> >> >> map when you click on one of the search
> results. I thought
> >> >> >> this was
> >> >> >> >> discussed in the Sample Application.
> >> >> >> >> Dave
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Monday, April 20, 2009 12:18 AM
> location on map
> >> >> >> >> hi alll...........
> >> >> >> >> I read the dev guide but
> didn't get any
> >> >> >> idea regarding
> >> >> >> >> this.Hav anyone tried this before pls give me
> any hint how
> >> >> >> to start this
> >> >> >> >> thanks ®ards
> >> >> >> >> susan
> >> >> >> >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
> >> >> >> >> wrote:
> >> >> >> >> Have you read through the developer’s guide? It
> has sample
> >> >> >> code for
> >> >> >> >> selection and explains many concepts. It sounds
> like you
> >> >> >> need to make
> >> >> >> >> either
> >> >> >> >> an invoke script or invoke url call from a
> command in your
> >> >> >> Basic or
> >> >> >> >> Flexible
> >> >> >> >> Web Layout. You don’t actually have to replace the
> >> >> >> gettingstarted.php. In
> >> >> >> >> the invoke script or invoke url command allows
> you to
> >> >> >> specify the target
> >> >> >> >> frame for the output of the script.
> >> >> >> >> Regards,
> >> >> >> >> Dave
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Friday, April 17, 2009 3:57 AM
> location on map
> >> >> >> >> yeah...i know that..
> >> >> >> >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
> >> >> >> >> Did you know how to create file that display's
> database
> >> >> >> table? If you
> >> >> >> >> don't
> >> >> >> >> know that you must find help somewhere else
> because I'm
> >> >> >> not a PHP guy.
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Friday, April 17, 2009 11:42 AM
> location on map
> >> >> >> >> Hi..
> >> >> >> >> No i dont have the file that displays database
> >> >> >> table...Actually iam
> >> >> >> >> doing this prjct in php.but i know javascript'
> >> >> >> >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
> >> >> >> >> Ok, so you have file that display's data from your
> >> >> >> database table? Or you
> >> >> >> >> don't have it at all? How familiar are you with
> >> >> >> javascript?
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Friday, April 17, 2009 11:13 AM
> location on map
> >> >> >> >> hi...
> >> >> >> >> My problem is that..
> >> >> >> >> I have a database table..Having colums
> place ,id etc
> >> >> >> .If
> >> >> >> i
> >> >> >> >> selected(clicking) a data in the table the
> corresponding
> >> >> >> place(polygon)
> >> >> >> >> should be displayed(selected) on the map...My
> map is a
> >> >> >> polygon map .each
> >> >> >> >> polygon having unique id.and the same id is
> present in the
> >> >> >> db table
> >> >> >> >> also....Now u got it?any idea please help...
> >> >> >> >> regards
> >> >> >> >> susan
> >> >> >> >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
> >> >> >> >> I'm not sure that I understand your problem.
> With this
> >> >> >> code you can
> >> >> >> >> select
> >> >> >> >> any feature on map. Can you send a little bit more
> >> >> >> information? I'm clues
> >> >> >> >> over there.
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Friday, April 17, 2009 10:47 AM
> location on map
> >> >> >> >> thank you ivan...
> >> >> >> >> on which file i have to
> write this
> >> >> >> coding??? any
> >> >> >> >> idea??
> >> >> >> >> regards
> >> >> >> >> susan
> >> >> >> >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
> >> >> >> >> OBJEKTI is layer name and other thing is path
> to the
> >> >> >> feature source.
> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
> >> >> >> >> You can copy/paste feature source from mapguide
> maestro in
> >> >> >> layer
> >> >> >> >> definition
> >> >> >> >> window.
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Friday, April 17, 2009 9:45 AM
> location on map
> >> >> >> >> thank you Ivan
> >> >> >> >> but i 'd like to know on which file i want to
> write this
> >> >> >> coding??
> >> >> >> >> In ur coding OBJEKT1 is layer name right?then
> what is
> >> >> >> this
> >> >> >> >> "Library://PROJEKTI/" + TIMgisUser +
> >> >> >> "/PODACI/OBJEKTI.FeatureSource");
> >> >> >> >> thanks and regards
> >> >> >> >> susan
> >> >> >> >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
> >> >> >> >> Hello Susan,
> >> >> >> >> Here is C# code for selection, it's pretty same
> as PHP.
> >> >> >> >> MgSiteConnection siteConnection = null;
> >> >> >> >> InitializeWebTier();
> >> >> >> >> MgUserInformation userInfo = new
> >> >> >> MgUserInformation(mgSessionId);
> >> >> >> >> siteConnection.Open(userInfo);
> >> >> >> >> MgResourceService resourceService =
> >> >> >> siteConnection.CreateService(
> >> >> >> >> MgServiceType.ResourceService) as
> MgResourceService;
> >> >> >> >> MgFeatureService featureService =
> >> >> >> >> MgServiceType.FeatureService) as MgFeatureService;
> >> >> >> >> MgMap map = new MgMap();
> >> >> >> >> map.Open(resourceService, "1"); //opening
> map with
> >> >> >> name „1“
> >> >> >> >> MgFeatureQueryOptions queryOptionsObjekti = new
> >> >> >> >> MgAgfReaderWriter geometryReaderWriter = new
> >> >> >> >> MgSelection selection = new MgSelection(map);
> >> >> >> >> //Defining layer and feature source
> >> >> >> >> MgLayer layerObjekti = GetLayerByName(map,
> "OBJEKTI");
> >> >> >> >> MgResourceIdentifier featureResIdObjekti = new
> >> >> >> MgResourceIdentifier(
> >> >> >> >> //Creating feature filter, this is very
> important
> >> >> >> step!
> >> >> >> >> string filter = "ID=" + idO;
> >> >> >> >> queryOptionsObjekti.SetFilter(filter);
> >> >> >> >> MgFeatureReader featureReaderObjekti =
> >> >> >> featureService.SelectFeatures(
> >> >> >> >> featureResIdObjekti, "OBJEKTI",
> queryOptionsObjekti);
> >> >> >> >> selection.AddFeatures(layerObjekti,
> >> >> >> featureReaderObjekti, 1);
> >> >> >> >> selection.Save(resourceService, "1");
> >> >> >> >> StringReader stream = new
> >> >> >> StringReader(selection.ToXml());
> >> >> >> >> string selectionXml = selection.ToXml();
> >> >> >> >> featureReaderObjekti.Close();
> >> >> >> >> map.Save();
> >> >> >> >> //Here, you call javascript function and
> pass the
> >> >> >> selection var
> >> >> >> >> Response.Write("<script>select('" +
> selectionXml +
> >> >> >> "');</script>");
> >> >> >> >> //This is javascript function that set's the
> selection
> >> >> >> from code and do
> >> >> >> >> the
> >> >> >> >> refresh.
> >> >> >> >> function select(xml)
> >> >> >> >> parent.mapFrame.SetSelectionXML(xml);
> >> >> >> >> parent.mapFrame.ExecuteMapAction(10);
> >> >> >> Of *susan Daniel
> >> >> >> >> *Sent:* Friday, April 17, 2009 9:11 AM
> >> >> >> >> *To:* mapguide-users at lists.osgeo.org
> <mailto:mapguide-users at lists.osgeo.org>
> <mailto:mapguide-users at lists.osgeo.org>>
> >> >> >> >> *Subject:* [mapguide-users] select the location
> on map
> >> >> >> >> hi all
> >> >> >> >> My plat form is mapguide maestro&php.I
> connect it
> >> >> >> with mysql.Now
> >> >> >> >> i
> >> >> >> >> want to select the corresponding polygon on the
> map while
> >> >> >> clicking on the
> >> >> >> >> data in database.In order to display the
> database table in
> >> >> >> the taskpane,i
> >> >> >> >> removed the contents of the file
> "/mapviewerphp/getting
> >> >> >> started .php" and
> >> >> >> >> wrote my codings.then how to select the
> polygon?.Any one
> >> >> >> know
> >> >> >> >> this????Anyone
> >> >> >> >> having coding to do this???
> >> >> >> >> please help me
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> _______________________________________________
> >> >> >> >> mapguide-users mailing list
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> >> thanks®ards
> >> >> >> >> susan
> >> >> >> > thanks®ards
> >> >> >> > susan
> >> >> >> View this message in context:
> http://n2.nabble.com/select-the-location-on-map-tp2649765p2691346.html
> >> >> >> Sent from the MapGuide Users mailing list archive at
> >> >> >> Nabble.com.
> >> >> >> -- thanks®ards
> >> >> >> susan
> mapguide-users
> >> >> >> mailing list mapguide-users at lists.osgeo.org
> >> >> >> thanks®ards
> >> >> >> susan
> >> >> >> thanks®ards
> >> >> >> susan
> >> >> > thanks®ards
> >> >> > susan
> >> >> Zac Spitzer -
> >> >> http://zacster.blogspot.com
> >> >> +61 405 847 168
> >> > thanks®ards
> >> > susan
> >> Zac Spitzer -
> >> +61 405 847 168
> > thanks®ards
> > susan
> Zac Spitzer -
> +61 405 847 168
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> thanks®ards
> susan
