[mapguide-users] select the location on map
susan Daniel
daniel.susan6 at gmail.com
Tue May 5 07:15:53 EDT 2009
Thank you stefan....
I got the sessionId and mapname....
now when i entered the panId this error is occuring
T*he specified object was not found.The specified object was not found.
Exception occurred in method GetItem at line 117 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\foundation\Data/NamedCollection.cpp
*that may be the problem of the code in selectlocation.php.I copied it from
devguide (page 53) and changed like this
$districtQuery = new MgFeatureQueryOptions();
$districtQuery->SetFilter("pan_id=$ID");
$layer = $map->GetLayers()->GetItem('panchayat');
$featureReader = $layer->SelectFeatures($districtQuery);
$featureReader->ReadNext();
$districtGeometryData = $featureReader->
GetGeometry('Data');
// Convert the AGF binary data to MgGeometry.
$agfReaderWriter = new MgAgfReaderWriter();
$districtGeometry = $agfReaderWriter->Read($districtGeometryData);
// Create a filter to select the desired features. Combine
// a basic filter and a spatial filter.
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetFilter("pan_id=$ID");
$queryOptions->SetSpatialFilter('panchayat', $districtGeometry,
MgFeatureSpatialOperations::Inside);
// Get the features from the feature source,
// turn it into a selection, then save the selection as XML.
$layer = $map->GetLayers()->GetItem(0);
$featureReader = $layer->SelectFeatures($queryOptions);
$selection = new MgSelection($map);
$selection->AddFeatures($layer, $featureReader, 0);
$selectionXml = $selection->ToXml();
I*n this" panchayat" is my layer name and each polygon in the layer having a
unique id "pan_id".
Is it correct???
* thanks ®ards
susan
On Tue, May 5, 2009 at 3:54 PM, Stefan Dalakov <s.dalakov at mapware.net>wrote:
> Hi Susan,
> this one for sure works :
> <head>
> <script language="javascript">
> function MyOnLoad ()
> document.myform.SESSION.value=parent.parent.mapFrame.GetSessionId();;
> document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;;
> </script>
> </head>
> <body onLoad="MyOnLoad()">
> <form name="myform" action="selectlocation.php" method="get">
> Enter PanId <input type="text" name="PanId"/><br><br>
> <input type="hidden" name="SESSION" value=""/>
> <input type="hidden" name="MAPNAME" value=""/>
> <input type="submit" value="Submit" />
> </form>
> <br><br>
> </body>
> If it doesn't work just check references to mapFrame -
> parent.parent.mapFrame or parent.mapFrame - depends from where you are
> calling it.
> Setselection.php needs to get these values from the calling routine from
> client side - there is no way for setselection to guess the session id of
> the caller
> Stefan Dalakov
> susan Daniel wrote:
>> hi all..
>> can i give this sessionId and mapname directly in
>> selectlocation.php page.If so how???
>> thanka®ards
>> susan
>> On Tue, May 5, 2009 at 11:10 AM, Zac Spitzer <zac.spitzer at gmail.com<mailto:
>> zac.spitzer at gmail.com>> wrote:
>> that looks right
>> try using fiddler to monitor track what is being passed back up to
>> the server
>> r u using firefox with firebug?
>> you could also add an
>> alert(Getsession());
>> to make sure the session id is being returned
>> On Tue, May 5, 2009 at 3:35 PM, susan Daniel
>> <daniel.susan6 at gmail.com <mailto:daniel.susan6 at gmail.com>> wrote:
>> > hi......
>> > Did u mean like this
>> > <form action="selectlocation.php" method="GET">
>> > <input type="hidden" name="SESSION" id="mg_session" value=""/ >
>> > document.getElementById('mg_session').value=Getsession();
>> > </script>
>> > </form>
>> > but still the error is occuring...
>> > the error is like this
>> > Invalid argument(s): [1] = "" The session ID is invalid because
>> the session
>> > separator character was not found.Invalid argument(s): [1] = ""
>> The session
>> > ID is invalid because the session separator character was not found.
>> > Exception occurred in method MgUserInformation.SetMgSessionId at
>> line 183 in
>> > file d:\buildforgeprojects\mapguide_open_source
>> > Do u know what is this session separator character????
>> > thanks®ards
>> > susan
>> > On Tue, May 5, 2009 at 10:44 AM, Zac Spitzer
>> <zac.spitzer at gmail.com <mailto:zac.spitzer at gmail.com>> wrote:
>> >> you changed the order!
>> >> what you have done is try to reference the hidden form field
>> before it
>> >> exists
>> >> z
>> >> On Tue, May 5, 2009 at 3:02 PM, susan Daniel
>> >> wrote:
>> >> > hi zac...
>> >> > It is also not working......
>> >> > This is the code
>> >> > <body>
>> >> > <script>
>> >> > </script>
>> >> > <form action="selectlocation.php" method="get">
>> >> > </form>
>> >> > and in selectlocation.php i'm having this code:
>> >> > <?php $ID= $_GET['PanId'];
>> >> > ?><br />
>> >> > <body class="AppFrame" onLoad="OnPageLoad()">
>> >> > <h1 class="AppHeading">Select features</h1>
>> >> > <?php
>> >> > include '../common/common.php';
>> >> > $args = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST:
>> $_GET;
>> >> > $sessionId = $args['SESSION'];
>> >> > $mapName = $args['MAPNAME'];
>> >> > try
>> >> > // Initialize the Web Extensions and connect to the
>> Server using
>> >> > // the Web Extensions session identifier stored in PHP
>> session
>> >> > state.
>> >> > MgInitializeWebTier ($webconfigFilePath);
>> >> > $userInfo = new MgUserInformation($sessionId );
>> >> > $siteConnection = new MgSiteConnection();
>> >> > $siteConnection->Open($userInfo);
>> >> > $map = new MgMap($siteConnection);
>> >> > $map->Open( $mapName );
>> >> > // Get the geometry for the boundaries of District 1
>> >> > $districtQuery->SetFilter("pan_id==$ID");
>> >> > $layer = $map->GetLayers()->GetItem('Panchayat');
>> >> > $districtGeometry =
>> $districtGeometry,
>> XML.
>> >> > catch (MgException $e)
>> >> > echo $e->GetMessage();
>> >> > echo $e->GetDetails();
>> >> > </body>
>> >> > function OnPageLoad()
>> >> > selectionXml = '<?php echo $selectionXml; ?>';
>> >> > parent.parent.SetSelectionXML(selectionXml);
>> >> > </script>
>> >> > </body>
>> >> > </html>
>> >> > Can u find any error in this?????
>> >> > regards
>> >> > susan
>> >> > On Tue, May 5, 2009 at 10:14 AM, Zac Spitzer
>> >> > wrote:
>> >> >> quicky n dirty but it should work
>> >> >> <script>
>> >> >> </script>
>> >> >> On Tue, May 5, 2009 at 2:39 PM, susan Daniel
>> >> >> wrote:
>> >> >> > hi chris
>> >> >> > I removed that quotes .but the same error
>> occurred..Anyone
>> >> >> > know
>> >> >> > any
>> >> >> > other method to pass this SessionId &mapname???
>> >> >> > help me plsssss
>> >> >> > regards
>> >> >> > susan
>> >> >> > On Mon, May 4, 2009 at 8:07 PM, Chris Claydon
>> >> >> > <chris.claydon at autodesk.com
>> <mailto:chris.claydon at autodesk.com>>
>> >> >> > wrote:
>> >> >> >> It looks like this field <input type="hidden"name="SESSION"
>> >> >> >> value="javascript:Getsession()"/ >
>> >> >> >> is using the string “javascript:Getsession()” rather than
>> actually
>> >> >> >> calling
>> >> >> >> the method and setting the value to the id that is returned.
>> >> >> >> If you remove the quotes, what happens then?
>> >> >> >> Chris.
>> >> >> >> From: mapguide-users-bounces at lists.osgeo.org
>> <mailto:mapguide-users-bounces at lists.osgeo.org>
>> >> >> >> [mailto:mapguide-users-bounces at lists.osgeo.org
>> <mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of susan
>> >> >> >> Daniel
>> >> >> >> Sent: Sunday, May 03, 2009 10:09 PM
>> >> >> >> To: MapGuide Users Mail List
>> >> >> >> Subject: Re: [mapguide-users] select the location on map
>> >> >> >> hi....
>> >> >> >> Still the same error ....
>> >> >> >> Invalid argument(s): [1] = "javascript:Getsession()" The
>> session ID
>> >> >> >> is
>> >> >> >> found.Invalid
>> >> >> >> argument(s): [1] = "javascript:Getsession()" The session
>> ID is
>> >> >> >> invalid
>> Exception
>> >> >> >> occurred in
>> >> >> >> method MgUserInformation.SetMgSessionId at line 183 in file
>> >> >> >> my code in window.php:
>> >> >> >> <body>
>> >> >> >> <script language="javascript"type="javasript/text">
>> >> >> >> function Getsession()
>> document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
>> >> >> >> function Getmapname()
>> >> >> >> </script>
>> >> >> >> <input type="hidden"name="MAPNAME"
>> value="javascript:Getmapname()"/
>> >> >> >> </form>
>> >> >> >> <br><br>
>> >> >> >> Tf anyone having any idea plsss help.....I tried a lot
>> >> >> >> thanks®ards
>> >> >> >> susan
>> >> >> >> On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov
>> >> >> >> <s.dalakov at mapware.net <mailto:s.dalakov at mapware.net>>
>> >> >> >> wrote:
>> >> >> >> You could use something like this (executed when
>> window.php is
>> >> >> >> loaded)
>> >> >> >> Stefan
>> >> >> >> susan Daniel wrote:
>> >> >> >> hi..all
>> >> >> >> Then what i have to do?Any solution to pass these
>> sessionId
>> >> >> >> and
>> >> >> >> mapname ????
>> >> >> >> regards
>> >> >> >> susan
>> >> >> >> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov
>> <mailto:s.dalakov at mapware.net>>> wrote:
>> >> >> >> These javascript.functions never get executed. I
>> checked now, I
>> >> >> >> added some "alert"s and they didn't show.
>> >> >> >> susan Daniel wrote:
>> >> >> >> HI..
>> >> >> >> I removed that brace but still the error is there
>> >> >> >> regards
>> >> >> >> susan
>> >> >> >> On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
>> >> >> >> <jumpinjackie at gmail.com
>> <mailto:jumpinjackie at gmail.com> <mailto:jumpinjackie at gmail.com
>> <mailto:jumpinjackie at gmail.com>>> wrote:
>> >> >> >> I see an extra brace (the very first one) in the
>> javascript
>> >> >> >> block that could
>> >> >> >> be messing everything up.
>> >> >> >> - Jackie
>> >> >> >> SusanDaniel wrote:
>> >> >> >> > hi all
>> >> >> >> > In order to display a form in the task
>> pane i've
>> >> >> >> the following
>> >> >> >> > code
>> >> >> >> > in "....../mapviewerphp/window.php"
>> >> >> >> > <body>
>> >> >> >> > function getsession()
>> >> >> >> > sessionId=parent.parent.mapframe.GetSessionId();
>> >> >> >> > function getmapname()
>> >> >> >> > mapname=parent.parent.mapframe.GetMapName();
>> >> >> >> > </script>
>> >> >> >> value="javascript:getsession()"/ >
>> >> >> >> value="javascript:getmapname()"/ >
>> >> >> >> > </form>
>> >> >> >> > *and in the selectlocation .php i am having
>> >> >> >> > </head>
>> >> >> >> > ?>.<br />
>> >> >> >> > <?php
>> "POST")? $_POST:
>> >> >> >> $_GET;
>> >> >> >> > try
>> connect to the
>> >> >> >> Server using
>> stored in
>> >> >> >> PHP session
>> >> >> >> > state.
>> >> >> >> > $userInfo = new MgUserInformation($sessionId);
>> >> >> >> > $map->Open($mapName);
>> District 1
>> >> >> >> > $layer =
>> >> >> >> > $featureReader =
>> >> >> >> > $districtGeometry =
>> features.
>> >> >> >> Combine
>> >> >> >> > $queryOptions->SetSpatialFilter('SHPGEOM',
>> >> >> >> $districtGeometry,
>> selection
>> >> >> >> as XML.
>> >> >> >> > $featureReader =
>> $featureReader, 0);
>> >> >> >> > </body>
>> >> >> >> > </script>
>> >> >> >> > </body>
>> >> >> >> > </html>
>> >> >> >> > *This code..But when i enter the panId in the
>> form this
>> >> >> >> error is occuring
>> "javascript:getsession()" The
>> >> >> >> session ID is
>> was not
>> >> >> >> found.Invalid
>> >> >> >> > argument(s): [1] = "javascript:getsession()" The
>> session ID
>> >> >> >> is invalid
>> found.
>> >> >> >> Exception occurred
>> >> >> >> > in
>> 183 in file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
>> >> >> >> > Any mistake in my coding?????
>> >> >> >> > Help me plss
>> >> >> >> > regards
>> >> >> >> > susan
>> >> >> >> > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
>> >> >> >> > <dave.wilson at autodesk.com
>> <mailto:dave.wilson at autodesk.com>
>> <mailto:dave.wilson at autodesk.com>>>wrote:
>> >> >> >> >> Did you check out the samples in the downloads
>> area of
>> >> >> >> Osgeo?
>> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>> >> >> >> >> Dave
>> >> >> >> >> *From:* mapguide-users-bounces at lists.osgeo.org
>> <mailto:mapguide-users-bounces at lists.osgeo.org>> [mailto:
>> <mailto:mapguide-users-bounces at lists.osgeo.org>>] *On Behalf
>> >> >> >> Of *Ivan Milicevic
>> >> >> >> >> *Sent:* Wednesday, April 22, 2009 1:52 AM
>> >> >> >> >> *To:* MapGuide Users Mail List
>> >> >> >> >> *Subject:* RE: [mapguide-users] select the
>> location on map
>> >> >> >> >> You can get it from some of them. Please, read
>> >> >> >> descritption.
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Wednesday, April 22, 2009 9:46 AM
>> >> >> >> >> *Subject:* Re: [mapguide-users] select the
>> location on map
>> >> >> >> >> Thank u....
>> >> >> >> >> Can i get the source code of any
>> of these
>> >> >> >> sample
>> >> >> >> >> applications? If so from where?
>> >> >> >> >> regards
>> >> >> >> >> susan
>> >> >> >> >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic <
>> >> >> >> >> Ivan.Milicevic at supranet.hr
>> <mailto:Ivan.Milicevic at supranet.hr>
>> <mailto:Ivan.Milicevic at supranet.hr>>> wrote:
>> >> >> >> >> http://mapguide.osgeo.org/livegallery.html
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Wednesday, April 22, 2009 8:06 AM
>> location on map
>> >> >> >> >> hi deve
>> >> >> >> >> I couldn't find that sample
>> application.Any
>> >> >> >> link?
>> >> >> >> >> regards
>> >> >> >> >> susan
>> >> >> >> >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
>> <mailto:dave.wilson at autodesk.com> <mailto:dave.wilson at autodesk.com
>> >> >> >> >> wrote:
>> >> >> >> >> The sample application that does the Find
>> Address does a
>> >> >> >> selection on the
>> >> >> >> >> map when you click on one of the search
>> results. I thought
>> >> >> >> this was
>> >> >> >> >> discussed in the Sample Application.
>> >> >> >> >> Dave
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Monday, April 20, 2009 12:18 AM
>> location on map
>> >> >> >> >> hi alll...........
>> >> >> >> >> I read the dev guide but
>> didn't get any
>> >> >> >> idea regarding
>> >> >> >> >> this.Hav anyone tried this before pls give me
>> any hint how
>> >> >> >> to start this
>> >> >> >> >> thanks ®ards
>> >> >> >> >> susan
>> >> >> >> >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>> >> >> >> >> wrote:
>> >> >> >> >> Have you read through the developer’s guide? It
>> has sample
>> >> >> >> code for
>> >> >> >> >> selection and explains many concepts. It sounds
>> like you
>> >> >> >> need to make
>> >> >> >> >> either
>> >> >> >> >> an invoke script or invoke url call from a
>> command in your
>> >> >> >> Basic or
>> >> >> >> >> Flexible
>> >> >> >> >> Web Layout. You don’t actually have to replace the
>> >> >> >> gettingstarted.php. In
>> >> >> >> >> the invoke script or invoke url command allows
>> you to
>> >> >> >> specify the target
>> >> >> >> >> frame for the output of the script.
>> >> >> >> >> Regards,
>> >> >> >> >> Dave
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Friday, April 17, 2009 3:57 AM
>> location on map
>> >> >> >> >> yeah...i know that..
>> >> >> >> >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
>> >> >> >> >> Did you know how to create file that display's
>> database
>> >> >> >> table? If you
>> >> >> >> >> don't
>> >> >> >> >> know that you must find help somewhere else
>> because I'm
>> >> >> >> not a PHP guy.
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Friday, April 17, 2009 11:42 AM
>> location on map
>> >> >> >> >> Hi..
>> >> >> >> >> No i dont have the file that displays database
>> >> >> >> table...Actually iam
>> >> >> >> >> doing this prjct in php.but i know javascript'
>> >> >> >> >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
>> >> >> >> >> Ok, so you have file that display's data from your
>> >> >> >> database table? Or you
>> >> >> >> >> don't have it at all? How familiar are you with
>> >> >> >> javascript?
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Friday, April 17, 2009 11:13 AM
>> location on map
>> >> >> >> >> hi...
>> >> >> >> >> My problem is that..
>> >> >> >> >> I have a database table..Having colums
>> place ,id etc
>> >> >> >> .If
>> >> >> >> i
>> >> >> >> >> selected(clicking) a data in the table the
>> corresponding
>> >> >> >> place(polygon)
>> >> >> >> >> should be displayed(selected) on the map...My
>> map is a
>> >> >> >> polygon map .each
>> >> >> >> >> polygon having unique id.and the same id is
>> present in the
>> >> >> >> db table
>> >> >> >> >> also....Now u got it?any idea please help...
>> >> >> >> >> regards
>> >> >> >> >> susan
>> >> >> >> >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
>> >> >> >> >> I'm not sure that I understand your problem.
>> With this
>> >> >> >> code you can
>> >> >> >> >> select
>> >> >> >> >> any feature on map. Can you send a little bit more
>> >> >> >> information? I'm clues
>> >> >> >> >> over there.
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Friday, April 17, 2009 10:47 AM
>> location on map
>> >> >> >> >> thank you ivan...
>> >> >> >> >> on which file i have to
>> write this
>> >> >> >> coding??? any
>> >> >> >> >> idea??
>> >> >> >> >> regards
>> >> >> >> >> susan
>> >> >> >> >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
>> >> >> >> >> OBJEKTI is layer name and other thing is path
>> to the
>> >> >> >> feature source.
>> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>> >> >> >> >> You can copy/paste feature source from mapguide
>> maestro in
>> >> >> >> layer
>> >> >> >> >> definition
>> >> >> >> >> window.
>> >> >> >> Of *susan Daniel
>> >> >> >> >> *Sent:* Friday, April 17, 2009 9:45 AM
>> location on map
>> >> >> >> >> thank you Ivan
>> >> >> >> >> but i 'd like to know on which file i want to
>> write this
>> >> >> >> coding??
>> >> >> >> >> In ur coding OBJEKT1 is layer name right?then
>> what is
>> >> >> >> this
>> >> >> >> >> "Library://PROJEKTI/" + TIMgisUser +
>> >> >> >> "/PODACI/OBJEKTI.FeatureSource");
>> >> >> >> >> thanks and regards
>> >> >> >> >> susan
>> >> >> >> >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
>> >> >> >> >> Hello Susan,
>> >> >> >> >> Here is C# code for selection, it's pretty same
>> as PHP.
>> >> >> >> >> MgSiteConnection siteConnection = null;
>> >> >> >> >> InitializeWebTier();
>> >> >> >> >> MgUserInformation userInfo = new
>> >> >> >> MgUserInformation(mgSessionId);
>> >> >> >> >> siteConnection.Open(userInfo);
>> >> >> >> >> MgResourceService resourceService =
>> >> >> >> siteConnection.CreateService(
>> >> >> >> >> MgServiceType.ResourceService) as
>> MgResourceService;
>> >> >> >> >> MgFeatureService featureService =
>> >> >> >> >> MgServiceType.FeatureService) as MgFeatureService;
>> >> >> >> >> MgMap map = new MgMap();
>> >> >> >> >> map.Open(resourceService, "1"); //opening
>> map with
>> >> >> >> name „1“
>> >> >> >> >> MgFeatureQueryOptions queryOptionsObjekti = new
>> >> >> >> >> MgAgfReaderWriter geometryReaderWriter = new
>> >> >> >> >> MgSelection selection = new MgSelection(map);
>> >> >> >> >> //Defining layer and feature source
>> >> >> >> >> MgLayer layerObjekti = GetLayerByName(map,
>> "OBJEKTI");
>> >> >> >> >> MgResourceIdentifier featureResIdObjekti = new
>> >> >> >> MgResourceIdentifier(
>> >> >> >> >> //Creating feature filter, this is very
>> important
>> >> >> >> step!
>> >> >> >> >> string filter = "ID=" + idO;
>> >> >> >> >> queryOptionsObjekti.SetFilter(filter);
>> >> >> >> >> MgFeatureReader featureReaderObjekti =
>> >> >> >> featureService.SelectFeatures(
>> >> >> >> >> featureResIdObjekti, "OBJEKTI",
>> queryOptionsObjekti);
>> >> >> >> >> selection.AddFeatures(layerObjekti,
>> >> >> >> featureReaderObjekti, 1);
>> >> >> >> >> selection.Save(resourceService, "1");
>> >> >> >> >> StringReader stream = new
>> >> >> >> StringReader(selection.ToXml());
>> >> >> >> >> string selectionXml = selection.ToXml();
>> >> >> >> >> featureReaderObjekti.Close();
>> >> >> >> >> map.Save();
>> >> >> >> >> //Here, you call javascript function and
>> pass the
>> >> >> >> selection var
>> >> >> >> >> Response.Write("<script>select('" +
>> selectionXml +
>> >> >> >> "');</script>");
>> >> >> >> >> //This is javascript function that set's the
>> selection
>> >> >> >> from code and do
>> >> >> >> >> the
>> >> >> >> >> refresh.
>> >> >> >> >> function select(xml)
>> >> >> >> >> parent.mapFrame.SetSelectionXML(xml);
>> >> >> >> >> parent.mapFrame.ExecuteMapAction(10);
>> >> >> >> <mailto: <mapguide-users-bounces at lists.osgeo.org>
> [Message clipped]
thanks®ards
susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090505/59d03081/attachment.html
