[mapguide-users] select the location on map
Stefan Dalakov s.dalakov at mapware.net
Tue May 5 07:28:22 EDT 2009
check layer name - it is case-sensitive, and don't get confused by layer
name and legend display name
Stefan Dalakov
susan Daniel wrote:
> Thank you stefan....
> I got the sessionId and mapname....
> now when i entered the panId this error is occuring
> T*he specified object was not found.The specified object was not
> found. Exception occurred in method GetItem at line 117 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\foundation\Data/NamedCollection.cpp
> *that may be the problem of the code in selectlocation.php.I copied it
> from devguide (page 53) and changed like this
> $districtQuery = new MgFeatureQueryOptions();
>       $districtQuery->SetFilter("pan_id=$ID");
>       $layer = $map->GetLayers()->GetItem('panchayat');
>       $featureReader = $layer->SelectFeatures($districtQuery);
>       $featureReader->ReadNext();
>       $districtGeometryData = $featureReader->
>       GetGeometry('Data');
>       // Convert the AGF binary data to MgGeometry.
>       $agfReaderWriter = new MgAgfReaderWriter();
>       $districtGeometry = $agfReaderWriter->Read($districtGeometryData);
>       // Create a filter to select the desired features. Combine
>       // a basic filter and a spatial filter.
>       $queryOptions = new MgFeatureQueryOptions();
>       $queryOptions->SetFilter("pan_id=$ID");
>       $queryOptions->SetSpatialFilter('panchayat', $districtGeometry,
> MgFeatureSpatialOperations::Inside);
>       // Get the features from the feature source,
>       // turn it into a selection, then save the selection as XML.
>       $layer = $map->GetLayers()->GetItem(0);
>       $featureReader = $layer->SelectFeatures($queryOptions);
>       $selection = new MgSelection($map);
>       $selection->AddFeatures($layer, $featureReader, 0);
>       $selectionXml = $selection->ToXml();
> I*n this" panchayat" is my layer name and each polygon in the layer
> having a unique id  "pan_id".
> Is it correct???
> * thanks &regards
> susan
> On Tue, May 5, 2009 at 3:54 PM, Stefan Dalakov <s.dalakov at mapware.net
> <mailto:s.dalakov at mapware.net>> wrote:
>     Hi Susan,
>     this one for sure works :
>     <head>
>     <script language="javascript">
>     function MyOnLoad ()
>     document.myform.SESSION.value=parent.parent.mapFrame.GetSessionId();;
>     document.myform.MAPNAME.value=parent.parent.mapFrame.GetMapName() ;;
>     </script>
>     </head>
>     <body onLoad="MyOnLoad()">
>     <form name="myform" action="selectlocation.php" method="get">
>     Enter PanId <input type="text" name="PanId"/><br><br>
>     <input type="hidden" name="SESSION" value=""/>
>     <input type="hidden" name="MAPNAME" value=""/>
>     <input type="submit" value="Submit" />
>     </form>
>     <br><br>
>     </body>
>     If it doesn't work just check references to mapFrame -
>     parent.parent.mapFrame or parent.mapFrame - depends from where you
>     are calling it.
>     Setselection.php needs to get these values from the calling
>     routine from client side - there is no way for setselection to
>     guess the session id of the caller
>     Stefan Dalakov
>     susan Daniel wrote:
>         hi all..
>                      can i give this sessionId and mapname directly in
>         selectlocation.php page.If so how???
>         thanka&regards
>         susan
>         On Tue, May 5, 2009 at 11:10 AM, Zac Spitzer
>         <zac.spitzer at gmail.com <mailto:zac.spitzer at gmail.com>
>         <mailto:zac.spitzer at gmail.com <mailto:zac.spitzer at gmail.com>>>
>         wrote:
>            that looks right
>            try using fiddler to monitor track what is being passed
>         back up to
>            the server
>            r u using firefox with firebug?
>            you could also add an
>            alert(Getsession());
>            to make sure the session id is being returned
>            On Tue, May 5, 2009 at 3:35 PM, susan Daniel
>            <daniel.susan6 at gmail.com <mailto:daniel.susan6 at gmail.com>
>         <mailto:daniel.susan6 at gmail.com>>> wrote:
>            > hi......
>            >              Did u mean like this
>            > <form action="selectlocation.php" method="GET">
>            > <input type="hidden" name="SESSION" id="mg_session"
>         value=""/ >
>          document.getElementById('mg_session').value=Getsession();
>            > </script>
>            > </form>
>            > but still the error is occuring...
>            > the error is like this
>            > Invalid argument(s): [1] = "" The session ID is invalid
>         because
>            the session
>            > separator character was not found.Invalid argument(s):
>         [1] = ""
>            The session
>            > ID is invalid because the session separator character was
>         not found.
>         MgUserInformation.SetMgSessionId at
>            line 183 in
>            > file d:\buildforgeprojects\mapguide_open_source
>            > Do u know what is this session separator character????
>            > thanks&regards
>            > susan
>            > On Tue, May 5, 2009 at 10:44 AM, Zac Spitzer
>         wrote:
>            >> you changed the order!
>            >> what you have done is try to reference the hidden form field
>            before it
>            >> exists
>            >> z
>            >> On Tue, May 5, 2009 at 3:02 PM, susan Daniel
>            >> wrote:
>            >> > hi zac...
>            >> >         It is also not working......
>            >> > This is the code
>            >> > <body>
>            >> > <script>
>            >> > </script>
>            >> > <form action="selectlocation.php" method="get">
>         value=""/ >
>            >> > </form>
>            >> > and in selectlocation.php i'm having this code:
>            >> > <?php $ID= $_GET['PanId'];
>            >> >    ?><br />
>            >> >   <body class="AppFrame" onLoad="OnPageLoad()">
>            >> >     <h1 class="AppHeading">Select features</h1>
>            >> >     <?php
>            >> >     include '../common/common.php';
>            >> >     $args = ($_SERVER['REQUEST_METHOD'] == "POST")?
>         $_POST:
>            $_GET;
>            >> >     $sessionId = $args['SESSION'];
>            >> >     $mapName = $args['MAPNAME'];
>            >> >     try
>            >> >       // Initialize the Web Extensions and connect to the
>            Server using
>            >> >       // the Web Extensions session identifier stored
>         in PHP
>            session
>            >> > state.
>            >> >       MgInitializeWebTier ($webconfigFilePath);
>            >> >       $userInfo = new MgUserInformation($sessionId  );
>            >> >       $siteConnection = new MgSiteConnection();
>            >> >       $siteConnection->Open($userInfo);
>            >> >       $map = new MgMap($siteConnection);
>            >> >       $map->Open( $mapName  );
>            >> >       // Get the geometry for the boundaries of District 1
>            >> >       $districtQuery->SetFilter("pan_id==$ID");
>            >> >       $layer = $map->GetLayers()->GetItem('Panchayat');
>            >> >       $featureReader =
>            >> >       $districtGeometry =
>         features. Combine
>            $districtGeometry,
>         selection as
>            XML.
>            >> >       $featureReader =
>            >> >     catch (MgException $e)
>            >> >       echo $e->GetMessage();
>            >> >       echo $e->GetDetails();
>            >> >   </body>
>            >> >     function OnPageLoad()
>            >> >       selectionXml = '<?php echo $selectionXml; ?>';
>            >> >       parent.parent.SetSelectionXML(selectionXml);
>            >> >   </script>
>            >> > </body>
>            >> > </html>
>            >> > Can u find any error in this?????
>            >> > regards
>            >> > susan
>            >> > On Tue, May 5, 2009 at 10:14 AM, Zac Spitzer
>            >> > wrote:
>            >> >> quicky n dirty but it should work
>         value=""/ >
>            >> >> <script>
>            >> >> </script>
>            >> >> On Tue, May 5, 2009 at 2:39 PM, susan Daniel
>            >> >> wrote:
>            >> >> > hi chris
>            >> >> >          I removed that quotes .but the same error
>            occurred..Anyone
>            >> >> > know
>            >> >> > any
>            >> >> > other method to pass this SessionId &mapname???
>            >> >> > help me plsssss
>            >> >> > regards
>            >> >> > susan
>            >> >> > On Mon, May 4, 2009 at 8:07 PM, Chris Claydon
>            >> >> > <chris.claydon at autodesk.com
>         <mailto:chris.claydon at autodesk.com>
>         <mailto:chris.claydon at autodesk.com>>>
>            >> >> > wrote:
>            >> >> >> It looks like this field <input
>         type="hidden"name="SESSION"
>            >> >> >> value="javascript:Getsession()"/ >
>            >> >> >> is using the string “javascript:Getsession()”
>         rather than
>            actually
>            >> >> >> calling
>            >> >> >> the method and setting the value to the id that is
>         returned.
>            >> >> >> If you remove the quotes, what happens then?
>            >> >> >> Chris.
>            >> >> >> From: mapguide-users-bounces at lists.osgeo.org
>         <mailto:mapguide-users-bounces at lists.osgeo.org>
>         <mailto:mapguide-users-bounces at lists.osgeo.org>>
>            >> >> >> [mailto:mapguide-users-bounces at lists.osgeo.org
>         <mailto:mapguide-users-bounces at lists.osgeo.org>>] On Behalf Of
>         susan
>            >> >> >> Daniel
>            >> >> >> Sent: Sunday, May 03, 2009 10:09 PM
>            >> >> >> To: MapGuide Users Mail List
>            >> >> >> Subject: Re: [mapguide-users] select the location
>         on map
>            >> >> >> hi....
>            >> >> >>       Still the same error ....
>         "javascript:Getsession()" The
>            session ID
>            >> >> >> is
>         was not
>            >> >> >> found.Invalid
>            >> >> >> argument(s): [1] = "javascript:Getsession()" The
>         session
>            ID is
>            >> >> >> invalid
>            >> >> >> because the session separator character was not found.
>            Exception
>            >> >> >> occurred in
>            >> >> >> method MgUserInformation.SetMgSessionId at line
>         183 in file
>            >> >> >> my code in window.php:
>            >> >> >> <body>
>            >> >> >> <script language="javascript"type="javasript/text">
>            >> >> >> function Getsession()
>         document.myform.SESSION.value=parent.parent.mapframe.GetSessionId();
>            >> >> >> function Getmapname()
>            >> >> >> </script>
>            >> >> >> <input type="hidden"name="SESSION"
>            >> >> >> <input type="hidden"name="MAPNAME"
>            value="javascript:Getmapname()"/
>            >> >> >> </form>
>            >> >> >> <br><br>
>            >> >> >> Tf anyone having any idea plsss help.....I tried a lot
>            >> >> >> thanks&regards
>            >> >> >> susan
>            >> >> >> On Fri, Apr 24, 2009 at 4:24 PM, Stefan Dalakov
>         <mailto:s.dalakov at mapware.net> <mailto:s.dalakov at mapware.net
>         <mailto:s.dalakov at mapware.net>>>
>            >> >> >> wrote:
>            >> >> >> You could use something like this (executed when
>            window.php is
>            >> >> >> loaded)
>            >> >> >> Stefan
>            >> >> >> susan Daniel wrote:
>            >> >> >> hi..all
>            >> >> >>       Then what i have to do?Any solution to pass
>         these
>            sessionId
>            >> >> >> and
>            >> >> >> mapname ????
>            >> >> >> regards
>            >> >> >> susan
>            >> >> >> On Fri, Apr 24, 2009 at 3:24 PM, Stefan Dalakov
>         <mailto:s.dalakov at mapware.net>>>> wrote:
>            >> >> >>    These javascript.functions never get executed. I
>            checked now, I
>            >> >> >>    added some "alert"s  and they didn't show.
>            >> >> >>    susan Daniel wrote:
>            >> >> >>    HI..
>            >> >> >>            I removed that brace but still the
>         error is there
>            >> >> >>    regards
>            >> >> >>    susan
>            >> >> >>    On Fri, Apr 24, 2009 at 2:35 PM, Jackie Ng
>            >> >> >>    <jumpinjackie at gmail.com
>         <mailto:jumpinjackie at gmail.com>
>         <mailto:jumpinjackie at gmail.com>>
>         <mailto:jumpinjackie at gmail.com <mailto:jumpinjackie at gmail.com>
>         <mailto:jumpinjackie at gmail.com>>>> wrote:
>            >> >> >>        I see an extra brace (the very first one)
>         in the
>            javascript
>            >> >> >>        block that could
>            >> >> >>        be messing everything up.
>            >> >> >>        - Jackie
>            >> >> >>        SusanDaniel wrote:
>            >> >> >>        > hi all
>            >> >> >>        >         In order to display a form in the
>         task
>            pane i've
>            >> >> >>        the following
>            >> >> >>        > code
>            >> >> >>        > in "....../mapviewerphp/window.php"
>            >> >> >>        > <body>
>            >> >> >>        > function getsession()
>         sessionId=parent.parent.mapframe.GetSessionId();
>            >> >> >>        > function getmapname()
>            >> >> >>        > mapname=parent.parent.mapframe.GetMapName();
>            >> >> >>        > </script>
>         method="get">
>            >> >> >>        value="javascript:getsession()"/ >
>            >> >> >>        value="javascript:getmapname()"/  >
>            >> >> >>        > </form>
>            >> >> >>        > *and in the selectlocation .php i am having
>            >> >> >>        >  </head>
>            >> >> >>        >     ?>.<br />
>         features</h1>
>            >> >> >>        >     <?php
>            "POST")? $_POST:
>            >> >> >>        $_GET;
>            >> >> >>        >     try
>            connect to the
>            >> >> >>        Server using
>         identifier
>            stored in
>            >> >> >>        PHP session
>            >> >> >>        > state.
>            >> >> >>        >       MgInitializeWebTier
>            >> >> >>        >       $userInfo = new
>         MgUserInformation($sessionId);
>         MgSiteConnection();
>            >> >> >>        >       $map->Open($mapName);
>         boundaries of
>            District 1
>            >> >> >>        >       $layer =
>            >> >> >>        >       $featureReader =
>         $featureReader->
>         MgGeometry.
>            >> >> >>        >       $districtGeometry =
>         desired
>            features.
>            >> >> >>        Combine
>            >> >> >>        >       $queryOptions = new
>         $queryOptions->SetSpatialFilter('SHPGEOM',
>            >> >> >>        $districtGeometry,
>         feature source,
>         save the
>            selection
>            >> >> >>        as XML.
>            >> >> >>        >       $featureReader =
>            $featureReader, 0);
>            >> >> >>        >   </body>
>         $selectionXml; ?>';
>            >> >> >>        >   </script>
>            >> >> >>        > </body>
>            >> >> >>        > </html>
>            >> >> >>        > *This code..But when i enter the panId in the
>            form this
>            >> >> >>        error is occuring
>            "javascript:getsession()" The
>            >> >> >>        session ID is
>         character
>            was not
>            >> >> >>        found.Invalid
>            >> >> >>        > argument(s): [1] =
>            session ID
>            >> >> >>        is invalid
>         was not
>            found.
>            >> >> >>        Exception occurred
>            >> >> >>        > in
>         at line
>            183 in file
>         d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\mapguidecommon\System/UserInformation.cpp
>            >> >> >>        > Any mistake in my coding?????
>            >> >> >>        > Help me plss
>            >> >> >>        > regards
>            >> >> >>        > susan
>            >> >> >>        > On Wed, Apr 22, 2009 at 9:01 PM, Dave Wilson
>            >> >> >>        > <dave.wilson at autodesk.com
>         <mailto:dave.wilson at autodesk.com>
>         <mailto:dave.wilson at autodesk.com>>
>         <mailto:dave.wilson at autodesk.com>>>>wrote:
>            >> >> >>        >>  Did you check out the samples in the
>         downloads
>            area of
>            >> >> >> Osgeo?
>            http://mapguide.osgeo.org/download/releases/2.0.x-samples
>            >> >> >>        >> Dave
>            >> >> >>        >> *From:*
>         <mailto:mapguide-users-bounces at lists.osgeo.org>>> [mailto:
>         <mailto:mapguide-users-bounces at lists.osgeo.org>>>] *On Behalf
>            >> >> >>        Of *Ivan Milicevic
>            >> >> >>        >> *Sent:* Wednesday, April 22, 2009 1:52 AM
>            >> >> >>        >> *To:* MapGuide Users Mail List
>            >> >> >>        >> *Subject:* RE: [mapguide-users] select the
>            location on map
>            >> >> >>        >> You can get it from some of them.
>         Please, read
>            >> >> >> descritption.
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Wednesday, April 22, 2009 9:46 AM
>            >> >> >>        >> *Subject:* Re: [mapguide-users] select the
>            location on map
>            >> >> >>        >> Thank u....
>            >> >> >>        >>                Can i get the source code
>         of any
>            of these
>            >> >> >>        sample
>            >> >> >>        >> applications? If so from where?
>            >> >> >>        >> regards
>            >> >> >>        >> susan
>            >> >> >>        >> On Wed, Apr 22, 2009 at 1:00 PM, Ivan
>         Milicevic <
>            >> >> >>        >> Ivan.Milicevic at supranet.hr
>         <mailto:Ivan.Milicevic at supranet.hr>
>         <mailto:Ivan.Milicevic at supranet.hr>>
>         <mailto:Ivan.Milicevic at supranet.hr>>>> wrote:
>            >> >> >>        >> http://mapguide.osgeo.org/livegallery.html
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Wednesday, April 22, 2009 8:06 AM
>            location on map
>            >> >> >>        >> hi deve
>            >> >> >>        >>            I couldn't find that sample
>            application.Any
>            >> >> >> link?
>            >> >> >>        >> regards
>            >> >> >>        >> susan
>            >> >> >>        >> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson
>            >> >> >>        >> wrote:
>            >> >> >>        >> The sample application that does the Find
>            Address does a
>            >> >> >>        selection on the
>            >> >> >>        >> map when you click on one of the search
>            results. I thought
>            >> >> >>        this was
>            >> >> >>        >> discussed in the Sample Application.
>            >> >> >>        >> Dave
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Monday, April 20, 2009 12:18 AM
>            location on map
>            >> >> >>        >> hi alll...........
>            >> >> >>        >>                   I read the dev guide but
>            didn't get any
>            >> >> >>        idea regarding
>            >> >> >>        >> this.Hav anyone tried this before pls
>         give me
>            any hint how
>            >> >> >>        to start this
>            >> >> >>        >> thanks &regards
>            >> >> >>        >> susan
>            >> >> >>        >> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson
>            >> >> >>        >> wrote:
>            >> >> >>        >> Have you read through the developer’s
>         guide? It
>            has sample
>            >> >> >>        code for
>            >> >> >>        >> selection and explains many concepts. It
>         sounds
>            like you
>            >> >> >>        need to make
>            >> >> >>        >> either
>            >> >> >>        >> an invoke script or invoke url call from a
>            command in your
>            >> >> >>        Basic or
>            >> >> >>        >> Flexible
>            >> >> >>        >> Web Layout. You don’t actually have to
>         replace the
>            >> >> >>        gettingstarted.php. In
>            >> >> >>        >> the invoke script or invoke url command
>         allows
>            you to
>            >> >> >>        specify the target
>            >> >> >>        >> frame for the output of the script.
>            >> >> >>        >> Regards,
>            >> >> >>        >> Dave
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Friday, April 17, 2009 3:57 AM
>            location on map
>            >> >> >>        >> yeah...i know that..
>            >> >> >>        >> On Fri, Apr 17, 2009 at 3:15 PM, Ivan
>         Milicevic <
>            >> >> >>        >> Did you know how to create file that
>         display's
>            database
>            >> >> >>        table? If you
>            >> >> >>        >> don't
>            >> >> >>        >> know that you must find help somewhere else
>            because I'm
>            >> >> >>        not a PHP guy.
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Friday, April 17, 2009 11:42 AM
>            location on map
>            >> >> >>        >> Hi..
>            >> >> >>        >>     No i dont have the file that
>         displays database
>            >> >> >>        table...Actually iam
>            >> >> >>        >> doing this prjct in php.but i know
>         javascript'
>            >> >> >>        >> On Fri, Apr 17, 2009 at 3:02 PM, Ivan
>         Milicevic <
>            >> >> >>        >> Ok, so you have file that display's data
>         from your
>            >> >> >>        database table? Or you
>            >> >> >>        >> don't have it at all? How familiar are
>         you with
>            >> >> >> javascript?
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Friday, April 17, 2009 11:13 AM
>            location on map
>            >> >> >>        >> hi...
>            >> >> >>        >>    My problem is that..
>            >> >> >>        >>    I have a database table..Having colums
>             place ,id etc
>            >> >> >> .If
>            >> >> >> i
>            >> >> >>        >> selected(clicking) a data in the table the
>            corresponding
>            >> >> >>        place(polygon)
>            >> >> >>        >> should be displayed(selected) on the
>         map...My
>            map is a
>            >> >> >>        polygon map .each
>            >> >> >>        >> polygon having unique id.and the same id is
>            present in the
>            >> >> >>        db table
>            >> >> >>        >> also....Now u got it?any idea please help...
>            >> >> >>        >> regards
>            >> >> >>        >> susan
>            >> >> >>        >> On Fri, Apr 17, 2009 at 2:24 PM, Ivan
>         Milicevic <
>            >> >> >>        >> I'm not sure that I understand your problem.
>            With this
>            >> >> >>        code you can
>            >> >> >>        >> select
>            >> >> >>        >> any feature on map. Can you send a
>         little bit more
>            >> >> >>        information? I'm clues
>            >> >> >>        >> over there.
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Friday, April 17, 2009 10:47 AM
>            location on map
>            >> >> >>        >> thank you  ivan...
>            >> >> >>        >>                        on which file i
>         have to
>            write this
>            >> >> >>        coding???  any
>            >> >> >>        >> idea??
>            >> >> >>        >> regards
>            >> >> >>        >> susan
>            >> >> >>        >> On Fri, Apr 17, 2009 at 2:09 PM, Ivan
>         Milicevic <
>            >> >> >>        >> OBJEKTI is layer name and other thing is
>         path
>            to the
>            >> >> >>        feature source.
>            "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
>            >> >> >>        >> You can copy/paste feature source from
>         mapguide
>            maestro in
>            >> >> >>        layer
>            >> >> >>        >> definition
>            >> >> >>        >> window.
>            >> >> >>        >> *From:*
>            >> >> >>        Of *susan Daniel
>            >> >> >>        >> *Sent:* Friday, April 17, 2009 9:45 AM
>            location on map
>            >> >> >>        >> thank you Ivan
>            >> >> >>        >> but  i 'd like to know on which file i
>         want to
>            write this
>            >> >> >>        coding??
>            >> >> >>        >> In ur coding OBJEKT1  is layer name
>         right?then
>            what is
>            >> >> >> this
>            >> >> >>        >> "Library://PROJEKTI/" + TIMgisUser +
>            >> >> >>        "/PODACI/OBJEKTI.FeatureSource");
>            >> >> >>        >> thanks and regards
>            >> >> >>        >> susan
>            >> >> >>        >> On Fri, Apr 17, 2009 at 12:46 PM, Ivan
>         Milicevic <
>            >> >> >>        >> Hello Susan,
>            >> >> >>        >> Here is C# code for selection, it's
>         pretty same
>            as PHP.
>            >> >> >>        >> MgSiteConnection siteConnection = null;
>            >> >> >>        >>     InitializeWebTier();
>            >> >> >>        >>     MgUserInformation userInfo = new
>            >> >> >>        MgUserInformation(mgSessionId);
>            >> >> >>        >>     siteConnection.Open(userInfo);
>            >> >> >>        >>     MgResourceService resourceService =
>            >> >> >>        siteConnection.CreateService(
>            >> >> >>        >> MgServiceType.ResourceService) as
>            MgResourceService;
>            >> >> >>        >>     MgFeatureService featureService =
>            >> >> >>        >> MgServiceType.FeatureService) as
>         MgFeatureService;
>            >> >> >>        >>     MgMap map = new MgMap();
>            >> >> >>        >>     map.Open(resourceService, "1");
>         //opening
>            map with
>            >> >> >>        name „1“
>         queryOptionsObjekti = new
>            >> >> >>        >>     MgAgfReaderWriter
>         geometryReaderWriter = new
>            >> >> >>        >>     MgSelection selection = new
>         MgSelection(map);
>            >> >> >>        >>     //Defining layer and feature source
>            >> >> >>        >>     MgLayer layerObjekti =
>         GetLayerByName(map,
>            "OBJEKTI");
>            >> >> >>        >>     MgResourceIdentifier
>         featureResIdObjekti = new
>            >> >> >>        MgResourceIdentifier(
>            >> >> >>        >>     //Creating feature filter, this is very
>            important
>            >> >> >> step!
>            >> >> >>        >>     string filter = "ID=" + idO;
>            >> >> >>        >>     queryOptionsObjekti.SetFilter(filter);
>            >> >> >>        >>     MgFeatureReader featureReaderObjekti =
>            >> >> >>        featureService.SelectFeatures(
>            >> >> >>        >> featureResIdObjekti, "OBJEKTI",
>            queryOptionsObjekti);
>            >> >> >>        >>     selection.AddFeatures(layerObjekti,
>            >> >> >>        featureReaderObjekti, 1);
>            >> >> >>        >>     selection.Save(resourceService, "1");
>            >> >> >>        >>     StringReader stream = new
>            >> >> >> StringReader(selection.ToXml());
>            >> >> >>        >>     string selectionXml = selection.ToXml();
>            >> >> >>        >>     featureReaderObjekti.Close();
>            >> >> >>        >>     map.Save();
>            >> >> >>        >>     //Here, you call javascript function and
>            pass the
>            >> >> >>        selection var
>            >> >> >>        >>     Response.Write("<script>select('" +
>            selectionXml +
>            >> >> >>        "');</script>");
>            >> >> >>        >> //This is javascript function that set's the
>            selection
>            >> >> >>        from code and do
>            >> >> >>        >> the
>            >> >> >>        >> refresh.
>            >> >> >>        >> function select(xml)
>            >> >> >>        >> parent.mapFrame.SetSelectionXML(xml);
>            >> >> >>        >> parent.mapFrame.ExecuteMapAction(10);
>            >> >> >>        >> *From:*
>            >> >> >>        <mailto:
>     [Message clipped]
> thanks&regards
>  susan
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
