[mapguide-users] setting filter
susan Daniel
daniel.susan6 at gmail.com
Wed May 6 01:03:49 EDT 2009
hi all.....
Anyone plzz help me to set the filter.I am having a feature source
with properties(pan_id,Name.,etc..).Now I wanna select the polygon from
the map having pan_id=ID.
The ID will be entered from the task pane. Here is my code:
*I copied it from dev guide..Then what is this this"SHPGEOM" in
setspatialfilter
<?php
include '../common/common.php';
$args = ($_SERVER['REQUEST_METHOD']=="GET")? $_GET: $_POST;
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
$ID= $_GET['PanId'];
try
// Initialize the Web Extensions and connect to the Server using
// the Web Extensions session identifier stored in PHP session state.
MgInitializeWebTier ($webconfigFilePath);
$userInfo = new MgUserInformation($sessionId );
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$map = new MgMap($siteConnection);
$map->Open( $mapName );
// Get the geometry for the boundaries of District
$districtQuery = new MgFeatureQueryOptions();
* $districtQuery->SetFilter("pan_id=$ID");*
$layer = $map->GetLayers()->GetItem(0);
$featureReader = $layer->SelectFeatures($districtQuery);
$featureReader->ReadNext();
$districtGeometryData = $featureReader->
GetGeometry('Data');
// Convert the AGF binary data to MgGeometry.
$agfReaderWriter = new MgAgfReaderWriter();
$districtGeometry = $agfReaderWriter->Read($districtGeometryData);
// Create a filter to select the desired features. Combine
// a basic filter and a spatial filter.
$queryOptions = new MgFeatureQueryOptions();
$*queryOptions->SetFilter("pan_id=$ID");
$queryOptions->SetSpatialFilter('SHPGEOM', $districtGeometry,
MgFeatureSpatialOperations::Inside);
// Get the features from the feature source,
// turn it into a selection, then save the selection as XML.
$featureReader = $layer->SelectFeatures($queryOptions);
$selection = new MgSelection($map);
$selection->AddFeatures($layer, $featureReader, 0);
$selectionXml = $selection->ToXml();
catch (MgException $e)
echo $e->GetMessage();
echo $e->GetDetails();
</body>
<script language="javascript">
function OnPageLoad()
selectionXml = '<?php echo $selectionXml; ?>';
parent.parent.SetSelectionXML(selectionXml);
</script>
</body>
</html>
thanks®ards
susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090506/38147c49/attachment.html
