[mapguide-users] setting filter
Ivan Milicevic Ivan.Milicevic at supranet.hr
Wed May 6 03:10:23 EDT 2009
Susan,
If your column ID is type of string put the filter value must be rounded
with qoute marks.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of susan
Daniel
Sent: Wednesday, May 06, 2009 7:04 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] setting filter
hi all.....
       Anyone plzz help me to set the filter.I am having  a feature
source with properties(pan_id,Name.,etc..).Now I wanna  select the
polygon  from the map  having pan_id=ID.
The ID will be entered from the task pane. Here is my code:
I copied it from dev guide..Then what is this this"SHPGEOM" in
setspatialfilter
<?php
    include '../common/common.php';
    $args = ($_SERVER['REQUEST_METHOD']=="GET")? $_GET: $_POST;
    $sessionId = $args['SESSION'];
    $mapName = $args['MAPNAME'];
    $ID= $_GET['PanId'];
    try
      // Initialize the Web Extensions and connect to the Server using
      // the Web Extensions session identifier stored in PHP session
state.
      MgInitializeWebTier ($webconfigFilePath);
      $userInfo = new MgUserInformation($sessionId  );
      $siteConnection = new MgSiteConnection();
      $siteConnection->Open($userInfo);
      $map = new MgMap($siteConnection);
      $map->Open( $mapName  );
      // Get the geometry for the boundaries of District
      $districtQuery = new MgFeatureQueryOptions();
      $districtQuery->SetFilter("pan_id=$ID");
      $layer = $map->GetLayers()->GetItem(0);
      $featureReader = $layer->SelectFeatures($districtQuery);
      $featureReader->ReadNext();
      $districtGeometryData = $featureReader->
      GetGeometry('Data');
      // Convert the AGF binary data to MgGeometry.
      $agfReaderWriter = new MgAgfReaderWriter();
      $districtGeometry = $agfReaderWriter->Read($districtGeometryData);
      // Create a filter to select the desired features. Combine
      // a basic filter and a spatial filter.
      $queryOptions = new MgFeatureQueryOptions();
      $queryOptions->SetFilter("pan_id=$ID");
      $queryOptions->SetSpatialFilter('SHPGEOM', $districtGeometry,
MgFeatureSpatialOperations::Inside);
      // Get the features from the feature source,
      // turn it into a selection, then save the selection as XML.
      $featureReader = $layer->SelectFeatures($queryOptions);
      $selection = new MgSelection($map);
      $selection->AddFeatures($layer, $featureReader, 0);
      $selectionXml = $selection->ToXml();
    catch (MgException $e)
      echo $e->GetMessage();
      echo $e->GetDetails();
  </body>
  <script language="javascript">
    function OnPageLoad()
      selectionXml = '<?php echo $selectionXml; ?>';
      parent.parent.SetSelectionXML(selectionXml);
  </script>
</body>
</html>
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090506/d29be5a3/attachment.html
