[mapguide-users] SetSelectionXML from opener
Jamo adam.jamison at portbris.com.au
Wed May 6 01:08:04 EDT 2009
I'm using opener.parent.mapFrame.SetSelectionXML(XML) to set the selection of
the map from a search window.
It selects one feature as requested, on the right layer .... however none of
the properties pane is updated correctly?
.... does the XML have to contain the properties as well??
this is the part that does the work
while (cFeats.ReadNext())
            //MgSelection cSel = new MgSelection();
            MgPropertyCollection idProps = new MgPropertyCollection();
            foreach (MgPropertyDefinition IDPropDef in
cFeats.GetClassDefinition().GetIdentityProperties())
              idProps.Add(new MgInt32Property(IDPropDef.Name,
cFeats.GetInt32(IDPropDef.Name)));
            cSel.AddFeatureIds(cLayer, cLayer.GetClassName(), idProps);
            String selText =
System.Web.HttpUtility.HtmlEncode(cSel.ToXml());
            Response.Write(selText);
            TableRow TR = new TableRow();
            if (cFeats.IsNull("StaffMember") == false)
              TableCell TC = new TableCell();
              TC.Text = "a HREF=\"#\" onclicker=\"sendXML('" + selText +
"');\">" + cFeats.GetString("StaffMember") + " ";//onclick changed to
onclicker
              TR.Cells.Add(TC);
            if (cFeats.IsNull("Infotitle") == false)
              TC.Text = cFeats.GetString("Infotitle");
              TR.Cells.Add(TC);
            if (cFeats.IsNull("InfomailNickname") == false)
              Image displayImage = new Image();
              displayImage.ImageUrl =
"http://intranet/Image%20Library/Staff%20Photos/" +
cFeats.GetString("InfomailNickname") + ".jpg";
              displayImage.Height = 70;
              TC.Controls.Add(displayImage);
              TR.Cells.Add(TC);
            SearchResults.Rows.Add(TR);
and the Javascript
function sendXML(XML)
 // if(parent.parent.mapFrame = null)
 alert(opener.parent.mapFrame.name);
    opener.parent.mapFrame.SetSelectionXML(XML);
View this message in context: http://n2.nabble.com/SetSelectionXML-from-opener-tp2808645p2808645.html
