[mapguide-users] help
saloua wakrim
wakrimsaloua.wakrim at gmail.com
Sun May 10 18:08:02 EDT 2009
thanks a lot for your replay,yes, i'm sure, i've tried another code and with
mapguide studio i see the layer that i add, it contains the line wich i
insert, but on iframe (where the map is displayed) i don't see the layer and
even in mapguide studio with the layers belonging to the map, i don't see
the layer (it's not added), this is my complete code:
<%@ Page Language="VB" AutoEventWireup="true" CodeFile="essai.aspx.vb"
Inherits="essai" %>
<%@ Import Namespace="System" %>
<%@ Import Namespace="System.IO" %>
<%@ Import Namespace="System.Collections.Specialized" %>
<%@ Import Namespace="OSGeo.MapGuide" %>
<%@ Import Namespace="System.Text" %>
<%@ Import Namespace="System.Globalization" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head id="Head1" runat="server">
<title>selection</title>
</head>
<body>
<br />
Dim x0 As String = "100"
Dim y0 As String = "100"
Dim x1 As String = "120"
Dim y1 As String = "120"
Dim sessionid1 As String
Dim siteConnection As MgSiteConnection
Dim resourceSrvc As MgResourceService
Dim myLayerName As String = "line6"
Dim mapname As String = "Sheboygan"
Dim map As MgMap
Dim featureSrvc As MgFeatureService
Dim myLayer As MgLayer
Dim configPath As String = "C:\Program
Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\webconfig.ini"
MapGuideApi.MgInitializeWebTier(configPath)
Dim site1 As MgSite = New MgSite()
Dim userInfo As MgUserInformation = New MgUserInformation("Administrator",
"admin")
siteConnection = New MgSiteConnection()
siteConnection.Open(userInfo)
site1 = siteConnection.GetSite()
sessionid1 = site1.CreateSession()
userInfo.SetMgSessionId(sessionid1)
resourceSrvc = siteConnection.CreateService(MgServiceType.ResourceService)
featureSrvc = siteConnection.CreateService(MgServiceType.FeatureService)
Response.Charset = "utf-8"
Dim layerDef As String = "Library://Samples/Sheboygan/Layers/" + myLayerName
+ ".LayerDefinition"
Dim layerDefId As MgResourceIdentifier = New MgResourceIdentifier(layerDef)
Dim dataSource As String = "Library://Samples/Sheboygan/Data/" + myLayerName
+ ".FeatureSource"
Dim dataSourceId As MgResourceIdentifier = NewMgResourceIdentifier(dataSource)
Dim resourceID2 As MgResourceIdentifier = New MgResourceIdentifier(
"Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition")
map = New MgMap(siteConnection)
map.Create(resourceSrvc, resourceID2, mapname)
map.Save()
map.Open(resourceSrvc, mapname)
Dim myClassDef As MgClassDefinition
If (DoesLayerExist(myLayerName, map) = False) Then
'//create Feature Source
myClassDef = New MgClassDefinition()
myClassDef.SetName("line6")
'myClassDef.SetDescription(myLayerName + " Feature Source")
'myClassDef.SetDefaultGeometryPropertyName("SHPGEOM")
'Set KEY Property
Dim prop As MgDataPropertyDefinition = New MgDataPropertyDefinition("KEY")
prop.SetDataType(MgPropertyType.Int32)
prop.SetAutoGeneration(True)
prop.SetReadOnly(True)
prop.SetNullable(False)
myClassDef.GetProperties().Add(prop)
myClassDef.GetIdentityProperties().Add(prop)
'Set ID Property
prop = New MgDataPropertyDefinition("ID")
'et geometry property
Dim geomProp As MgGeometricPropertyDefinition =
NewMgGeometricPropertyDefinition(
"SHPGEOM")
geomProp.SetGeometryTypes(MgFeatureGeometricType.Point)
geomProp.SetHasElevation(False)
geomProp.SetHasMeasure(False)
geomProp.SetSpatialContextAssociation("LL84")
myClassDef.GetProperties().Add(geomProp)
'Create the schema
Dim schema As MgFeatureSchema = New MgFeatureSchema()
schema.SetName("SHP_Shema")
schema.GetClasses().Add(myClassDef)
Dim sdfParams As MgCreateSdfParams = New MgCreateSdfParams("MGA-56 (GDA94
/MGA zone 56)", map.GetMapSRS(), schema)
featureSrvc.CreateFeatureSource(dataSourceId, sdfParams)
Dim content As MgByteSource = New MgByteSource("C:\Program
Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\createpoint\LayerDefinition.xml"
resourceSrvc.SetResource(layerDefId, content.GetReader(), Nothing)
myLayer = New MgLayer(layerDefId, resourceSrvc)
myLayer.SetName(myLayerName)
myLayer.SetLegendLabel(myLayerName)
myLayer.SetDisplayInLegend(True)
myLayer.SetSelectable(False)
map.GetLayers().Insert(0, myLayer)
'map.GetLayers().Add(myLayer)
myLayer.ForceRefresh()
map.Save(resourceSrvc)
End If
Dim insertFeatures2 As MgInsertFeatures = New MgInsertFeatures(myLayerName,
makeLine2("1", x0, y0, x1, y1))
Dim commands As MgFeatureCommandCollection = NewMgFeatureCommandCollection()
commands.Add(insertFeatures2)
myLayer.UpdateFeatures(commands)
<div id="viewer">
<iframe id="carte" width="800" height="300" frameborder="0" scrolling="no"
src="http://localhost/mapguide2008/mapviewerajax/?SESSION=<%=sessionid1 %>
&WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout"
name="fenetre"></iframe>
</div>
<br />
</body>
<script type="text/javascript">
function refresh()
//carte.GetMapFrame().GetLayers(true,true);
//carte.GetScriptFrame().location.href = "essai.aspx";
frames['fenetre'].location.reload();
carte.GetMapFrame().Refresh();
//carte.ExecuteMapAction(20);
//carte.GetMapFrame().ExecuteMapAction(1);
//carte.GetTaskFrame().location.href = "essai.aspx"
//carte.GetMapFrame().ExecuteMapAction(20);
</script>
<script runat="server">
Public Function makeLine2(ByVal Name As String, ByVal x0 As String, ByVal y0
As String, ByVal x1 As String, ByVal y1 As String) As MgPropertyCollection
Dim PropertyCollection2 As MgPropertyCollection = New MgPropertyCollection()
Dim nameProperty2 As MgInt32Property = New MgInt32Property("ID", 1)
PropertyCollection2.Add(nameProperty2)
Dim wktReaderWriter2 As MgWktReaderWriter = New MgWktReaderWriter()
Dim agfReaderWriter2 As MgAgfReaderWriter = New MgAgfReaderWriter()
Dim geometry2 As MgGeometry = wktReaderWriter2.Read("LINESTRING XY (" + x0 +
" " + y0 + "," + x1 + " " + y1 + ")")
Dim geometryByteReader2 As MgByteReader = agfReaderWriter2.Write(geometry2)
Dim geometryProperty2 As MgGeometryProperty = New MgGeometryProperty(
"SHPGEOM", geometryByteReader2)
PropertyCollection2.Add(geometryProperty2)
Return PropertyCollection2
End Function
Function DoesLayerExist(ByVal LayerName As String, ByVal Map As MgMap) As
Boolean
Dim layers As MgLayerCollection = Map.GetLayers()
Return (layers.Contains(LayerName))
End Function
Function LoadTemplate2(ByVal filePath As String) As String
Dim sr As StreamReader = File.OpenText(filePath)
Dim template As String = sr.ReadToEnd()
Return template
End Function
</script>
</html>
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090510/c136f878/attachment.html
