[mapguide-users] help
saloua wakrim
wakrimsaloua.wakrim at gmail.com
Mon May 11 03:37:20 EDT 2009
and i have the same prob with inserting polygone in layerand this time even
with mapguide Studio i don't see the polygone in layer , this is my code i
give it you may be it will help you see my error :
As cordinates i pass
Dim x() As Double = {0, 2, 2, 0, 0}
Dim y() As Double = {0, 0, 2, 2, 0}
just for testing and for constituting polygone i do that: (as i've show you
in my code)
Dim poly As MgPolygon
Dim geomfactory As MgGeometryFactory = New MgGeometryFactory()
Dim coordcol As MgCoordinateCollection = New
MgCoordinateCollection()
Dim j As Integer
For j = 0 To 4
Dim coord As MgCoordinate = geomfactory.CreateCoordinateXY(a(j),
b(j))
coordcol.Add(coord)
j = j + 1
Next
Dim outring As MgLinearRing = geomfactory.CreateLinearRing(coordcol)
poly = geomfactory.CreatePolygon(outring, Nothing)
Dim agf As MgAgfReaderWriter = New MgAgfReaderWriter()
properties.Add(New MgGeometryProperty("GEOM", agf.Write(poly)))
another prob that i have that i can't see the layer i add after refreshing
map (conntained in <iframe>)for saying layer i use mapguide studio where i
see the layer wich doesn't contain the polygon, may be pro in type of
geometry i give or another, i'll give all complete code it will help you see
my error and help me if you can, i've spent a lot of time at that but i
don't see my error and why even i add layer in map i don't see it and when i
see it using mapguide studio it doesn't contain polygone i insert.i have
even tested to insert polygone with text shape (("POLYGON XY ((0 0, 2 0, 2
2, 0 2, 0 0))" in function makeLine2() as you see)but it doesn't run too.i
don't know what do, please help me if you can do it. Thanks a lot in
advance.
<%@ Page Language="VB" AutoEventWireup="true" CodeFile="essai.aspx.vb"
Inherits="essai" %>
<%@ Import Namespace="System" %>
<%@ Import Namespace="System.IO" %>
<%@ Import Namespace="System.Collections.Specialized" %>
<%@ Import Namespace="OSGeo.MapGuide" %>
<%@ Import Namespace="System.Text" %>
<%@ Import Namespace="System.Globalization" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head id="Head1" runat="server">
<title>selection</title>
</head>
<body>
<br />
Dim sessionid1 As String
Dim siteConnection As MgSiteConnection
Dim resourceSrvc As MgResourceService
Dim myLayerName As String = "line9"
Dim mapname As String = "Sheboygan"
Dim map As MgMap
Dim featureSrvc As MgFeatureService
Dim myLayer As MgLayer
Dim configPath As String = "C:\Program
Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\webconfig.ini"
MapGuideApi.MgInitializeWebTier(configPath)
Dim site1 As MgSite = New MgSite()
Dim userInfo As MgUserInformation = New
MgUserInformation("Administrator", "admin")
siteConnection = New MgSiteConnection()
siteConnection.Open(userInfo)
site1 = siteConnection.GetSite()
sessionid1 = site1.CreateSession()
userInfo.SetMgSessionId(sessionid1)
resourceSrvc =
siteConnection.CreateService(MgServiceType.ResourceService)
featureSrvc =
siteConnection.CreateService(MgServiceType.FeatureService)
Response.Charset = "utf-8"
Dim layerDef As String = "Library://Samples/Sheboygan/Layers/" +
myLayerName + ".LayerDefinition"
Dim layerDefId As MgResourceIdentifier = New
MgResourceIdentifier(layerDef)
Dim dataSource As String = "Library://Samples/Sheboygan/Data/" +
myLayerName + ".FeatureSource"
Dim dataSourceId As MgResourceIdentifier = New
MgResourceIdentifier(dataSource)
Dim resourceID2 As MgResourceIdentifier = New
MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition")
map = New MgMap(siteConnection)
map.Create(resourceSrvc, resourceID2, mapname)
map.Save()
map.Open(resourceSrvc, mapname)
Dim myClassDef As MgClassDefinition
If (DoesLayerExist(myLayerName, map) = False) Then
'//create Feature Source
myClassDef = New MgClassDefinition()
myClassDef.SetName("line9")
'myClassDef.SetDescription(myLayerName + " Feature Source")
'myClassDef.SetDefaultGeometryPropertyName("SHPGEOM")
'Set KEY Property
Dim prop As MgDataPropertyDefinition = New
MgDataPropertyDefinition("KEY")
prop.SetDataType(MgPropertyType.Int32)
prop.SetAutoGeneration(True)
prop.SetReadOnly(True)
prop.SetNullable(False)
myClassDef.GetProperties().Add(prop)
myClassDef.GetIdentityProperties().Add(prop)
'Set ID Property
prop = New MgDataPropertyDefinition("ID")
'et geometry property
Dim geomProp As MgGeometricPropertyDefinition = New
MgGeometricPropertyDefinition("GEOM")
geomProp.SetGeometryTypes(MgFeatureGeometricType.Surface)
geomProp.SetHasElevation(False)
geomProp.SetHasMeasure(False)
geomProp.SetSpatialContextAssociation("LL84")
myClassDef.GetProperties().Add(geomProp)
'Create the schema
Dim schema As MgFeatureSchema = New MgFeatureSchema()
schema.SetName("SHP_Shema")
schema.GetClasses().Add(myClassDef)
Dim sdfParams As MgCreateSdfParams = New MgCreateSdfParams("MGA-56
(GDA94 /MGA zone 56)", map.GetMapSRS(), schema)
featureSrvc.CreateFeatureSource(dataSourceId, sdfParams)
Dim content As MgByteSource = New MgByteSource("C:\Program
Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\createpoint\LayerDefinition.xml")
resourceSrvc.SetResource(layerDefId, content.GetReader(), Nothing)
myLayer = New MgLayer(layerDefId, resourceSrvc)
myLayer.SetName(myLayerName)
myLayer.SetLegendLabel(myLayerName)
myLayer.SetDisplayInLegend(True)
myLayer.SetSelectable(False)
map.GetLayers().Insert(0, myLayer)
'map.GetLayers().Add(myLayer)
myLayer.ForceRefresh()
map.Save(resourceSrvc)
End If
Dim insertFeatures2 As MgInsertFeatures = New
MgInsertFeatures(myLayerName, makeLine())
Dim commands As MgFeatureCommandCollection = New
MgFeatureCommandCollection()
commands.Add(insertFeatures2)
myLayer.UpdateFeatures(commands)
<div id="viewer">
<iframe id="carte" width="800" height="300" frameborder="0" scrolling="no"
src="http://localhost/mapguide2008/mapviewerajax/?SESSION=<%=sessionid1%>&WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout"
name="fenetre"></iframe>
</div>
<br />
<div>
<input type="button" value="zoom" name="zoom" onclick="zoom()"/>
</div>
<br />
<div>
<input type="button" value="rafraichir" name="calque"
onclick="testcalque();"/>
</div>
</body>
<script type="text/javascript">
var str2;
var str;
function zoom()
carte.GetMapFrame().ZoomToView(-87.7116768,43.7766789973,5000,true);
function testcalque()
//carte.GetMapFrame().GetLayers(true,true);
//carte.GetScriptFrame().location.href = "essai.aspx";
frames['fenetre'].location.reload();
carte.GetMapFrame().Refresh();
//carte.ExecuteMapAction(20);
//carte.GetMapFrame().ExecuteMapAction(1);
//carte.GetTaskFrame().location.href = "essai.aspx"
//carte.GetMapFrame().ExecuteMapAction(20);
</script>
<script runat="server">
Public Function makeLine() As MgPropertyCollection
Dim j As Integer
For j = 0 To 4
Dim coord As MgCoordinate = geomfactory.CreateCoordinateXY(x(j),
y(j))
coordcol.Add(coord)
j = j + 1
Next
return properties
End Function
Public Function makeLine2() As MgPropertyCollection
Dim PropertyCollection2 As MgPropertyCollection = New
MgPropertyCollection()
Dim nameProperty2 As MgInt32Property = New MgInt32Property("ID", 1)
PropertyCollection2.Add(nameProperty2)
Dim wktReaderWriter2 As MgWktReaderWriter = New MgWktReaderWriter()
Dim agfReaderWriter2 As MgAgfReaderWriter = New MgAgfReaderWriter()
Dim geometry2 As MgPolygon = wktReaderWriter2.Read("POLYGON XY ((0
0, 2 0, 2 2, 0 2, 0 0))")
Dim geometryByteReader2 As MgByteReader =
agfReaderWriter2.Write(geometry2)
Dim geometryProperty2 As MgGeometryProperty = New
MgGeometryProperty("GEOM", geometryByteReader2)
PropertyCollection2.Add(geometryProperty2)
Return PropertyCollection2
End Function
Function DoesLayerExist(ByVal LayerName As String, ByVal Map As MgMap)
As Boolean
Dim layers As MgLayerCollection = Map.GetLayers()
Return (layers.Contains(LayerName))
End Function
</script>
</html>
2009/5/11 javed shaikh <jaspune at hotmail.com>
> Wakrim
> Could you tell me what is the error?
> You were code is technically correct, if you can tell me what is the error
> i can help you.
> Before that make sure you are passing corrrect cordinates (last co ordinate
> is same as first) you are passing correct layer scheme and inserting in
> correct session.
> J
> > From: wakrimsaloua.wakrim at gmail.com
> > To: jaspune at hotmail.com
> > Subject: please help me if you can
> > Date: Sat, 9 May 2009 04:13:56 -0700
> > hi, i've the same prob that you have, but i can't resolve it, i use this
> code for drawning polygon ,but it doesn't draw it, please correct it me if
> you have time to do it, this is my mail: wakrimsaloua.wakrim at gmail.com,
> this is my code:
> > Dim myClassDef As MgClassDefinition = New MgClassDefinition()
> > myClassDef.SetName("saloua3")
> > 'Set KEY Property
> > 'Set ID Property
> > 'add poly
> > Dim coordcol As MgCoordinateCollection = New MgCoordinateCollection()
> > Dim j As Integer
> > For j = 0 To 3
> > Dim coord As MgCoordinate = geomfactory.CreateCoordinateXY(x(j), y(j))
> > coordcol.Add(coord)
> > Next
> > 'Dim geom As MgByteReader = geometryReaderWriter.Write(poly)
> > properties = New MgPropertyCollection()
> MgGeometricPropertyDefinition("SHPGEOM")
> > geomProp.SetGeometryTypes(MgFeatureGeometricType.Curve)
> > 'Create the schema
> > Dim sdfParams As MgCreateSdfParams = New MgCreateSdfParams("MGA-56 (GDA94
> > 'Dim layerDefContent As MgByteReader =
> BuildLayerDefinitionContent(dataSource, "SHP_Shema:linetestvb4", "", "5",
> "F000F")
> > 'resourceSrvc.SetResource(layerDefId, layerDefContent, nothing)
> Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\testvb\LayerDefinition.xml")
> > Dim myLayer As MgLayer = New MgLayer(layerDefId, resourceSrvc)
> > myLayer.SetLegendLabel("legend" + myLayerName)
> > myLayer.SetSelectable(True)
> > Dim insertFeatures As MgInsertFeatures = New
> MgInsertFeatures(myLayerName, properties)
> > commands.Add(insertFeatures)
> > Dim commandIndex As Integer = commands.IndexOf(insertFeatures)
> > Dim insertResults As MgPropertyCollection
> > insertResults = featureSrvc.UpdateFeatures(dataSourceId, commands, False)
> > End If
> 2009/5/11 saloua wakrim <wakrimsaloua.wakrim at gmail.com>
> thanks a lot for your replay,yes, i'm sure, i've tried another code and
> with mapguide studio i see the layer that i add, it contains the line wich i
> insert, but on iframe (where the map is displayed) i don't see the layer and
> even in mapguide studio with the layers belonging to the map, i don't see
> the layer (it's not added), this is my complete code:
> Inherits
> ="essai" %>
> head>
> body>
> br />
> Dim x0 As String = "100"
> Dim y0 As String = "100"
> Dim x1 As String = "120"
> Dim y1 As String = "120"
> Dim myLayerName As String = "line6"
> Dim map As MgMap
> Dim userInfo As MgUserInformation = New MgUserInformation("Administrator",
> "admin")
> siteConnection =
> resourceSrvc = siteConnection.CreateService(MgServiceType.ResourceService)
> featureSrvc = siteConnection.CreateService(MgServiceType.FeatureService)
> Response.Charset =
> "utf-8"
> Dim layerDefId As MgResourceIdentifier = NewMgResourceIdentifier(layerDef)
> Dim dataSourceId As MgResourceIdentifier = NewMgResourceIdentifier(dataSource)
> Dim resourceID2 As MgResourceIdentifier = New MgResourceIdentifier(
> map =
> map.Save()
> myClassDef =
> myClassDef.SetName(
> "line6")
> 'Set KEY Property
> Dim prop As MgDataPropertyDefinition = New MgDataPropertyDefinition("KEY")
> True)
> prop.SetReadOnly(
> True)
> prop.SetNullable(
> False)
> 'Set ID Property
> prop =
> Dim geomProp As MgGeometricPropertyDefinition = NewMgGeometricPropertyDefinition(
> "SHPGEOM")
> geomProp.SetGeometryTypes(MgFeatureGeometricType.Point)
> False)
> False)
> "LL84")
> 'Create the schema
> schema.SetName(
> "SHP_Shema")
> Nothing)
> myLayer =
> True)
> False)
> End If
> MgInsertFeatures(myLayerName, makeLine2("1", x0, y0, x1, y1))
> Dim commands As MgFeatureCommandCollection = NewMgFeatureCommandCollection()
> div id="viewer">
> src="http://localhost/mapguide2008/mapviewerajax/?SESSION=<%=sessionid1 %>
> </div>
> <br />
> body>
> function refresh()
> frames[
> script>
> Public
> Function makeLine2(ByVal Name As String, ByVal x0 As String, ByVal y0 As
> String, ByVal x1 As String, ByVal y1 As String) As MgPropertyCollection
> Dim PropertyCollection2 As MgPropertyCollection = NewMgPropertyCollection()
> Dim geometry2 As MgGeometry = wktReaderWriter2.Read("LINESTRING XY (" + x0
> + " " + y0 + "," + x1 + " " + y1 + ")")
> Dim geometryProperty2 As MgGeometryProperty = New MgGeometryProperty(
> "SHPGEOM", geometryByteReader2)
> End Function
> Function DoesLayerExist(ByVal LayerName As String, ByVal Map As MgMap) As Boolean
> End Function
> Function LoadTemplate2(ByVal filePath As String) As String
> Dim sr As StreamReader = File.OpenText(filePath)
> Dim template As String = sr.ReadToEnd()
> Return template
> End Function
> script>
> html>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090511/db40e063/attachment.html
