[mapguide-users] help
saloua wakrim wakrimsaloua.wakrim at gmail.com
Mon May 11 09:20:15 EDT 2009
hi! please i want know if this code is that what all i must do for adding
new layer to map and see it in viewer frame or i must do some relation with
the feature source i create in my code?? thanks on advance
myLayer = New MgLayer(layerDefId, resourceSrvc)
myLayer.SetName(myLayerName)
myLayer.SetLegendLabel(myLayerName)
myLayer.SetDisplayInLegend(True)
myLayer.SetSelectable(False)
map.GetLayers().Insert(0, myLayer)
myLayer.ForceRefresh()
map.Save(resourceSrvc)
2009/5/11 saloua wakrim <wakrimsaloua.wakrim at gmail.com>
> and i have the same prob with inserting polygone in layerand this time even
> with mapguide Studio i don't see the polygone in layer , this is my code i
> give it you may be it will help you see my error :
> As cordinates i pass
>  Dim x() As Double = {0, 2, 2, 0, 0}
>   Dim y() As Double = {0, 0, 2, 2, 0}
> just for testing and for constituting polygone i do that: (as i've show you
> in my code)
>         Dim poly As MgPolygon
>         Dim geomfactory As MgGeometryFactory = New MgGeometryFactory()
>         Dim coordcol As MgCoordinateCollection = New
> MgCoordinateCollection()
>         Dim j As Integer
>         For j = 0 To 4
>         Dim coord As MgCoordinate = geomfactory.CreateCoordinateXY(a(j),
> b(j))
>         coordcol.Add(coord)
>         j = j + 1
>         Next
>         Dim outring As MgLinearRing =
> geomfactory.CreateLinearRing(coordcol)
>          poly = geomfactory.CreatePolygon(outring, Nothing)
>         Dim agf As MgAgfReaderWriter = New MgAgfReaderWriter()
>         properties.Add(New MgGeometryProperty("GEOM", agf.Write(poly)))
> another prob that i have that i can't see the layer i add after refreshing
> map (conntained in <iframe>)for saying layer i use mapguide studio where i
> see the layer wich doesn't contain the polygon, may be pro in type of
> geometry i give or another, i'll give all complete code it will help you see
> my error and help me if you can, i've spent a lot of time at that but i
> don't see my error and why even i add layer in map i don't see it and when i
> see it using mapguide studio it doesn't contain polygone i insert.i have
> even tested to insert polygone with text shape (("POLYGON XY ((0 0, 2 0, 2
> 2, 0 2, 0 0))" in function makeLine2() as you see)but it doesn't run too.i
> don't know what do, please help me if you can do it. Thanks a lot in
> advance.
> <%@ Page Language="VB" AutoEventWireup="true" CodeFile="essai.aspx.vb"
> Inherits="essai" %>
> <%@ Import Namespace="System" %>
> <%@ Import Namespace="System.IO" %>
> <%@ Import Namespace="System.Collections.Specialized" %>
> <%@ Import Namespace="OSGeo.MapGuide" %>
> <%@ Import Namespace="System.Text" %>
> <%@ Import Namespace="System.Globalization" %>
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
> <html xmlns="http://www.w3.org/1999/xhtml" >
> <head id="Head1" runat="server">
>     <title>selection</title>
> </head>
> <body>
> <br />
>         Dim sessionid1 As String
>      Dim siteConnection As MgSiteConnection
>      Dim resourceSrvc As MgResourceService
>      Dim myLayerName As String = "line9"
>      Dim mapname As String = "Sheboygan"
>      Dim map As MgMap
>      Dim featureSrvc As MgFeatureService
>      Dim myLayer As MgLayer
>        Dim configPath As String = "C:\Program
> Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\webconfig.ini"
>      MapGuideApi.MgInitializeWebTier(configPath)
>      Dim site1 As MgSite = New MgSite()
>      Dim userInfo As MgUserInformation = New
> MgUserInformation("Administrator", "admin")
>      siteConnection = New MgSiteConnection()
>      siteConnection.Open(userInfo)
>      site1 = siteConnection.GetSite()
>      sessionid1 = site1.CreateSession()
>      userInfo.SetMgSessionId(sessionid1)
>      resourceSrvc =
> siteConnection.CreateService(MgServiceType.ResourceService)
>      featureSrvc =
> siteConnection.CreateService(MgServiceType.FeatureService)
>      Response.Charset = "utf-8"
>      Dim layerDef As String = "Library://Samples/Sheboygan/Layers/" +
> myLayerName + ".LayerDefinition"
>      Dim layerDefId As MgResourceIdentifier = New
> MgResourceIdentifier(layerDef)
>      Dim dataSource As String = "Library://Samples/Sheboygan/Data/" +
> myLayerName + ".FeatureSource"
>      Dim dataSourceId As MgResourceIdentifier = New
> MgResourceIdentifier(dataSource)
>      Dim resourceID2 As MgResourceIdentifier = New
> MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition")
>      map = New MgMap(siteConnection)
>      map.Create(resourceSrvc, resourceID2, mapname)
>      map.Save()
>      map.Open(resourceSrvc, mapname)
>      Dim myClassDef As MgClassDefinition
>      If (DoesLayerExist(myLayerName, map) = False) Then
>            '//create Feature Source
>          myClassDef = New MgClassDefinition()
>          myClassDef.SetName("line9")
>          'myClassDef.SetDescription(myLayerName + " Feature Source")
>          'myClassDef.SetDefaultGeometryPropertyName("SHPGEOM")
>           'Set KEY Property
>          Dim prop As MgDataPropertyDefinition = New
> MgDataPropertyDefinition("KEY")
>          prop.SetDataType(MgPropertyType.Int32)
>          prop.SetAutoGeneration(True)
>          prop.SetReadOnly(True)
>          prop.SetNullable(False)
>          myClassDef.GetProperties().Add(prop)
>          myClassDef.GetIdentityProperties().Add(prop)
>           'Set ID Property
>          prop = New MgDataPropertyDefinition("ID")
>          'et geometry property
>          Dim geomProp As MgGeometricPropertyDefinition = New
> MgGeometricPropertyDefinition("GEOM")
>          geomProp.SetGeometryTypes(MgFeatureGeometricType.Surface)
>          geomProp.SetHasElevation(False)
>          geomProp.SetHasMeasure(False)
>          geomProp.SetSpatialContextAssociation("LL84")
>          myClassDef.GetProperties().Add(geomProp)
>           'Create the schema
>          Dim schema As MgFeatureSchema = New MgFeatureSchema()
>          schema.SetName("SHP_Shema")
>          schema.GetClasses().Add(myClassDef)
>          Dim sdfParams As MgCreateSdfParams = New MgCreateSdfParams("MGA-56
> (GDA94 /MGA zone 56)", map.GetMapSRS(), schema)
>          featureSrvc.CreateFeatureSource(dataSourceId, sdfParams)
>          Dim content As MgByteSource = New MgByteSource("C:\Program
> Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\createpoint\LayerDefinition.xml")
>          resourceSrvc.SetResource(layerDefId, content.GetReader(), Nothing)
>          'map.GetLayers().Add(myLayer)
>      End If
>        Dim insertFeatures2 As MgInsertFeatures = New
> MgInsertFeatures(myLayerName, makeLine())
>      Dim commands As MgFeatureCommandCollection = New
> MgFeatureCommandCollection()
>      commands.Add(insertFeatures2)
>     myLayer.UpdateFeatures(commands)
>  <div id="viewer">
>  <iframe id="carte" width="800" height="300" frameborder="0" scrolling="no"
> src="http://localhost/mapguide2008/mapviewerajax/?SESSION=<%=sessionid1<http://localhost/mapguide2008/mapviewerajax/?SESSION=%3C%=sessionid1>%>&WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout"
> name="fenetre"></iframe>
>  </div>
>  <br />
>  <div>
> <input type="button" value="zoom" name="zoom" onclick="zoom()"/>
> </div>
> <br />
> <div>
> <input type="button" value="rafraichir" name="calque"
> onclick="testcalque();"/>
> </div>
> </body>
> <script type="text/javascript">
>     var str2;
>     var str;
>     function zoom()
>     carte.GetMapFrame().ZoomToView(-87.7116768,43.7766789973,5000,true);
>      function testcalque()
>     //carte.GetMapFrame().GetLayers(true,true);
>    //carte.GetScriptFrame().location.href = "essai.aspx";
>    frames['fenetre'].location.reload();
>     carte.GetMapFrame().Refresh();
>     //carte.ExecuteMapAction(20);
>     //carte.GetMapFrame().ExecuteMapAction(1);
>     //carte.GetTaskFrame().location.href = "essai.aspx"
>      //carte.GetMapFrame().ExecuteMapAction(20);
> </script>
> <script runat="server">
>     Public Function makeLine() As MgPropertyCollection
>         Dim j As Integer
>         For j = 0 To 4
>         Dim coord As MgCoordinate = geomfactory.CreateCoordinateXY(x(j),
> y(j))
>         coordcol.Add(coord)
>         j = j + 1
>         Next
>     return properties
>     End Function
>     Public Function makeLine2() As MgPropertyCollection
>          Dim PropertyCollection2 As MgPropertyCollection = New
> MgPropertyCollection()
>         Dim nameProperty2 As MgInt32Property = New MgInt32Property("ID", 1)
>         PropertyCollection2.Add(nameProperty2)
>         Dim wktReaderWriter2 As MgWktReaderWriter = New MgWktReaderWriter()
>         Dim agfReaderWriter2 As MgAgfReaderWriter = New MgAgfReaderWriter()
>         Dim geometry2 As MgPolygon = wktReaderWriter2.Read("POLYGON XY ((0
> 0, 2 0, 2 2, 0 2, 0 0))")
>         Dim geometryByteReader2 As MgByteReader =
> agfReaderWriter2.Write(geometry2)
>         Dim geometryProperty2 As MgGeometryProperty = New
> MgGeometryProperty("GEOM", geometryByteReader2)
>         PropertyCollection2.Add(geometryProperty2)
>         Return PropertyCollection2
>     End Function
>     Function DoesLayerExist(ByVal LayerName As String, ByVal Map As MgMap)
> As Boolean
>         Dim layers As MgLayerCollection = Map.GetLayers()
>         Return (layers.Contains(LayerName))
>     End Function
> </script>
> </html>
> 2009/5/11 javed shaikh <jaspune at hotmail.com>
>> Wakrim
>> Could you tell me what is the error?
>> You were code is technically correct, if you can tell me what is the error
>> i can help you.
>> Before that make sure you are passing corrrect cordinates (last co
>> ordinate is same as first) you are passing correct layer scheme and
>> inserting in correct session.
>> J
>> > From: wakrimsaloua.wakrim at gmail.com
>> > To: jaspune at hotmail.com
>> > Subject: please help me if you can
>> > Date: Sat, 9 May 2009 04:13:56 -0700
>> > hi, i've the same prob that you have, but i can't resolve it, i use this
>> code for drawning polygon ,but it doesn't draw it, please correct it me if
>> you have time to do it, this is my mail: wakrimsaloua.wakrim at gmail.com,
>> this is my code:
>> > Dim myClassDef As MgClassDefinition = New MgClassDefinition()
>> > myClassDef.SetName("saloua3")
>> > 'Set KEY Property
>> > 'Set ID Property
>> > 'add poly
>> > Dim coordcol As MgCoordinateCollection = New MgCoordinateCollection()
>> > Dim j As Integer
>> > For j = 0 To 3
>> > Dim coord As MgCoordinate = geomfactory.CreateCoordinateXY(x(j), y(j))
>> > coordcol.Add(coord)
>> > Next
>> > Dim outring As MgLinearRing = geomfactory.CreateLinearRing(coordcol)
>> > 'Dim geom As MgByteReader = geometryReaderWriter.Write(poly)
>> > properties = New MgPropertyCollection()
>> MgGeometricPropertyDefinition("SHPGEOM")
>> > geomProp.SetGeometryTypes(MgFeatureGeometricType.Curve)
>> > 'Create the schema
>> > 'Dim layerDefContent As MgByteReader =
>> BuildLayerDefinitionContent(dataSource, "SHP_Shema:linetestvb4", "", "5",
>> "F000F")
>> > 'resourceSrvc.SetResource(layerDefId, layerDefContent, nothing)
>> Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\testvb\LayerDefinition.xml")
>> > Dim myLayer As MgLayer = New MgLayer(layerDefId, resourceSrvc)
>> > myLayer.SetLegendLabel("legend" + myLayerName)
>> > myLayer.SetSelectable(True)
>> > Dim insertFeatures As MgInsertFeatures = New
>> MgInsertFeatures(myLayerName, properties)
>> > commands.Add(insertFeatures)
>> > Dim commandIndex As Integer = commands.IndexOf(insertFeatures)
>> > Dim insertResults As MgPropertyCollection
>> > insertResults = featureSrvc.UpdateFeatures(dataSourceId, commands,
>> False)
>> > End If
>  thanks a lot for your replay,yes, i'm sure, i've tried another code and
>> with mapguide studio i see the layer that i add, it contains the line wich i
>> insert, but on iframe (where the map is displayed) i don't see the layer and
>> even in mapguide studio with the layers belonging to the map, i don't see
>> the layer (it's not added), this is my complete code:
>> Inherits
>> ="essai" %>
>> head>
>> body>
>> br />
>>  Dim x0 As String = "100"
>> Dim y0 As String = "100"
>> Dim x1 As String = "120"
>> Dim y1 As String = "120"
>> Dim myLayerName As String = "line6"
>> Dim map As MgMap
>> Dim userInfo As MgUserInformation = New MgUserInformation("Administrator",
>> "admin")
>> siteConnection =
>> resourceSrvc = siteConnection.CreateService(MgServiceType.ResourceService)
>> featureSrvc = siteConnection.CreateService(MgServiceType.FeatureService)
>> Response.Charset =
>> "utf-8"
>> Dim layerDefId As MgResourceIdentifier = NewMgResourceIdentifier(layerDef)
>> Dim dataSourceId As MgResourceIdentifier = NewMgResourceIdentifier(dataSource)
>> Dim resourceID2 As MgResourceIdentifier = New MgResourceIdentifier(
>> map =
>> map.Save()
>> myClassDef =
>> myClassDef.SetName(
>> "line6")
>> 'Set KEY Property
>> Dim prop As MgDataPropertyDefinition = New MgDataPropertyDefinition("KEY")
>> True)
>> prop.SetReadOnly(
>> True)
>> prop.SetNullable(
>> False)
>> 'Set ID Property
>> prop =
>> Dim geomProp As MgGeometricPropertyDefinition = NewMgGeometricPropertyDefinition(
>> "SHPGEOM")
>> geomProp.SetGeometryTypes(MgFeatureGeometricType.Point)
>> False)
>> False)
>> "LL84")
>> 'Create the schema
>> schema.SetName(
>> "SHP_Shema")
>> Dim sdfParams As MgCreateSdfParams = New MgCreateSdfParams("MGA-56 (GDA94
>> Nothing)
>> myLayer =
>> True)
>> False)
>>  End If
>> MgInsertFeatures(myLayerName, makeLine2("1", x0, y0, x1, y1))
>> Dim commands As MgFeatureCommandCollection = NewMgFeatureCommandCollection()
>> div id="viewer">
>> ="no" src="http://localhost/mapguide2008/mapviewerajax/?SESSION=<%=sessionid1
>> </div>
>> <br />
>> body>
>> function refresh()
>> frames[
>> script>
>> Public
>> Function makeLine2(ByVal Name As String, ByVal x0 As String, ByVal y0 As
>> String, ByVal x1 As String, ByVal y1 As String) As MgPropertyCollection
>> Dim PropertyCollection2 As MgPropertyCollection = NewMgPropertyCollection()
>> Dim geometry2 As MgGeometry = wktReaderWriter2.Read("LINESTRING XY (" +
>> x0 + " " + y0 + "," + x1 + " " + y1 + ")")
>> Dim geometryProperty2 As MgGeometryProperty = New MgGeometryProperty(
>> "SHPGEOM", geometryByteReader2)
>> End Function
>> As Boolean
>> End Function
>> Function LoadTemplate2(ByVal filePath As String) As String
>> Dim sr As StreamReader = File.OpenText(filePath)
>> Dim template As String = sr.ReadToEnd()
>> Return template
>> End Function
>> script>
>> html>
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090511/c07af443/attachment.html
