[mapguide-users] .NET viewer sample: query tool
nasp
nspitilli at hotmail.com
Tue May 12 09:29:10 EDT 2009
The problem is for layer with FDO Provider: OSGeo.ODBC and it's ok for SDF
layers.
OSGeo.ODBC data connection has no spatial context information (SDF layer
connection has it!).
Do you know how can I provide spatial context information for ODBC geometry?
Regards,
Naspi
Jackie Ng wrote:
> If you look at the server error logs, do they reveal any more information
> at the time of failure?
> - Jackie
> nasp wrote:
>> Thank you for your answer.
>> Mapguide version is 2.0.2 with FDO 3.4
>> The map has EPSG=3003
>> Any ideas?
>> Jackie Ng wrote:
>>> Are you using the latest release of MapGuide?
>>> Also, do your maps/layers/feature sources have defined coordinate
>>> systems?
>>> - Jackie
>>> nasp wrote:
>>>> Hi,
>>>> I downloaded .NET sample application.
>>>> Everything works fine but not the query tool.
>>>> In query\classes\query.aspx, Execute() procedure, I got an error
>>>> (MgUnclassifiedException) at this line
>>>> centerPoint = (MgPoint)
>>>> centerPoint.Transform(csTransform);
>>>> Can someone help me, please?
>>>> Regards,
>>>> Naspi
View this message in context: http://n2.nabble.com/.NET-viewer-sample%3A-query-tool-tp2868356p2869149.html
