[mapguide-users] .NET viewer sample: query tool
Jackie Ng
jumpinjackie at gmail.com
Wed May 13 09:45:12 EDT 2009
If you are using MapGuide Studio, the feature source editor allows you to
specify a coordinate system for your point geometry tables.
I don't know if Maestro has exposed this same capability.
- Jackie
nasp wrote:
> The problem is for layer with FDO Provider: OSGeo.ODBC and it's ok for SDF
> layers.
> OSGeo.ODBC data connection has no spatial context information (SDF layer
> connection has it!).
> Do you know how can I provide spatial context information for ODBC
> geometry?
> Regards,
> Naspi
> Jackie Ng wrote:
>> If you look at the server error logs, do they reveal any more information
>> at the time of failure?
>> - Jackie
>> nasp wrote:
>>> Thank you for your answer.
>>> Mapguide version is 2.0.2 with FDO 3.4
>>> The map has EPSG=3003
>>> Any ideas?
>>> Jackie Ng wrote:
>>>> Are you using the latest release of MapGuide?
>>>> Also, do your maps/layers/feature sources have defined coordinate
>>>> systems?
>>>> - Jackie
>>>> nasp wrote:
>>>>> Hi,
>>>>> I downloaded .NET sample application.
>>>>> Everything works fine but not the query tool.
>>>>> In query\classes\query.aspx, Execute() procedure, I got an error
>>>>> (MgUnclassifiedException) at this line
>>>>> centerPoint = (MgPoint)
>>>>> centerPoint.Transform(csTransform);
>>>>> Can someone help me, please?
>>>>> Regards,
>>>>> Naspi
View this message in context: http://n2.nabble.com/.NET-viewer-sample%3A-query-tool-tp2868356p2883850.html
