[mapguide-users] .NET viewer sample: query tool
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 13 14:03:31 EDT 2009
I have recently fixed the ODBC spatial context problem in Maestro,
but not yet released a preview build.
If you build Maestro from source, it should work.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jackie Ng skrev:
> If you are using MapGuide Studio, the feature source editor allows you to
> specify a coordinate system for your point geometry tables.
> I don't know if Maestro has exposed this same capability.
> - Jackie
> nasp wrote:
>> The problem is for layer with FDO Provider: OSGeo.ODBC and it's ok for SDF
>> layers.
>> OSGeo.ODBC data connection has no spatial context information (SDF layer
>> connection has it!).
>> Do you know how can I provide spatial context information for ODBC
>> geometry?
>> Regards,
>> Naspi
>> Jackie Ng wrote:
>>> If you look at the server error logs, do they reveal any more information
>>> at the time of failure?
>>> - Jackie
>>> nasp wrote:
>>>> Thank you for your answer.
>>>> Mapguide version is 2.0.2 with FDO 3.4
>>>> The map has EPSG=3003
>>>> Any ideas?
>>>> Jackie Ng wrote:
>>>>> Are you using the latest release of MapGuide?
>>>>> Also, do your maps/layers/feature sources have defined coordinate
>>>>> systems?
>>>>> - Jackie
>>>>> nasp wrote:
>>>>>> Hi,
>>>>>> I downloaded .NET sample application.
>>>>>> Everything works fine but not the query tool.
>>>>>> In query\classes\query.aspx, Execute() procedure, I got an error
>>>>>> (MgUnclassifiedException) at this line
>>>>>> centerPoint = (MgPoint)
>>>>>> centerPoint.Transform(csTransform);
>>>>>> Can someone help me, please?
>>>>>> Regards,
>>>>>> Naspi
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090513/306afe75/attachment.html
