[mapguide-users] WebServerExtensions Installation
Jackie Ng jumpinjackie at gmail.com
Wed May 13 09:08:08 EDT 2009
The installer is doing the following:
1) Installing to C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions
- If Apache, configures httpd.conf based on your installer preferences.
- If IIS, creates the virtual directories and sets up the script mappings
(php, aspx, jsp, fcgi) based on your installer preferences.
- If manual config, nothing else is done (I believe)
What you could do is install the web server extensions into a test machine.
Then grab all the files under WebServerExtensions, upload it to your remote
host and manually install and configure from there.
- Jackie
S.Dalakov wrote:
> Hi all,
> I want to (try to) install MGOS2.02 (WebServerExtensions) on a commercial
> hosting, so my question is :
>  Is it possible to configure WebServerExtensions manually - no provider
> will let me run an executable ? What in fact is the installer doing
> (except to copy files) ?
> Thank you in advance
> Stefan Dalakov
View this message in context: http://n2.nabble.com/WebServerExtensions-Installation-tp2883554p2883636.html
