[mapguide-users] WebServerExtensions Installation
Stefan Dalakov s.dalakov at mapware.net
Wed May 13 09:51:19 EDT 2009
Thank you Jackie, I will give it a try
Stefan Dalakov
Jackie Ng wrote:
> The installer is doing the following:
> 1) Installing to C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions
> - If Apache, configures httpd.conf based on your installer preferences.
> - If IIS, creates the virtual directories and sets up the script mappings
> (php, aspx, jsp, fcgi) based on your installer preferences.
> - If manual config, nothing else is done (I believe)
> What you could do is install the web server extensions into a test machine.
> Then grab all the files under WebServerExtensions, upload it to your remote
> host and manually install and configure from there.
> - Jackie
> S.Dalakov wrote:
>> Hi all,
>> I want to (try to) install MGOS2.02 (WebServerExtensions) on a commercial
>> hosting, so my question is :
>>  Is it possible to configure WebServerExtensions manually - no provider
>> will let me run an executable ? What in fact is the installer doing
>> (except to copy files) ?
>> Thank you in advance
>> Stefan Dalakov
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090513/5761eae4/attachment.html
