[mapguide-users] Exporting a MapGuide Map to HTML file?
briancomeau brian.comeau at accenture.com
Thu May 14 10:30:53 EDT 2009
So it is possible?
Are you saying that there isn't something like the previous MWF that I could
simply embed into an HTML file using the OBJECT tags? If not, is there
another way to do this? You mentioned an API, is that fairly easy to use?
Thanks,
Brian
zspitzer wrote:
> which of course supports mapguide , it's a client mapping api
> On Fri, May 15, 2009 at 12:26 AM, Zac Spitzer <zac.spitzer at gmail.com>
> wrote:
>> 6.5 and 2009 are very different beasts
>> by source what do you mean?
>> you might want to have a look at openlayers
>> z
>> On Fri, May 15, 2009 at 12:24 AM, briancomeau
>> <brian.comeau at accenture.com> wrote:
>>> Hi Experts,
>>> I have tested communication between MapGuide and JavaScript using a 6.5
>>> version (MWF) map embedded in an HTML file. I would like to test the
>>> same
>>> thing with Autodesk MapGuide 2009. Is it possible to export to MWF and
>>> use
>>> the OBJECT tags to embed?
>>> How else would I go about accessing the source for the generated page? I
>>> want to be able to communicate between Flash and the MapGuide map.
>>> Thanks in advance!
>>> /Brian
>>> View this message in context:
>>> http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891259.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891445.html
