[mapguide-users] Exporting a MapGuide Map to HTML file?
Zac Spitzer
zac.spitzer at gmail.com
Thu May 14 10:27:27 EDT 2009
which of course supports mapguide , it's a client mapping api
On Fri, May 15, 2009 at 12:26 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> 6.5 and 2009 are very different beasts
> by source what do you mean?
> you might want to have a look at openlayers
> z
> On Fri, May 15, 2009 at 12:24 AM, briancomeau
> <brian.comeau at accenture.com> wrote:
>> Hi Experts,
>> I have tested communication between MapGuide and JavaScript using a 6.5
>> version (MWF) map embedded in an HTML file. I would like to test the same
>> thing with Autodesk MapGuide 2009. Is it possible to export to MWF and use
>> the OBJECT tags to embed?
>> How else would I go about accessing the source for the generated page? I
>> want to be able to communicate between Flash and the MapGuide map.
>> Thanks in advance!
>> /Brian
>> View this message in context: http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891259.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
