[mapguide-users] Exporting a MapGuide Map to HTML file?
Zac Spitzer
zac.spitzer at gmail.com
Thu May 14 10:26:37 EDT 2009
6.5 and 2009 are very different beasts
by source what do you mean?
you might want to have a look at openlayers
z
On Fri, May 15, 2009 at 12:24 AM, briancomeau
<brian.comeau at accenture.com> wrote:
> Hi Experts,
> I have tested communication between MapGuide and JavaScript using a 6.5
> version (MWF) map embedded in an HTML file. I would like to test the same
> thing with Autodesk MapGuide 2009. Is it possible to export to MWF and use
> the OBJECT tags to embed?
> How else would I go about accessing the source for the generated page? I
> want to be able to communicate between Flash and the MapGuide map.
> Thanks in advance!
> /Brian
> View this message in context: http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891259.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
