[mapguide-users] Exporting a MapGuide Map to HTML file?
Zac Spitzer
zac.spitzer at gmail.com
Thu May 14 11:01:33 EDT 2009
there is DWF land
On Fri, May 15, 2009 at 12:44 AM, briancomeau
<brian.comeau at accenture.com> wrote:
> So I took a look at OpenLayers, and it will not work for my particular
> situation.
> Any other ideas? Is there really no way to export to a standalone
> self-contained map anymore?
> briancomeau wrote:
>> So it is possible?
>> Are you saying that there isn't something like the previous MWF that I
>> could simply embed into an HTML file using the OBJECT tags? If not, is
>> there another way to do this? You mentioned an API, is that fairly easy to
>> use?
>> Thanks,
>> Brian
>> zspitzer wrote:
>>> which of course supports mapguide , it's a client mapping api
>>> On Fri, May 15, 2009 at 12:26 AM, Zac Spitzer <zac.spitzer at gmail.com>
>>> wrote:
>>>> 6.5 and 2009 are very different beasts
>>>> by source what do you mean?
>>>> you might want to have a look at openlayers
>>>> z
>>>> On Fri, May 15, 2009 at 12:24 AM, briancomeau
>>>>> Hi Experts,
>>>>> I have tested communication between MapGuide and JavaScript using a 6.5
>>>>> version (MWF) map embedded in an HTML file. I would like to test the
>>>>> same
>>>>> thing with Autodesk MapGuide 2009. Is it possible to export to MWF and
>>>>> use
>>>>> the OBJECT tags to embed?
>>>>> How else would I go about accessing the source for the generated page?
>>>>> I
>>>>> want to be able to communicate between Flash and the MapGuide map.
>>>>> Thanks in advance!
>>>>> /Brian
>>>>> View this message in context:
>>>>> http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891259.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com
>>>> +61 405 847 168
>>> Zac Spitzer -
>>> +61 405 847 168
> View this message in context: http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891833.html
Zac Spitzer -
+61 405 847 168
