[mapguide-users] Exporting a MapGuide Map to HTML file?
briancomeau
brian.comeau at accenture.com
Thu May 14 11:17:10 EDT 2009
So I can export to DWF and it will do what I'm looking for?
I found it was possible with 6.5 by looking through the examples in the API
for that version. It shows very distinctly how it can be done.
zspitzer wrote:
> there is DWF land
> On Fri, May 15, 2009 at 12:44 AM, briancomeau
> <brian.comeau at accenture.com> wrote:
>> So I took a look at OpenLayers, and it will not work for my particular
>> situation.
>> Any other ideas? Is there really no way to export to a standalone
>> self-contained map anymore?
>> briancomeau wrote:
>>> So it is possible?
>>> Are you saying that there isn't something like the previous MWF that I
>>> could simply embed into an HTML file using the OBJECT tags? If not, is
>>> there another way to do this? You mentioned an API, is that fairly easy
>>> to
>>> use?
>>> Thanks,
>>> Brian
>>> zspitzer wrote:
>>>> which of course supports mapguide , it's a client mapping api
>>>> On Fri, May 15, 2009 at 12:26 AM, Zac Spitzer <zac.spitzer at gmail.com>
>>>> wrote:
>>>>> 6.5 and 2009 are very different beasts
>>>>> by source what do you mean?
>>>>> you might want to have a look at openlayers
>>>>> z
>>>>> On Fri, May 15, 2009 at 12:24 AM, briancomeau
>>>>>> Hi Experts,
>>>>>> I have tested communication between MapGuide and JavaScript using a
>>>>>> 6.5
>>>>>> version (MWF) map embedded in an HTML file. I would like to test the
>>>>>> same
>>>>>> thing with Autodesk MapGuide 2009. Is it possible to export to MWF
>>>>>> and
>>>>>> use
>>>>>> the OBJECT tags to embed?
>>>>>> How else would I go about accessing the source for the generated
>>>>>> page?
>>>>>> I
>>>>>> want to be able to communicate between Flash and the MapGuide map.
>>>>>> Thanks in advance!
>>>>>> /Brian
>>>>>> View this message in context:
>>>>>> http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891259.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> Zac Spitzer -
>>>>> http://zacster.blogspot.com
>>>>> +61 405 847 168
>>>> Zac Spitzer -
>>>> +61 405 847 168
>> http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2891833.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://n2.nabble.com/Exporting-a-MapGuide-Map-to-HTML-file--tp2891259p2892756.html
