SPAM-LOW: [mapguide-users] Issue with Gdal DefaultRasterFileLocation with UNC path
Kori Maleski kori.maleski at gmail.com
Thu May 14 16:49:11 EDT 2009
If I use a mapped drive, no error occurs - but it fails to read the files
coordinate system and simply defaults to XY Arbitrary.  Fails to display as
a layer with a resource not found in the error log.
The login account has full control on the share.
I should note that this worked  with 2.0.1.
Cheers,
Kori Maleski
On Thu, May 14, 2009 at 1:26 PM, Dave Wilson <dave.wilson at autodesk.com>wrote:
>  Mapped drives generally don’t work. Is your MapGuide server running with
> a login that has permissions on the network share? Running the service with
> the default System account will not work.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andy Morsell
> *Sent:* Thursday, May 14, 2009 1:34 PM
> *To:* 'MapGuide Users Mail List'
> *Subject:* RE: SPAM-LOW: [mapguide-users] Issue with Gdal
> What if you use a drive letter mapping instead of a UNC?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com <http://www.spatialgis.com/>
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kori Maleski
> *Sent:* Thursday, May 14, 2009 11:56 AM
> *To:* MapGuide Users Mail List
> *Subject:* SPAM-LOW: [mapguide-users] Issue with Gdal
> Hi all,
> I am running MapGuide 2.0.2 with the service running under a domain
> account.
> The account has full control over a file server directory containing raster
> imagery in Sid format.  The imagery is in LL84.
> When configuring a raster data connection with the Gdal FDO I am having
> issues with applying coordinate system overrides when the files reside on a
> file server and are being accessed via UNC path.
> When I reference the file locally - i.e.  c:\myfiledirectory\myfile.sid,  I
> can override the coordinate system with no issues in both Studio and
> Maestro.  Map display is perfect.
> When I use a UNC path - i.e. \\myserver\myfiledirectory\myfile.sid, and
> try to use the override by refreshing to see the default spatial context I
> get the following error:
> In studio:  A popup windows error :
> The exception unknown software exception (0xc0000409) occurred in the
> application at location 0x00ea0a66
> In the event viewer:
> Out of process application '/LM/W3SVC/1/ROOT/mapguide/mapagent' terminated
> unexpectedly.
> Maestro displays no error.
> But after an attempt or two in either application, the service is
> unresponsive and W3SVC and mgserver services have to be restarted.
> Has anyone run into this issue before?
> Cheers,
> Kori Maleski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090514/8c4954e4/attachment.html
