[mapguide-users] AJAX/FUSION Viewer :: Pass data from Flash to
Map (2 Frames)
nasp
nspitilli at hotmail.com
Fri May 15 10:04:37 EDT 2009
take a look to this:
http://discussion.autodesk.com/autodeskimages/adsk/files/migrating_from_autodesk_mapguide_6.5_to_the_new_mapguide_technology.pdf
PassData.html, mentioned in previous message also contains what you need to
pass data from Mapguide to you application, like you did with MG 6.5.
Naspi
briancomeau wrote:
> Hi James,
> I looked at that code and it seems that it was posted in 2006. I'm using
> Autodesk's MapGuide Studio 2009. Is there anything for that particular
> piece of software that bears relevance for this?
> Thanks,
> Brian
> James Card wrote:
>> On Thu, 14 May 2009 12:19:08 -0700, briancomeau
>> <brian.comeau at accenture.com> wrote:
>>> I have two frames in a main.php file. One of those frames contains the
>>> reference to the AJAXViewer with the WebLayout that I created, and the
>>> other
>>> contains a Flash .SWF. I would like to be able to capture key values
>>> from
>>> the selections made on the AJAXViewer and pass those to Flash, and would
>>> also like to be able to pass values from Flash into the AJAXViewer.
>> The code at <http://www.calcad.com/MGOS/PassData.html> may help with the
>> first part of that; it demonstrates how to get the key values from the
>> selection set. The code samples page at
>> <http://trac.osgeo.org/mapguide/wiki/CodeSamples> may also be useful.
>> James Card
>> California CAD Solutions, Inc.
>> 209-578-5580 - Voice
>> 209-521-6493 - FAX
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/AJAX-FUSION-Viewer-%3A%3A-Pass-data-from-Flash-to-Map-%282-Frames%29-tp2899031p2907906.html
