[mapguide-users] AJAX/FUSION Viewer :: Pass data from Flash to Map (2 Frames)
briancomeau brian.comeau at accenture.com
Fri May 15 09:43:40 EDT 2009
Hi James,
I looked at that code and it seems that it was posted in 2006. I'm using
Autodesk's MapGuide Studio 2009. Is there anything for that particular piece
of software that bears relevance for this?
Thanks,
Brian
James Card wrote:
> On Thu, 14 May 2009 12:19:08 -0700, briancomeau
> <brian.comeau at accenture.com> wrote:
>> I have two frames in a main.php file. One of those frames contains the
>> reference to the AJAXViewer with the WebLayout that I created, and the
>> other
>> contains a Flash .SWF. I would like to be able to capture key values from
>> the selections made on the AJAXViewer and pass those to Flash, and would
>> also like to be able to pass values from Flash into the AJAXViewer.
> The code at <http://www.calcad.com/MGOS/PassData.html> may help with the
> first part of that; it demonstrates how to get the key values from the
> selection set. The code samples page at
> <http://trac.osgeo.org/mapguide/wiki/CodeSamples> may also be useful.
> James Card
> California CAD Solutions, Inc.
> 209-578-5580 - Voice
> 209-521-6493 - FAX
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/AJAX-FUSION-Viewer-%3A%3A-Pass-data-from-Flash-to-Map-%282-Frames%29-tp2899031p2907812.html
