[mapguide-users] AJAX/FUSION Viewer :: Pass data from Flash to
Map (2 Frames)
James Card
James.Card at calcad.com
Thu May 14 15:34:16 EDT 2009
On Thu, 14 May 2009 12:19:08 -0700, briancomeau <brian.comeau at accenture.com> wrote:
> I have two frames in a main.php file. One of those frames contains the
> reference to the AJAXViewer with the WebLayout that I created, and the
> other
> contains a Flash .SWF. I would like to be able to capture key values from
> the selections made on the AJAXViewer and pass those to Flash, and would
> also like to be able to pass values from Flash into the AJAXViewer.
The code at <http://www.calcad.com/MGOS/PassData.html> may help with the first part of that; it demonstrates how to get the key values from the selection set. The code samples page at <http://trac.osgeo.org/mapguide/wiki/CodeSamples> may also be useful.
James Card
California CAD Solutions, Inc.
209-578-5580 - Voice
209-521-6493 - FAX
