[mapguide-users] AJAX/FUSION Viewer :: Pass data from Flash to Map (2 Frames)
briancomeau brian.comeau at accenture.com
Fri May 15 12:27:11 EDT 2009
Ok, so I found Invoke URL under advanced commands as part of a Web Layout.
This looks like it can configure a button to do something. How can I have
this execute as soon as the user clicks (selects) an object on any layer.
For example, in 6.5, I could have a map and as soon as the user selects
Texas, 'TX' is passed to Flash. If the user were to zoom-in and click on
'Dallas', then 'Dallas' is passed to Flash.
How do I do this? I haven't found very many tutorials out there on this
software. If any of you kind-hearted souls out there wouldn't mind helping,
that would be fantastic.
Oh, I looked at passData, but even after changing the layer to
'VotingDistricts' (my layer instead of Rooms) it still doesn't work.
Thanks,
Brian
briancomeau wrote:
> How do I get to the screen showing "Invoke URL"?
> Sorry, I really do need sort of a step-by-step. I'm not familiar with this
> software, just the one I need to connect to.
> Thanks again!
> James Card wrote:
>> On Fri, 15 May 2009 06:43:40 -0700, briancomeau
>> <brian.comeau at accenture.com> wrote:
>>> I looked at that code and it seems that it was posted in 2006. I'm using
>>> Autodesk's MapGuide Studio 2009. Is there anything for that particular
>>> piece of software that bears relevance for this?
>> We're still using that code on our MGOS 2.0.2 servers (same code base as
>> MapGuide Enterprise 2009). That portion of the MapGuide API is unchanged.
>> James Card
>> California CAD Solutions, Inc.
>> 209-578-5580 - Voice
>> 209-521-6493 - FAX
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/AJAX-FUSION-Viewer-%3A%3A-Pass-data-from-Flash-to-Map-%282-Frames%29-tp2899031p2908690.html
