[mapguide-users] AJAX/FUSION Viewer :: Pass data from Flash to Map (2 Frames)
James Card James.Card at calcad.com
Fri May 15 13:41:18 EDT 2009
On Fri, 15 May 2009 09:27:11 -0700, briancomeau <brian.comeau at accenture.com> wrote:
> Ok, so I found Invoke URL under advanced commands as part of a Web Layout. This looks like it can configure a button to do something. How can I have this execute as soon as the user clicks (selects) an object on any layer.
> For example, in 6.5, I could have a map and as soon as the user selects Texas, 'TX' is passed to Flash. If the user were to zoom-in and click on 'Dallas', then 'Dallas' is passed to Flash.
This will require adding a JavaScript function to the page and hooking it into the selection-changed event. I'd start with "Hooking to events in the AJAX viewer" <https://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking> and the "MapGuide Viewer API Reference" <http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html>.
> Oh, I looked at passData, but even after changing the layer to
> 'VotingDistricts' (my layer instead of Rooms) it still doesn't work.
There are several parameters that will need to be configured in the invoke-url dialog in order to make this work, and of course you must have a page to forward the data to.
I'll admit that the change from MapGuide 6.5 to MapGuide Enterprise is a difficult one; there is much to learn about the new architecture -- it is a dramatically different set of technologies than the old one. Much more of the processing happens server-side now.
James Card
California CAD Solutions, Inc.
209-578-5580 - Voice
209-521-6493 - FAX
