[mapguide-users] AJAX/FUSION Viewer :: Pass data from Flash to Map (2 Frames)
briancomeau brian.comeau at accenture.com
Fri May 15 13:45:42 EDT 2009
Thanks James, I will read through those.
By the way, where can I find sample data and instructions on integrating it?
I would like to make a small Access database to test these things off of so
that I can change data as I like. The samples that came with MG are in .sdf
format that I cannot get open to edit.
Thanks!
James Card wrote:
> On Fri, 15 May 2009 09:27:11 -0700, briancomeau
> <brian.comeau at accenture.com> wrote:
>> Ok, so I found Invoke URL under advanced commands as part of a Web
>> Layout. This looks like it can configure a button to do something. How
>> can I have this execute as soon as the user clicks (selects) an object on
>> any layer.
>> For example, in 6.5, I could have a map and as soon as the user selects
>> Texas, 'TX' is passed to Flash. If the user were to zoom-in and click on
>> 'Dallas', then 'Dallas' is passed to Flash.
> This will require adding a JavaScript function to the page and hooking it
> into the selection-changed event. I'd start with "Hooking to events in the
> AJAX viewer"
> <https://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking>
> and the "MapGuide Viewer API Reference"
> <http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html>.
>> Oh, I looked at passData, but even after changing the layer to
>> 'VotingDistricts' (my layer instead of Rooms) it still doesn't work.
> There are several parameters that will need to be configured in the
> invoke-url dialog in order to make this work, and of course you must have
> a page to forward the data to.
> I'll admit that the change from MapGuide 6.5 to MapGuide Enterprise is a
> difficult one; there is much to learn about the new architecture -- it is
> a dramatically different set of technologies than the old one. Much more
> of the processing happens server-side now.
> James Card
> California CAD Solutions, Inc.
> 209-578-5580 - Voice
> 209-521-6493 - FAX
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/AJAX-FUSION-Viewer-%3A%3A-Pass-data-from-Flash-to-Map-%282-Frames%29-tp2899031p2909058.html
