[mapguide-users] Minimum install to use PHP/AJAX maps on Windows servers
Zac Spitzer zac.spitzer at gmail.com
Tue May 19 03:18:46 EDT 2009
On Tue, May 19, 2009 at 5:12 PM, shepwaydistrictcouncil
<neil.thompson at shepway.gov.uk> wrote:
> Hi
> I'm a systems developer for a UK Local Authority who would love to use MGOS
> on their website.
> I've set up MGOS Server as well as all the examples and we have Studio9
> working fine creating our layers etc but what I need is to find out the
> answers to some simple newbie questions so I'm hoping you guru's can assist
> please.
> 1) I run two servers 1 is the website and the other being an application
> server (currently running MapGuide 6.5 via Tomcat), With MGOS installed on
> my application server can I place the PHP files on my normal webserver still
> or does the entire install have to be on 1 server. (I currently pass traffic
> to tomcat serving MapGuide via Apaches JK connectors invisibly)
you just need to install the webserver extensions on your webserver
> 2) I also need to start with a real basic PHP example, so something with
> layers, menu, zoom and map but obviously as it's a live environment dont
> want to have all the folders accessible as they appear to be now, what is
> the best way to narrow down what I would need, for example do I need the
> fusion, schemareport, mapagent, stdicons and viewerfiles that all seem to be
> in the packaged web root directory
there are two viewer options, the classic viewer which is old skoool javascript
n frames or fusion which is cutting edge javascript & openlayers
I would recommend downloading the latest fusion (2.0) from the fusion website
http://trac.osgeo.org/fusion
The classic viewer is effectively EOL and prob won't be improved beyond
basic support fixes
there are lots samples on the mapguide wiki as well
http://trac.osgeo.org/mapguide/
check out this as well (remove the [space])
http://ennoble.dream[space]hosters.com/mapguide-central/
> Many thanks for any assistance. We always share our code back into the OS
> arena so if you guys can get us on our feet we will gladly push back all
> examples and code once running and promote the use of MGOS to all the UK
> Local Authorities.
> Kind regards
> Neil
> View this message in context: http://n2.nabble.com/Minimum-install-to-use-PHP-AJAX-maps-on-Windows-servers-tp2937896p2937896.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
