[mapguide-users] Pregenarate MapGuide Tiles
Matteo matteo.conte1979 at libero.it
Tue May 19 04:47:30 EDT 2009
Thanks a lot Kenneth
Regards
Matteo
Kenneth Skovhede, GEOGRAF A/S wrote:
> To generate tiles, do the following.
> 1) Open the map
> 2) Click the "Baselayer Groups" tab
> 3) Click on the "Finite Display Scales" item in the list
> 4) Set up the desired scales and save the map
> 5) Click the "MgCooker" icon (to the far right on the toolbar)
> 6) Select what groups and levels you want
> 7) Click "Build tiles now"
> You may skip step 3+4 if you already have the map setup.
> You can look at the sample in the Sheboygan package to see how it looks
> when it is set up.
> MgCooker is fairly new and you must use the latest preview release of
> Maestro, or it won't be there.
> Also, as MgCooker is new, there are a number of bugs:
> http://trac.osgeo.org/mapguide/query?status=new&status=assigned&status=reopened&component=Maestro&summary=~MgCooker&order=priority
> I have fixed all these bugs (twice actually) but not yet committed them.
> I will commit them soon and put up a new preview release when I have
> some spare time.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Matteo skrev:
>> Hi Zac,
>>  how I can pregenerate tiles with Maestro? I find a "Generate" button on
>> interface but it overwrite only the scale that I set.
>> Regards
>> Matteo
>> zspitzer wrote:
>>> you have two options, one is my openlayers javascript tile seeder
>>> and the other is the mg cooker tiler tool built into maestro
>>> http://trac.osgeo.org/mapguide/wiki/CodeSamples/Tiles/TileCacheSeeding
>>> http://trac.osgeo.org/mapguide/wiki/maestro
>>> z
>>> On Tue, May 19, 2009 at 2:04 AM, Matteo <matteo.conte1979 at libero.it>
>>> wrote:
>>>> Hi All,
>>>>  I need to pre-generate tiles from mapguide 2.0.2 maps to increase
>>>> Mapguide
>>>> speed. Is possible? If yes how? Another things: how I can set IIS 5 or
>>>> 6
>>>> for
>>>> mantain tiles?
>>>> Regards
>>>> Matteo Conte
>>>> View this message in context:
>>>> http://n2.nabble.com/Pregenarate-MapGuide-Tiles-tp2933966p2933966.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
View this message in context: http://n2.nabble.com/Pregenarate-MapGuide-Tiles-tp2933966p2938336.html
