[mapguide-users] Allow access to different layers based on login
Zac Spitzer
zac.spitzer at gmail.com
Wed May 20 04:29:12 EDT 2009
roping WFS into the equation here, it would be more secure if WFS
also supported using a layer defintion rather than feature source
based, as it allows
filtering and restricting access.
for example, i have an oracle feature source and I want to only
expose one table, at the moment I would need to create a separate oracle user
per table to achieve what otherwise potentially achievable via layer based WFS,
utilising a common approach above FDO
z
On Wed, May 20, 2009 at 6:13 PM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> I was thinking of the SelectFeatures, SelectAggregates and ExecuteSqlQuery
> functions.
> So "Resource Content" refers to data store content.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
> 9. The security level of the user and the render should be seperated, so the
> user cannot list resource content, but still render the layer. (relating to
> 5)
> would that require a change to the approach for the viewers n legends ?
> perhaps
> only return a shorten version of ResourceContent with the relevant
> info required?
> z
> On Wed, May 20, 2009 at 5:51 PM, Kenneth Skovhede, GEOGRAF A/S
> 8. Change the security system to allow overrides properly
> Current method is to look at the top folder, then trace down into the
> structure.
> At any point, a folder can block access, making it impossible to maintain
> write access to a single resource,
> as all folders in its path must be writeable by the user.
> (relating to 5)
> Zac Spitzer skrev:
> i agree about creating tickets for existing bugs as it also allows some
> tracking of comments which the wiki doesn't really help with, trac is
> a bit limited there...
> http://trac.osgeo.org/mapguide/wiki/Future/SecurityEnhancements ?
> shall we bounce the list of ideas round via email first?
> 1. pluggable external authentication (ie ldap, active directory,
> possibly use apache PAM here)
> 2. case insensitive usernames
> 3. removing the mandatory anonymous login requirement
> 4. adding login from anonymous session support to fusion and classic
> 5. improving MapGuide's "hissy fit" if a user tries to load a map that
> contains resources that they don't have permissions to.
> 6. exposing tile caches via http in a formalised manner, kinda relating to 3
> 7. switching from http status for errors codes to xml results?
> z
> On Wed, May 20, 2009 at 5:27 PM, Kenneth Skovhede, GEOGRAF A/S
> I would not mind writing up a proposal to list issues and workflow for the
> login/user-management issues.
> The RFC is formal, so I would write it as a wiki page initally, once the
> actual issues are decided,
> we could create issue tickets for each, and put up an RFC for each of the
> breaking changes?
> I don't have experience or time enough to actually implement the changes
> though.
> Zac Spitzer skrev:
> are there relevant bugs in trac? i had a quick browse but couldn't find any
> can we add a security component to trac?
> (wish we could assign multiple components to a single issue and
> making the field headers like components a hyperlink to all issues
> for that component, but I'm just a spoilt old jira junkie)
> also related is allowing ldap for user auth and getting rid of the stupid
> case sensitive usernames, using XML has quite a few drawbacks
> there's a swag of security related items here aren't there? definitely
> need an RFC
> I reckon autodesk's commercial customers would love this too
> and it probably is a show stopper for a lot of larger companies evaluating
> MG
> z
> On Wed, May 20, 2009 at 3:42 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> I don't see a lot of use for a login UI without also fixing the MapGuide
> security model and improving the way it deals with users accessing maps
> which contain resources they don't have permissions to. It's a fairly large
> can of worms...
> Unfortunately, I don't have any resources (development time, money) to throw
> at a problem this size, and I don't feel comfortable writing an RFC without
> being able to follow through on it.
> Jason
> -----Original Message-----
> From: Zac Spitzer
> Sent: Tuesday, May 19, 2009 10:37 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Allow access to different layers based on
> login
> we kinda need a login interface with the viewers,that way if anon
> access is allowed
> it should be the default, then allowing the users to login if they want/need
> to
> the whole anonymous login stuff is rather annoying
> time for an RFC maybe?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
