[mapguide-users] Allow access to different layers based on login
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 20 04:13:40 EDT 2009
I was thinking of the SelectFeatures, SelectAggregates and
ExecuteSqlQuery functions.
So "Resource Content" refers to data store content.
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> 9. The security level of the user and the render should be seperated, so the
> user cannot list resource content, but still render the layer. (relating to 5)
> would that require a change to the approach for the viewers n legends ? perhaps
> only return a shorten version of ResourceContent with the relevant
> info required?
> z
> On Wed, May 20, 2009 at 5:51 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk> wrote:
>> 8. Change the security system to allow overrides properly
>> Current method is to look at the top folder, then trace down into the
>> structure.
>> At any point, a folder can block access, making it impossible to maintain
>> write access to a single resource,
>> as all folders in its path must be writeable by the user.
>> (relating to 5)
>> Zac Spitzer skrev:
>> i agree about creating tickets for existing bugs as it also allows some
>> tracking of comments which the wiki doesn't really help with, trac is
>> a bit limited there...
>> http://trac.osgeo.org/mapguide/wiki/Future/SecurityEnhancements ?
>> shall we bounce the list of ideas round via email first?
>> 1. pluggable external authentication (ie ldap, active directory,
>> possibly use apache PAM here)
>> 2. case insensitive usernames
>> 3. removing the mandatory anonymous login requirement
>> 4. adding login from anonymous session support to fusion and classic
>> 5. improving MapGuide's "hissy fit" if a user tries to load a map that
>> contains resources that they don't have permissions to.
>> 6. exposing tile caches via http in a formalised manner, kinda relating to 3
>> 7. switching from http status for errors codes to xml results?
>> z
>> On Wed, May 20, 2009 at 5:27 PM, Kenneth Skovhede, GEOGRAF A/S
>> I would not mind writing up a proposal to list issues and workflow for the
>> login/user-management issues.
>> The RFC is formal, so I would write it as a wiki page initally, once the
>> actual issues are decided,
>> we could create issue tickets for each, and put up an RFC for each of the
>> breaking changes?
>> I don't have experience or time enough to actually implement the changes
>> though.
>> Zac Spitzer skrev:
>> are there relevant bugs in trac? i had a quick browse but couldn't find any
>> can we add a security component to trac?
>> (wish we could assign multiple components to a single issue and
>> making the field headers like components a hyperlink to all issues
>> for that component, but I'm just a spoilt old jira junkie)
>> also related is allowing ldap for user auth and getting rid of the stupid
>> case sensitive usernames, using XML has quite a few drawbacks
>> there's a swag of security related items here aren't there? definitely
>> need an RFC
>> I reckon autodesk's commercial customers would love this too
>> and it probably is a show stopper for a lot of larger companies evaluating
>> MG
>> z
>> On Wed, May 20, 2009 at 3:42 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>> I don't see a lot of use for a login UI without also fixing the MapGuide
>> security model and improving the way it deals with users accessing maps
>> which contain resources they don't have permissions to. It's a fairly large
>> can of worms...
>> Unfortunately, I don't have any resources (development time, money) to throw
>> at a problem this size, and I don't feel comfortable writing an RFC without
>> being able to follow through on it.
>> Jason
>> -----Original Message-----
>> From: Zac Spitzer
>> Sent: Tuesday, May 19, 2009 10:37 PM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Allow access to different layers based on
>> login
>> we kinda need a login interface with the viewers,that way if anon
>> access is allowed
>> it should be the default, then allowing the users to login if they want/need
>> to
>> the whole anonymous login stuff is rather annoying
>> time for an RFC maybe?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090520/206c9b98/attachment.html
