[mapguide-users] map layer points created from odbc connection not changing?
shepwaydistrictcouncil neil.thompson at shepway.gov.uk
Thu May 21 17:25:27 EDT 2009
Hi
We have a planning application layer we have created using spatial data via
an ODBC connection which plots all applications on our map perfectly.
Unfortunately though for some reason when a new application is added in the
SQL 2000 database that the ODBC reads from the map does not appear to
refresh with this new information (using F5 etc).
I said it should do so as these layer configs surely just tell mapguide when
it builds the layers at view time where to go and get the info to spatially
display.
Am I right or does the map need to be rebuilt every time content data is
added, removed or amended in the tables?
Thanks
Neil
View this message in context: http://n2.nabble.com/map-layer-points-created-from-odbc-connection-not-changing--tp2954283p2954283.html
