[mapguide-users] Maestro Login issue
Beluga
jdsalimi at yahoo.ca
Thu May 21 18:30:24 EDT 2009
I checked the services window of Apache and Mapguide Server v2.0 is "started"
but I don't see ApacheMapGuide. Perhaps this is the source of the problem?
How can I get that running?
shepwaydistrictcouncil wrote:
> Also, check the required services are running:
> ApacheMapGuide and Mapguide Server v2
> The full path to the login screen on a default install is :
> http://localhost:8008/mapguide/mapadmin/login.php
View this message in context: http://n2.nabble.com/Maestro-Login-issue-tp2954385p2954556.html
