[mapguide-users] Maestro Login issue
Beluga jdsalimi at yahoo.ca
Thu May 21 18:22:25 EDT 2009
Hi, thanks for the quick reply.
I installed Apache, PHP, and MapGuide separately. I know PHP and Apache are
configured to work together but I can't say the same for MapGuide. Does
MapGuide need to be configured to work with Apache?
I checked the httpd.conf file for Apache and it goes like this: localhost:80
I'll try that out.
Thanks,
shepwaydistrictcouncil wrote:
> Hi
> I think you may find the port is 8008 if you did the bundled install of
> MapGuide / PHP and Apache.
> You can check your installation by opening the httpd.conf file located at
> C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\Apache2\conf
> (if you did the default install)
> Open httpd.conf and look around line 235
> You should have something like : ServerName localhost:8008
> Hope that helps
> Neil
View this message in context: http://n2.nabble.com/Maestro-Login-issue-tp2954385p2954533.html
