[mapguide-users] Maestro Login issue
Jason Birch Jason.Birch at nanaimo.ca
Thu May 21 18:31:16 EDT 2009
MapGuide on Windows is likely not going to work with anything but the bundled Apache and PHP versions unless you compile from scratch.
You need to install both the Server and WebServerExtensions packages.  You will also likely want to grab the latest pre-release version of Maestro.
Jason
