[mapguide-users] polygon zoom problem
padmini godavarthi godavarthi.padmini at gmail.com
Fri May 22 12:19:47 EDT 2009
iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1) on win xp
i have a problem with zom toview function??????????????????
 Try
            If Not Session("id1") Is Nothing Then
                Dim mapCenterX As Double
                Dim mapCenterY As Double
                Dim serverVars As NameValueCollection =
Request.ServerVariables
                Dim strServerVars As String = ""
                Dim str1 As String
                For Each str1 In serverVars.AllKeys
                    strServerVars += "<br>" & str1
                Next
                Dim platform As String = serverVars("SERVER_SOFTWARE")
                Dim queryStr As String = serverVars("QUERY_STRING")
                Dim queryStr1 As String = serverVars("Form")
                Dim requestParams As NameValueCollection =
IIf(Request.HttpMethod = "POST", Request.Form, Request.QueryString)
                Dim sessionId As String = Request.QueryString("SESSION")
                Dim realPath As String =
Request.ServerVariables("APPL_PHYSICAL_PATH")
                Dim configPath As String = realPath + "webconfig.ini"
                MapGuideApi.MgInitializeWebTier(configPath)
                Dim userInfo As MgUserInformation = New
MgUserInformation(sessionId)
                Dim siteConnection As MgSiteConnection = New
MgSiteConnection
                siteConnection.Open(userInfo)
                Dim resService As MgResourceService =
siteConnection.CreateService(MgServiceType.ResourceService)
                Dim featureService As MgFeatureService =
siteConnection.CreateService(MgServiceType.FeatureService)
                Dim fetresource As MgResourceIdentifier = New
MgResourceIdentifier("Library://propertytax/resource.FeatureSource")
                Dim nameQuery As MgFeatureQueryOptions = New
MgFeatureQueryOptions()
                Dim val As String = "PARCEL_ID"
                nameQuery.AddFeatureProperty(val)
                Dim queryval As String = Session("id1")
                Dim totquery As String = val & "=" & "'" & queryval & "'"
                nameQuery.SetFilter(totquery)
                Dim tabname As String = "PROPERTY LAYER"
                Dim map As MgMap = New MgMap()
                map.Open(resService, "oramap")
                Dim layer As MgLayer = map.GetLayers().GetItem("PROPERTY
LAYER")
                Dim geometryReaderWriter As MgAgfReaderWriter = New
MgAgfReaderWriter()
                Dim featureReader As MgFeatureReader =
featureService.SelectFeatures(fetresource, layer.GetFeatureClassName(),
nameQuery)
                Dim geometryFactory As MgGeometryFactory = New
MgGeometryFactory()
                While featureReader.ReadNext()
                   Dim byteReader As MgByteReader =
featureReader.GetGeometry("GEOMETRY")
                   Dim geometry As MgGeometry =
geometryReaderWriter.Read(byteReader)
                   Dim centroid As MgPoint = geometry.GetCentroid()
                  mapCenterX = centroid.GetCoordinate().GetX()
                   mapCenterY = centroid.GetCoordinate().GetY()
         Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
"highlight(" & mapCenterX & "," & mapCenterY & ");", True)
                'End While
                featureReader.Close()
                Dim resService1 As MgResourceService =
CType(siteConnection.CreateService(MgServiceType.ResourceService),
MgResourceService)
                Dim featureService1 As MgFeatureService =
CType(siteConnection.CreateService(MgServiceType.FeatureService),
MgFeatureService)
                Dim fetresource1 As MgResourceIdentifier = New
                Dim nameQuery1 As MgFeatureQueryOptions = New
                Dim val1 As String = "PARCEL_ID"
                nameQuery1.AddFeatureProperty(val1)
                Dim queryval1 As String = Session("id1")
                Dim totquery1 As String = val1 + "=" + "'" + queryval1 + "'"
                nameQuery1.SetFilter(totquery1)
                Dim layer1 As MgLayer = map.GetLayers().GetItem("PROPERTY
LAYER")
                Dim featureReader1 As MgFeatureReader =
featureService1.SelectFeatures(fetresource1, layer1.GetFeatureClassName(),
nameQuery1)
                Dim selection As MgSelection = New MgSelection(map)
                selection.AddFeatures(layer1, featureReader1, 0)
                Dim selectXML As String = selection.ToXml()
                selection.Save(resService1, "oramap")
"test", "select('" & selectXML & "')", True)
                featureReader1.Close()
            End If
        Catch ex As Exception
            'MsgBox(ex.Message)
        End Try
and my java script functions are
function select(val) {
         var selectionXML = val;
          parent.parent.SetSelectionXML(selectionXML);
         //    parent.parent.mapFrame.ZoomToView(x,y,2000,true);
       parent.parent.refresh;
         alert("Selected");
        function highlight(x,y)
           //  alert("2nd");
           var xval = x;
           var yval = y;
          parent.parent.mapFrame.ZoomToView(xval,yval,1000,true);
i wrote all this code in taskpane page loading even
but i didnt get the exact zoom level of that parcel it remains same as the
initial view
can any one plz tell me the solution????????????????????????????
Regards,
padmini.
View this message in context: http://n2.nabble.com/polygon-zoom-problem-tp2958362p2958362.html
