[mapguide-users] Problem with layer selection and zoom to selection
ehsan ehsan85 at yahoo.com
Mon May 25 04:13:59 EDT 2009
hi, i trying to make selection on the map and zoom to selection...it seem the
layer had been selected, but in the properties pane show that "none
selected", in the status bar show "1 feature selected",i'm using the
JavaScript body onload to SetSelectionXml to make selection on the layer,
and ExecuteMapAction(10) to Zoom to selection..but it is no zoom to
selection and no properties..
Before this it went OK, the layer is selected and it is zoom to
selection...when i using a form to make search for the values..
after that i making a change to pass the 2 values through the URL like this:
http://localhost:8008/mapguide/search.php?NOLOT=4040&LAYER=Bukit%20Peteri
i had make a change to the mainframe.php,taskframe.php and taskframe.templ
by adding this 2 value..NOLOT & LAYER.
to make it able to pass the value in the URL, by using $_GET parameter.
is there any mistake that i had make here...?
can someone help me...i had just search through the forum..but can not find
any solution...
Thanks in advance.
ehsan.
View this message in context: http://n2.nabble.com/Problem-with-layer-selection-and-zoom-to-selection-tp2968465p2968465.html
