[mapguide-users] Selection Problem with PK-Column Type Int64
Andreas Morf
a.morf at fkl.ch
Mon May 25 04:57:16 EDT 2009
Hi all
I ran into a problem with selection of objects: using a column-type Int64 as
primary key, the objects are only marked as selected on the map (blue) if
the value of the primary key column are smaller than 2147483648 (in the
range of Int32) - otherwise, only the attributes are shown in the selection
tab of the AJAX-Viewer but nothing on the map...
Any ideas?
Andreas
